- Are the command options working for Evohome (controller)? Meaning statements like afterMin()? <- only possible for zones
- Is it possible to read the current status/mode of the controller? I've tried evohome_controller.state()
- What is the difference between setMode AUTO and AUTOWITHRESET?
- How can I turn on the heater in AUTO mode, but including the configuration of the special day (CUSTOM). I've tried to run the two commands after each other: evohome_controller.setMode(dz.EVOHOME_MODE_AUTO) evohome_controller.setMode(dz.EVOHOME_MODE_CUSTOM) which results in the heater is turned off
- How do the optional parameters in setMode() work?
- dparm: I guess this is refers to make this command temparary? I've tried this line. It switches to away mode, but it doesn't switch back after the minute
local Time = require('Time') local function makeSeconds(sec, min, hour, day, month, year ) -- simplified (month=30, year=365) if sec == nil then sec = 0 end if min == nil then min = 0 else min = min * 60 end if hour == nil then hour = 0 else hour = hour * 3600 end if day == nil then day = 0 else day = day * 24 * 3600 end if year == nil then year = 0 else year = year * 365 * 24 * 3600 end return sec + min + hour + day + year end evohome_controller.setMode(dz.EVOHOME_MODE_AWAY, os.date("!%Y-%m-%dT%TZ",os.time(Time(dz.time.raw)) + makeSeconds(0,1,0,0,0,0))) -- bij nachtknop indrukken gaat de verwarming tijdelijk op away
- What is 'action' meant for?
