I'm using an Raspberry 7inch touchscreen with the floorplans. The problem is that in the floorplans the buttons can't be pushed, because the floorplan sees the touch-input as a mouse-hover, and then shows the popup from that switch in the floorplan.
I would like to disable the popup feature in the floorplans. How do i do that?
Greetings Bob.
Disable popup on mouse hover in Floorplans
- Dnpwwo
Re: Disable popup on mouse hover in Floorplans
@Bob1976,
Not sure why your touchscreen would do that, maybe because the Raspberry is slow to process the event.
You can't turn it off but in the Settings / Floorplans tab you can adjust how long the mouse is held down before the pop up is displayed. Setting that to a really high value (10000?) may help.
elwinmage
Hello, same probleme here with another touchscreen, on LightSwitch panel no problem, but in FloorPlan, also the setting si set to 5000ms, the popup appears immediatly an the clock don't work...
elwinmage
It seems to be a chromium problem, works fine with iceweasel
