Absolutely reliable - retransmission
ensingg
Post by ensingg »
Please help me getting the most reliable solution and reporting when there is a possiblity the command has not be executed on the device I want.
1. Check health plugin
2. Check for ReTX (retransmissions) ? Or are ReTX not the most important indicator that something might have been nog executed?
In the /rest-zigate/1/plugin-stat' there are a lot of variables :-)
APSAck : 1547
APSFailure : 0
APSNck : 26
AvgTimeSpentInForwarder : 0
AvgTimeSpentInProcFrame : 0
AvgZiGateRoundTime8000 : 0
AvgZiGateRoundTime8011 : 0
AvgZiGateRoundTime8012 : 0
CRC : 0
Cluster : 1719
CurrentLoad : 0
Error : False
ForwardedQueueCurrentSize : 0
FrameErrors : 0
MaxApdu : 4
MaxLoad : 41
MaxNpdu : 3
MaxTimeSpentInForwarder : 0
MaxTimeSpentInProcFrame : 0
MaxZiGateRoundTime8000 : 0
MaxZiGateRoundTime8011 : 0
MaxZiGateRoundTime8012 : 0
PDMLoads : 0
ReTx : 0
Received : 8290
Rxph : 113,21
Rxpm : 1,89
Rxps : 0,03
Sent : 1664
StartTime : 1632385775
Trend : {@{Load=0; Rxps=0,03; Txps=0,01; _TS=51719}, @{Load=0; Rxps=0,03; Txps=0,01; _TS=51720}, @{Load=0; Rxps=0,03;
Txps=0,01; _TS=51721}, @{Load=0; Rxps=0,03; Txps=0,01; _TS=51722}...}
Txph : 22,72
Txpm : 0,38
Txps : 0,01
Uptime : 263617
WriterQueueCurrentSize : 0
Domoticz version: 2025.1
Re: Absolutely reliable - retransmission
I believe the Zigate will always report back if a command is executed. For a switch if you switch it on and the ZigBee device did not listen the switch on the Domoticz user interface Will be switched back to original situation.
pipiche
Post by pipiche »
The parameters you are listed here are for the plugin developers . What exactly is your issue ?
