thermostat  [Solved]
Cdzn
thermostat
Post by Cdzn »
Hello there. I have thermostat and would like to heat and cool in time. I wrote these script but can`t change setpoint from it.
local timer1 = 'every minute' --'at 06:00'
		timer = { timer1}
			  logging = { level = domoticz.LOG_DEBUG },
		   execute = function(domoticz,item,devices)
		    if (item.isTimer) then domoticz.devices(3).SetPoint= 26
Setpoint just don`t setting at thermostat
besix
Re: thermostat  [Solved]
Post by besix »
Change
to
if (item.isTimer) then domoticz.devices(3).updateSetPoint(26)
Cdzn
Re: thermostat
Post by Cdzn »
besix wrote: Saturday 02 October 2021 8:29 Change
to
What I just didn’t do. Thanks. Why setpoint does`t work?
EddyG
Re: thermostat
Post by EddyG »
besix
Re: thermostat
Post by besix »
		timer = {'every minute'},				-- causes the script to be called every minute
		   execute = function(domoticz,item)
		        domoticz.devices('SetPoint').updateSetPoint(26)
Rename SetPoint to your thermostat and check
Cdzn
Re: thermostat
Post by Cdzn »
besix wrote: Saturday 02 October 2021 9:47
Your 1st answer working. Thank You! every minure just for testing.
Cdzn
Re: thermostat
Post by Cdzn »
One more question. How to make this work with 2 different timers
local Timer1 = 'at 19:43'
local Timer2 = 'at 19:44'
    	    timer = {Timer1, Timer2}
		        return
		    if (item.isTimer) then domoticz.devices(3).updateSetPoint(24.5)
		        return
besix
Re: thermostat
Post by besix »
I think it will help
return
	on =
	   {timer =
		   {'at 8:00',
		    'every 3 minutes between 9:30 and 23:00',
                    'at 23:01' }
	execute = function(dz, item)
    if item.isTimer then
    if dz.time.matchesRule('at 8:00') then
        dz.devices('SetPoint').updateSetPoint(24)
	if dz.time.matchesRule('every 3 minutes between 9:30 and 23:00') then
        dz.devices('SetPoint').updateSetPoint(23)
	if dz.time.matchesRule('at 23:01') then
        dz.devices('SetPoint').updateSetPoint(21)
Cdzn
Re: thermostat
Post by Cdzn »
besix wrote: Saturday 02 October 2021 17:47 I think it will help
return
	on =
	   {timer =
		   {'at 8:00',
                    'at 23:01' }
Thank You!!!
rrozema
Re: thermostat
Post by rrozema »
Many thermostats have a 'mode' setting, switching between 'economy' and 'normal' modes. Both modes have their own setpoint, so you need to set the both temperatures only once, and you only switch the mode control from economy to normal and vice versa. This allows you to still adjust the 'normal' setpoint manually without having to re-code your script.
If your thermostat doesn't have such an economy mode, have a look at SVT, the Smart Virtual Thermostat plugin. If you can switch your heating on and off from domoticz using for example a simple esp relay, use this plugin to replace your normal thermostat and most likely you'll get better comfort plus on top of that use less energy for heating your house.
Cdzn
Re: thermostat
Post by Cdzn »
rrozema wrote: Monday 04 October 2021 20:50 Many thermostats have a 'mode' setting, switching between 'economy' and 'normal' modes. Both modes have their own setpoint, so you need to set the both temperatures only once, and you only switch the mode control from economy to normal and vice versa. This allows you to still adjust the 'normal' setpoint manually without having to re-code your script.
The problem is i using handmade thermostate with Nextion display and internal ESPeasy thermostat, not in domoticz, to have a possibility to change setpoint from Domoticz or from touchscreen.
NExt step i want to make script like this, which remember last setpoint, turn thermostate ON, after 30 minutes return setpoint to last value.
		devices = {
			'Принудительный нагрев',
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
	execute = function(domoticz, switch)
	  --local Lastsp = domoticz.devices(3).updateSetPoint(25)
	    if (switch.state == 'On')
	    then domoticz.devices(3).updateSetPoint(27)
	         switch.switchOff().afterMin(30)
	      elseif (switch.state == 'Off')
            then domoticz.devices(3).updateSetPoint(24)
rrozema
Re: thermostat
Post by rrozema »
If you are in control om the software inside the thermostat, why don't you rewrite it to be a device to show and enter a setpoint only. The setpoint set is sent into a setpoint device in Domoticz Then have your Domoticz do the actual work of regulating the heat source. For example by using svt.
Cdzn
Re: thermostat
Post by Cdzn »
rrozema wrote: Wednesday 13 October 2021 16:13 If you are in control om the software inside the thermostat, why don't you rewrite it to be a device to show and enter a setpoint only. The setpoint set is sent into a setpoint device in Domoticz Then have your Domoticz do the actual work of regulating the heat source. For example by using svt.
I have no idead how to make it works
rrozema
Re: thermostat
Post by rrozema »
Cdzn wrote: Thursday 14 October 2021 11:45
I assumed you had written the software in the thermostat yourself.
Users browsing this forum: rini52 and 1 guest
