JSON command for create virtual sensor - custom sensor?
sammyke007
Domoticz version: 2022.1
Post by sammyke007 »
Anyone who knows the JSON command for creating a virtual sensor - custom sensor?
It has to be
http://IPADRESS:8080/json.htm?type=createvirtualsensor&idx=1&sensorname=Test&sensortype=XYZ
where XYZ should be the number for a custom sensor.
Some sensortypes are wrote down here already:
https://www.domoticz.com/wiki/Domoticz_ ... ual_sensor
Any idea?
Tnx!
McMelloW
Domoticz version: V2024.1
Re: JSON command for create virtual sensor - custom sensor?
Post by McMelloW »
sammyke007 wrote: Tuesday 12 December 2017 16:53 Hi
It has to be
Any idea?
Tnx!
You need to add an extra parameter for the y-axis. But i don't know how to do this. Facing exact the same problem.
Greetings McMelloW
Filnet
Domoticz version: 2025.2 ß
Post by Filnet »
Hello
Have you solved this?
I have the same problem.
Thanks for your help.
Tristan
Post by Tristan »
http://IPADRESS:8080/json.htm?type=createvirtualsensor&idx=HARDWAREID&sensorname=NAME&sensortype=TYPEID&sensoroptions=1;AXUNIT
AXUNIT = Ax Unit
HARDWAREID = Hardware index of the Dummy Hardware you are using (not a sensor index)
NAME = Name of the new sensor
TYPEID = See https://github.com/domoticz/domoticz/bl ... aretypes.h
Filnet
Post by Filnet »
Thank you!
philchillbill
Post by philchillbill »
If you create a test device (of any type you like) in the Domoticz UI in a browser while you have developer tools enabled (ctrl-shift-i in Chrome), under the network tab you'll see the JSON that the UI sends back to the Domoticz engine when you create or change something. From this, you can figure out the correct JSON to use for any command !
Last edited by philchillbill on Friday 19 July 2019 19:35, edited 1 time in total.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
willem9136
Post by willem9136 »
Question, can I create any type of sensor?
I need a kind of custom sensor with 3 inputs
I need to see the output of 3 separate thermometers in 1 graph on the dashboard of Domoticz.
Is this possible?
Domoticz version: 2025.1
willem9136 wrote: Monday 11 October 2021 11:30 Question, can I create any type of sensor?
Is this possible?
No this is not possible. A Custom Sensor can only store and display 1 value. Also it is not possible to view graphs on the default dashboard of Domoticz.
If you want to graph multiple values on a dashboard you need something like dashticz extension or make your own graphing with grafana.
henkkoorn
Domoticz version: 2023.1
Post by henkkoorn »
philchillbill wrote: Friday 19 July 2019 19:35 If you create a test device (of any type you like) in the Domoticz UI in a browser while you have developer tools enabled (ctrl-shift-i in Chrome), under the network tab you'll see the JSON that the UI sends back to the Domoticz engine when you create or change something. From this, you can figure out the correct JSON to use for any command !
I have something here
Users browsing this forum: Google [Bot], willemd and 1 guest
