help with dashticz docker
pvklink
Domoticz version: latest b
Post by pvklink »
I have all my software running with docker containers(10) with one docker-compose...
But with the last releases of dashticz i cant get this working anymore for dashticz..
So i remove the docker stuff for apache, php and dashticz and did this part the old way:
sudo apt-get update -y
sudo apt-get install apache2 php php-xml php-curl libapache2-mod-php
sudo chmod 777 $homevolumes/dashticz
sudo ln -s $homevolumes/dashticz/ /var/www/html
sudo systemctl restart apache2
The above config works with my general dashticz volume (git) on /home/pi/pvkmenu/volumes/dashticz...
All the other docker stuff works great with a large docker-compose file and volumes!
I like to have apache and php also with docker in the above compose structure and remove the old manual apache and php install on the rpi!
So i took a fragment of my compose file (below) and dockerfiles. This setup works for domoticz and dashticz gives an error.
Thats strange because the dashticz volume is the same git download and adjustments i used with the described old way...
QUESTION: what am i doing wrong with my compose part/dockerfile part
Because the volume part must be ok, as it is working with the old non-docker setip
I start the website with
http://192.168.20.38:8084/index.html and get a dashticz ERROR
docker-compose file
version: '3.6'
services:
  domoticz:
    container_name: domoticz
    build:
      context: /home/pi/pvkmenu/services/domoticz/.
    ports:
    - "82:8080"
    - "444:443"
    depends_on:
      - mosquitto
      - '/dev/ttyUSB0:/dev/ttyUSB0'
      - '/dev/ttyUSB1:/dev/ttyUSB1'
      - '/dev/ttyACM0:/dev/ttyACM0'
    volumes:
    - "/home/pi/pvkmenu/volumes/domoticz/data:/opt/domoticz/userdata"
    - "/var/run/docker.sock:/var/run/docker.sock"
    restart: unless-stopped
    network_mode: bridge
    environment:
    - PUID=1000
    - PGID=1000
    - LOG_PATH=/opt/domoticz/userdata/domoticz.log
  dashticz:
    container_name: dashticz
    build:
      context: /home/pi/pvkmenu/services/dashticz/.
    restart: always
    depends_on:
      - domoticz
    ports:
      - "8084:80"
    volumes:
      - /etc/localtime:/etc/localtime:ro
      - type: bind
        source: /home/pi/pvkmenu/volumes/dashticz/
        target: /var/www/html/
dockerfile dashticz( i took from the git pull folder)
# Dockerfile for Dashticz
# See http://nelkinda.com/blog/apache-php-in-docker/
FROM php:7.4-apache
ARG tz="Europe/Amsterdam"
RUN printf "[PHP]\ndate.timezone = $tz\n" > /usr/local/etc/php/conf.d/tzone.ini && \
mv "$PHP_INI_DIR/php.ini-production" "$PHP_INI_DIR/php.ini"
#RUN printf "[PHP]\ndate.timezone = $tz\n" > /usr/local/etc/php/conf.d/tzone.ini
SHELL ["/bin/bash", "-c"]
Jablotron connection, Ikea
pvklink
Re: help with dashticz docker
Post by pvklink »
I got dashticz in a docker working again for 95%.
Only my calender, news en 112 blocks dont work, they stay empty.
And i have to refresh my cache several times to get the 95% screen shown...
I also tried serveral browsers
It must be related with my dockerfile/image because i use he same data dashticz volume (latest beta git of dashticz) for both the docker based configuration and my other non-docker configuration 1:1 like the manual setup as described in the wiki
95% working set with docker
dockercompose (part of dashticz)
  dashticz:
    build:
      args:
        MYHUB: "${MYHUB_dashticz}php:7.4-apache"
    restart: always
    depends_on:
      - domoticz
    ports:
      - "8084:80"
    volumes:
      - type: bind
envfile
MYHUB=docker.io/
MYHUB_apache=docker.io/
MYHUB_broadlink=docker.io/
MYHUB_dashboard=docker.io/
MYHUB_dashticz=docker.io/
MYHUB_domoticz=docker.io/
MYHUB_drupal=docker.io/
MYHUB_mosquitto=docker.io/
MYHUB_motion=docker.io/
MYHUB_motioneye=docker.io/
MYHUB_mysql=docker.io/
MYHUB_nextpvr=docker.io/
MYHUB_nodered=docker.io/
MYHUB_phpmyadmin=docker.io/
MYHUB_portainer=docker.io/
MYHUB_raspiap=docker.io/
MYHUB_registry=docker.io/
MYHUB_tvheadend=docker.io/
MYHUB_unify=docker.io/
MYHUB_apachetest=docker.io/
dockerfile
ARG MYHUB
FROM ${MYHUB}
CMD ["apache2-foreground"]
