Telegram message
jacobsentertainment
Domoticz version: 2021-1
Telegram message
Post by jacobsentertainment »
Sorry to ask here, I tried finding some info on using telegram for notification only but all I try is giving me a telegram message and a mail message, I only want a telegram message not a mail message.
Can somebody tell me a small line how to only get a notification by telegram?
Domoticz version: 2025.1
Re: Telegram message
I suppose you have activated telegram notifications according https://www.domoticz.com/wiki/Telegram_notification
Then you can send a notification from dzVents with NSS_TELEGRAM as option in the notify statement.
See also the wiki on .notify function https://www.domoticz.com/wiki/DzVents:_ ... terface.29
jacobsentertainment
Hi Waltervl,
I have the telegram functioning in my system this works brilliant, only thing is when I use the notification it also sends me next to a message in telegram also the same in the mail. I want the notification to be only in telegram and searching trough the forum didn't give me the results I hoped for and from the wiki I couldn't make any sense.
If I use
domoticz.notify("Sauna","Temperatuur is nu "..Temp.."°", domoticz.NSS_TELEGRAM)
or
domoticz.notify("Sauna","Temperatuur is nu "..Temp.."°", "telegram")
The result is the same, telegram and mail notification.
Here is a topic with some examples. Perhaps needs some extra arguments like sound etc.
https://domoticz.com/forum/viewtopic.php?t=25676
jacobsentertainment
Thanks for the info, I got it working,
domoticz.notify("Domoticz", "testing telegram", domoticz.PRIORITY_NORMAL,domoticz.SOUND_DEFAULT, "" , "telegram")
I'm just a toolpusher not a programmer and try to figure out what is doing what in the script,
Just a couple of questions if you don't mind. What is "Domoticz" and , "" , good for in this line? I don't see any of this back in the log or in the output result.
Syntax according wiki is:
.notify(subject, message [,priority][,sound][,extra][,subsystem].[,delay]
Domoticz should be the subject (for email) and likely be ignored for telegram. The "" is the empty value for extra.
jacobsentertainment
Thanks a lot Waltervl!
