I am having a weird issue in the latest stable dz build with the Fibaro FGS224:
The physical connection seems right, everything works as expected with a double pulse switch: 2 buttons, 2 inputs and 2 lights. Lights toggle state when the corresponding button is pressed.
However in domoticz, after device inclusion, I get 6 idx'es of which 1 idx is on when either or both lamps are on. If i turn that idx off manually in dz, 1 lamp turns off, the other is still pyhiscally on. None of the other switch idx'es seem to be doing anything with the lamps.
This doesn't seem right, this would mean I can't control the S2 switch. S1 is the only one thats triggerable through dz, yet physically, S1 controls Q1 and S2 controls Q2. None of the S'es control any other Q. Weird stuff and I can't seem to figure it out?
Obviously, I was expecting 2 switchable switches that would correspond with S1 and S2.
Please help, I don't know what's wrong?
Cheers!
Fibaro FGS224 Double Smart Module+ Topic is solved
Ph0tonblast
commentator
Re: Fibaro FGS224 Double Smart Module+
domoticz is really buggy for zwave with fibaro
a workaround to use both switches is restart Domoticz after the including of fgs224 is completed
Ph0tonblast
You're a life saver, thanks restarting the service worked!commentator wrote: Friday 01 October 2021 15:59 domoticz is really buggy for zwave with fibaro
