I am new to the Zigbee stuff. Everything till now was running with RFLINK and KlikAanUit.
First of all I liked the idea of a two-way protocol in case of reliability.
But also the mesh netwerk part got my interest.
But now I have a Zigate + USB stick, a INNR SP220-2 set. The signal strength on the SP220 is 2 to 3.
Is this OK and don't I need to worry?
I wanted a router/gateway in between to extend the range so the SP220. But what do I need to buy? I see router or gateway.
Don't understand the difference for this technology.
And what is the most simple (cheapest) solution. I just want to buy something. I read about a USB stick that I need to flash. All nice, but what to buy to do it with standard devices.
Zigate USB newbie bridge/router/gateway
keros
Re: Zigate USB newbie bridge/router/gateway
You have to have only one gateway : that is the ZiGate.
The router are all the objects connected to the power supply : bulbs, plugs, etc ... Just had one plug to your network and you have your router to extent your network.
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
ensingg
But I read somewhere that for a 'repeater'' function you need plug (not battery) powered device.
I will try to plug my other SP220 in between and see what happens.
keros
That's right. It is what I explained above.
In the plugin WebUI Dashboard, you have the numbers of routers and end devices. That way you can check if your device is a router or net.
