how send a snapshot of camera to telegram ? Topic is solved
- Domoticz version: 2024.4
hi guys.
can i send a snapshot of my ip camera to telegram ? for example when motion sensor is on send a snap shot as notification
i have a active bot in telegram. and i use this for send notifications and alarm of sensors. but now i want use for send snap shots of camera.
thank you
thank you
Re: how send a snapshot of camera to telegram ?
I think that this thread is what you are looking for
http://domoticz.com/forum/viewtopic.php ... oto#p81428
hi thank you. i will read thiskoowee wrote:Hi
Topic is not available
- Domoticz version: 2023.1
I had the exact same challenge, but could not find a solution from within Domoticz.
I solved it with Node-Red (really simple there).
- Domoticz version: 2024.7
- jvdz
- Domoticz version: 4.107
.. and in case you like to send multiple snapshots in a group: viewtopic.php?p=277690#p277690
I use dzVents and the chatbot version. This the code.
Of which the numbers 5 en 2 resp. are the 2 mentioned camera's.
dz.snapshot("Webcam Buiten;Voordeurbel","Er staat een bezoeker aan de voordeur!")
local chatid = telegram.getId('XXXX')
result = telegram.sendText(chatid, 'Voordeur bel is ringing!')
result = telegram.sendImage(chatid, 5)
result = telegram.sendImage(chatid, 2)
- Domoticz version: 2024-2
Did you write a function telegram? There is no keyword telegram in dzVents as far as I know.
- Domoticz version: V3.8650
I think its this one:
https://www.domoticz.com/forum/viewtopic.php?t=21213
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
