execute through SSH
boodschap
execute through SSH
Post by boodschap »
I have this script I want to execute through SSH. It works perfectly in terminal, but not in my script... What am I missing?
		devices = { 'Radio' },
		timer = { 'every 5 minutes' },
		if domoticz.devices('Radio').state == 'Off' then
			os.execute ("ssh [email protected] killall mplayer")
			os.execute ("ssh [email protected] mplayer -noconsolecontrols /home/pi/domoticz/testsound.mp3 -volume 100 &> /dev/null")
		if device.state ~= 'Off' then
			if device.state == 'Radio 1' then
				os.execute ("ssh [email protected] mplayer -noconsolecontrols http://icecast.vrtcdn.be/radio1-high.mp3 -volume 100 &> /dev/null")
			if device.state == 'Studio Brussel' then
				os.execute ("ssh [email protected] mplayer -noconsolecontrolshttp://icecast.vrtcdn.be/stubru-high.mp3 -volume 100 &> /dev/null")
heggink
Domoticz version: 12451
Re: execute through SSH
Post by heggink »
Typical problem. In order to ssh, you need to have the right credentials in place. I use passwordless ssh for which you need to exchange keys. Keys are exchanged on a per user basis so it makes a difference which user domoticz runs as. If from the command line it works then I suspect the domoticz user is a different one and you would need to exchange keys for that. Mind you, if (like with me) domoticz runs as root then you will have to exchange keys for root which is obviously a bit of a security concern (root being able to do passwordless commands).
DASHTICZ 🙃
P1 meter & solar panel
boodschap
Post by boodschap »
Ok Thank you! Changed the script, works as a charm!
sudo -u pi ssh [email protected] mplayer -noconsolecontrols http://icecast.vrtcdn.be/radio1-high.mp3 -volume 100 &> /dev/null
