Incremental counter - daily usage via LUA
lamama1234
Post by lamama1234 »
I have an incremental counter for water usage and I wish to add automation for total amount of daily water usage. The Domoticz utility widget shows both the total amount of water used + daily:
But when I use LUA's
print(otherdevices_svalues['Water Main'])
I only get this crazy number that even using my water counter divider (450000), doesn't make any sense:
2021-11-07 15:47:00.228 Status: LUA: 18446744073694285637
Is there a way to get via LUA the current daily water usage of my incremental counter?
Using Domoticz 2020.1 stable.
Domoticz version: 2025.1
Re: Incremental counter - daily usage via LUA
Seems not possible in LUA unless like in dzVents you call the datadump Json and get the data out of there. (with /json.htm?type=devices&rid=IDX)
dzVents gets the .counterToday value from the JSON somehow. It is somewhere here https://github.com/domoticz/domoticz/tr ... ts/runtime
