Following an SD card failure today i had to use a backup image to get up and running again.
Since this backup was done i have added many Zigbee devices using zigbee2mqtt.Lesson learned backup more often.
The one device that was on my system at the time is there and works fine. However when i go to add the new devices they do not get added to Domoticz.
My log shows them.
2021-07-04 18:12:58.431 Zigbee: (Zigbee) Received available devices list from bridge
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device E1603/E1702/E1708 0x000d6ffffebcd076 (Plug2)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device E1603/E1702/E1708 0x000d6ffffebcdf99 (Plug1)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device E1746 0x000d6ffffe9a88f5 (0x000d6ffffe9a88f5)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device E1603/E1702/E1708 0x000d6ffffebcc75d (0x000d6ffffebcc75d)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device E1603/E1702/E1708 0x000d6ffffefd51f8 (0x000d6ffffefd51f8)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device LED1624G9 0x000d6ffffe0e78ba (0x000d6ffffe0e78ba)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device E1603/E1702/E1708 0x000d6ffffebce69c (0x000d6ffffebce69c)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device HG06106C 0x842e14fffe15cdce (0x842e14fffe15cdce)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device GL-MC-001 0x00124b00213f3c55 (0x00124b00213f3c55)
2021-07-04 18:12:58.432 Zigbee: (Zigbee) Device HG06337 0x842e14fffecd0f32 (0x842e14fffecd0f32)
I have updated Zigbee2Mqtt to the latest version and no change.
I am missing something obvious i think so any advice welcome.
Thanks.
Devices not showing after using backup image.
Re: Devices not showing after using backup image.
Hi, Just an update.
It seems that the zigbee2mqtt update hadn't worked for some reason.
Re did it and i know have all but two devices up and running.
Follow up to this i never got all devices working properly.
I have asked on Github but getting nowhere fast.
I have posted logs up there at
https://github.com/Koenkk/zigbee2mqtt/discussions/8291
Has anyone got a clue as to what is going on, hoping someone has seen this before and can help me out.
