sudo git pull
sudo git reset --hard 3725a295e12531e5c5f68d03d3e6f0c1f646b1caModerator: leecollings
sudo git pull
sudo git reset --hard 3725a295e12531e5c5f68d03d3e6f0c1f646b1caI get this message:waltervl wrote: Monday 18 October 2021 16:54 Yes, FirstThen restart DomoticzCode: Select all
sudo git pull sudo git reset --hard 3725a295e12531e5c5f68d03d3e6f0c1f646b1ca
HEAD is now at 3725a29 Remove `devices` argument from Adapters
OK, looks like it is not a problem, the plugin works and created devices (after I had enabled this in the Domoticz settings).manjh wrote: Monday 18 October 2021 17:17I get this message:waltervl wrote: Monday 18 October 2021 16:54 Yes, FirstThen restart DomoticzCode: Select all
sudo git pull sudo git reset --hard 3725a295e12531e5c5f68d03d3e6f0c1f646b1caIs that OK?Code: Select all
OK, thanks. I'll be patient.waltervl wrote: Monday 18 October 2021 18:55 Zigbee battery levels can take some time to being send by the sensor. So give it a day or so.
Zigbee2MQTT:info 2021-10-23 19:04:21: Currently 6 devices are joined:
Zigbee2MQTT:info 2021-10-23 19:04:21: garage (0x000d6f0016194686): HS3SA - HEIMAN Smoke detector (EndDevice)
Zigbee2MQTT:info 2021-10-23 19:04:21: begane grond (0x000d6f0016193e73): HS3SA - HEIMAN Smoke detector (EndDevice)
Zigbee2MQTT:info 2021-10-23 19:04:21: 1e verdieping (0x000d6f00161f9b87): HS3SA - HEIMAN Smoke detector (EndDevice)
Zigbee2MQTT:info 2021-10-23 19:04:21: 2e verdieping (0x000d6f00161f715e): HS3SA - HEIMAN Smoke detector (EndDevice)
Zigbee2MQTT:info 2021-10-23 19:04:21: berging (0x000d6f00161f96d7): HS3SA - HEIMAN Smoke detector (EndDevice)
Zigbee2MQTT:info 2021-10-23 19:04:21: 0xb4e3f9fffecb218f (0xb4e3f9fffecb218f): Not supported (Router)
Thanks for the suggestion, I submitted a request.EddyG wrote: Saturday 23 October 2021 19:36 Just make a request on https://github.com/Koenkk/zigbee2mqtt/issues/new/choose for adding the new device (bulb).
It might be that is just a new type which is (almost) the same as the already supported ones.
It could then be easily added by Koenk.
.*_power_;.*_effect;.*_pwrmem;.*_volt;.*_ampere;.*_thb;.*_lowbtrOff out the Conbee-2 for aprox. for 10 minutes and smoke detectors connect to IKEA lamp, after ON Conbee-2manjh wrote: Sunday 24 October 2021 17:51 A newbee question, no doubt...
I have been running a network of Conbee-2, with five smoke detectors across the house.
Today I added an IKEA lamp on the first floor, which should improve link-quality for some of the remote smoke detectors.
But I see that the smoke detectors hang on to the link with the controller, in stead of switching to the nearby router.
Is there a way to force a connection going to a router? I realize that re-pairing the smoke detectors might do it, but that seems like something I don't want to do...
Hmmm.. by the time I read this post, one of the smoke detectors had decided to connect to the Ikea bulb router in stead of the Conbee coordinator.. so apparently it happens without me forcing it!Creo2005 wrote: Sunday 24 October 2021 18:32Off out the Conbee-2 for aprox. for 10 minutes and smoke detectors connect to IKEA lamp, after ON Conbee-2manjh wrote: Sunday 24 October 2021 17:51 A newbee question, no doubt...
2021-10-25 01:40:14.307 (Zigbee2MQTT) Received available devices list from bridge
2021-10-25 01:40:14.309 (Zigbee2MQTT) nachtlampje: device definiton not found, skipping...From the Z2M frontend, I removed the device and re-paired it. Now it works, but this is how it was yesterday... at some point the device became "unsupported". Will see what happens.manjh wrote: Monday 25 October 2021 1:44 I was too quick being happy... I am running into strange problems.
The lamp was working OK, then suddenly stopped reacting.
Restarted Z2M, checked the config, re-paired the device.
It does come up in the network map, but in the list of devices it says "unsupported".
Device name and maker are there OK.
When I look in the log, I see:Does this mean the plugin is missing something? If so, why does it sometimes work, and sometimes does not?Code: Select all
2021-10-25 01:40:14.307 (Zigbee2MQTT) Received available devices list from bridge 2021-10-25 01:40:14.309 (Zigbee2MQTT) nachtlampje: device definiton not found, skipping...
Which file can I check to see that?EddyG wrote: Monday 25 October 2021 11:22 I see that in the latest version of zigbee2mqtt (dev branch) there is (at the end) a bulb LED1949C5 defined. So update zigbee2mqtt.
Zigbee2MQTT version 1.21.2-dev commit: 3f0a2fedUsers browsing this forum: No registered users and 1 guest
