EnOcean D2-01-0C not handled
domoticzRaspUser
I'm not a new domoticz's user but it's the first time a device doesn't work.
I don't know how to do neither whom asking ...
Regards.
Version: 2021.1
Platform: Ubuntu 20.04.3 LTS, GNOME : 3.36.8
Plugin/Hardware: EnOcean USB (ESP3)
2021-08-30 17:04:06.397 Status: EnOcean: Worker started...
2021-08-30 17:04:06.601 Status: EnOcean: Using serial port: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AU03KVTY-if00-port0
2021-08-30 17:04:06.601 Status: EnOcean: EnOcean Send: 55 00 01 00 05 70 08 38
2021-08-30 17:04:06.601 Status: EnOcean: EnOcean Send: 55 00 01 00 05 70 03 09
2021-08-30 17:04:06.676 Status: EnOcean: 02 (05/01) 00 FF AC A7 80 0A
2021-08-30 17:04:06.676 Status: EnOcean: Transceiver ID_Base: 0xffffffffffaca780
2021-08-30 17:04:06.876 Status: EnOcean: 02 (21/00) 00 02 0F 00 00 02 06 09 00 05 1D 59 4F 45 4F 01 03 47 41 54 45 57 41 59 43 54 52 4C 00 00 00 00 00
2021-08-30 17:04:06.876 Status: EnOcean: Version_Info, App: 02.0f.00.00, API: 02.06.09.00, ChipID: 05.1d.59.4f, ChipVersion: 45.4f.01.03, Description: GATEWAYCTRL
Device : D2-01-0C
2021-08-30 17:09:19.435 EnOcean: destination: 0xffffffff RSSI: -68 dBm (6/11)
2021-08-30 17:09:19.435 EnOcean: teach-in request received from 04120EBE (manufacturer: 046). number of channels: 1, device profile: D2-01-0C
2021-08-30 17:09:19.436 EnOcean: Sender_ID 0x04120EBE inserted in the database
2021-08-30 17:09:19.435 Status: EnOcean: 01 (0D/07) D4 A0 01 46 00 0C 01 D2 04 12 0E BE 00 00 FF FF FF FF 44 00
2021-08-30 17:09:20.492 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:20.492 EnOcean: teach-in request received from 04120EBE (manufacturer: 046). number of channels: 1, device profile: D2-01-0C
2021-08-30 17:09:20.492 EnOcean: Sender_ID 0x04120EBE already in the database
2021-08-30 17:09:20.492 Status: EnOcean: 01 (0D/07) D4 A0 01 46 00 0C 01 D2 04 12 0E BE 00 00 FF FF FF FF 43 00
2021-08-30 17:09:21.548 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:21.548 EnOcean: teach-in request received from 04120EBE (manufacturer: 046). number of channels: 1, device profile: D2-01-0C
2021-08-30 17:09:21.548 EnOcean: Sender_ID 0x04120EBE already in the database
2021-08-30 17:09:21.548 Status: EnOcean: 01 (0D/07) D4 A0 01 46 00 0C 01 D2 04 12 0E BE 00 00 FF FF FF FF 43 00
2021-08-30 17:09:22.018 EnOcean: Lighting 2 ()
2021-08-30 17:09:22.154 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:22.154 EnOcean: Sender_ID 0xFFFFFFFFFFACA782 inserted in the database with default profile F6-02-01
2021-08-30 17:09:22.154 EnOcean: If your Enocean RPS device uses another profile, you must update its configuration.
2021-08-30 17:09:22.155 EnOcean: Lighting 2 (Unknown)
2021-08-30 17:09:22.354 EnOcean: destination: 0xffffffff RSSI: -67 dBm (6/11)
2021-08-30 17:09:22.355 EnOcean: Lighting 2 (Unknown)
2021-08-30 17:09:22.016 Status: User: Admin (IP: 192.168.1.9) initiated a switch command (1/Fil Pilotte/On)
2021-08-30 17:09:22.017 Status: EnOcean: EnOcean Send: 55 00 07 00 01 11 F6 10 FF AC A7 82 30 93
2021-08-30 17:09:22.017 Status: EnOcean: EnOcean Send: 55 00 07 00 01 11 F6 00 FF AC A7 82 20 7D
2021-08-30 17:09:22.154 Status: EnOcean: 02 (01/00) 00
2021-08-30 17:09:22.154 Status: EnOcean: 01 (07/07) F6 10 FF AC A7 82 31 00 FF FF FF FF 43 00
2021-08-30 17:09:22.354 Status: EnOcean: 02 (01/00) 00
2021-08-30 17:09:22.354 Status: EnOcean: 01 (07/07) F6 00 FF AC A7 82 21 00 FF FF FF FF 43 00
2021-08-30 17:11:22.823 EnOcean: Lighting 2 (Unknown)
2021-08-30 17:11:22.881 EnOcean: destination: 0xffffffff RSSI: -70 dBm (6/11)
2021-08-30 17:11:22.881 EnOcean: EnOcean message VLD: Profile: 01 Type: 0C
2021-08-30 17:11:22.881 EnOcean: EnOcean message VLD: func: 02 Type: 40
2021-08-30 17:11:22.881 EnOcean: Unhandled RORG (d2)
2021-08-30 17:11:22.881 EnOcean: Lighting 2 (Unknown)
Specification : http://tools.enocean-alliance.org/EEPVi ... -01-0C.pdf
Regards.
Version: 2021.1
Device : D2-01-0C
efdeb
- Domoticz version: dev
Re: EnOcean D2-01-0C not handled
Can you tell me what exactly is the device you are using and where to download its user manual from ?
domoticzRaspUser
this device is a heating module with pilotwire command and energy measurement.
Here is the vendor specification : http://tools.enocean-alliance.org/EEPVi ... -01-0C.pdf
efdeb
Currently, this EEP D2-01-0C is not managed by Domoticz. That means that you cannot receive device current status, nor energy/power measurement data.
But, it may be possible to control it using two dummy EnOcean switches with the same ID. At least this should work with Nodon SIN-2-FP-01 Pilot Wire module (https://nodon.fr/wp-content/uploads/202 ... igital.pdf).
That's the reason why I am asking for the brand / device type or user manual (not EEP specification) of yours.
For Nodon module, you can try this (I cannot because I do not own this module) :
Go to Switches, press Manual Light/switch, select your EnOcean controler, enter a name for your switch, select On/Off Switch Type, select EnOcean Type, choose an unused ID and Rocker ID 1.
Put your device in association mode (see user manual) and press test.
Press Manual Light/switch again, select exactly the same values except Rocker ID 2.
You should then be able to send commands to the device using these two switches for activating the following modes : Stop, No frost, Eco, Comfort.
I am currently working on EnOcean implementation and shall see if possible to improve support for this EEP.
domoticzRaspUser
Thank you for your answer.
If needed, I can test a development version.
- labelette91
hello,
EnOcean D2-01-0C device is now nativly implemented .
cdt
cdt
PierreOV
Hello efdeb and labelette91,
THANK YOU very much for your contribution to EnOCean support on Domoticz !
I currently have a Domoticz 2021.1 version running on a Pi3B+ with Raspian Buster (Bullseye being still bugged with Domoticz.
I have THREE active gateways:
1 RFLINK (433MHz) with many sensors
2 ZIGBEE (Zigate+) with about 20nodes and 3routers: working perfectly but NEED BATTERIES
3 EnOcean (USB300) with Door sensors (Nodon:working fine), 220V switches (Nodon)
What is not yet working in Enocean:
Temp sensor (Nofon): recognized, entered in the DB: but not able to get the TEMP data ?
Radiator Valves (Ubiwizz MICIT RV004): Domoticz see it but i cannot get data or command it, because it is not yet implemented
Those valves are great: equivalent to the Zigbee one but without battery.
I can perfeclty control the zigbee valves with zigate and would like to do the same with EnOcean and get rid of many.many batteries...
The Ubiwizz valve is in fact a: Micropelt MVA004 oem to Ubiwizz
http://www.micropelt.com/en.html
http://www.micropelt.com/en/products/how-to-use.html
http://www.micropelt.com/en/products/en ... va004.html
The EEP profile is A5-20-01
I really believe that many many people would love to use this wonderful product, once supported.
Could you help ?
Thanks a lot,
Pierre
Could you help ?
Thanks a lot,
Pierre
- 2021-12-13_my3gateways.pdf
- (76.77 KiB) Downloaded 54 times
PierreOV
The dashboard related to the radiator valves control
- 2021-12-13_Valves & Temp sensors.pdf
- (142.19 KiB) Downloaded 74 times
