Monit - Error receiving data -- Connection reset by peer ??
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
Installed Monit as per instructions in the wiki. But somehow I can not get it to work properly.
Running on a Pi 3 connected to a wired network. Installation is done using default settings.
This is my log:
[CEST Sep 30 15:14:02] info     : Starting Monit 5.20.0 daemon with http interface at [*]:2812
[CEST Sep 30 15:14:02] info     : Monit start delay set to 300s
[CEST Sep 30 15:19:02] info     : 'RPi3' Monit 5.20.0 started
[CEST Sep 30 15:19:04] error    : 'domoticz' failed protocol test [HTTP] at [127.0.0.1]:8080/json.htm?type=command¶m=getversion [TCP/IP] -- Connection refused
[CEST Sep 30 15:19:46] error    : Denied connection from non-authorized client [127.0.0.1]
[CEST Sep 30 15:19:46] error    : Error receiving data -- Connection reset by peer
These are my settings in the /etc/monit/monitrc (snipped to show only the information regarding Domoticz)
  set daemon 300            # check services at 2-minute intervals
   with start delay 300     # optional: delay the first check by 4-minutes (by
#                           # default Monit check immediately after Monit start)
(snip)
  set mailserver smtp.gmail.com port 587
  username "[email protected]" password "PASSWORD" (of course changed it to the correct values)
  using tlsv1
  without timeout 30 seconds
  set alert [email protected] (of course changed it to the correct values)
(snip)
  set httpd port 2812 and
      use address 0.0.0.0                     # only accept connection from localhost
      allow 0.0.0.0/0.0.0.0                   # allow localhost to connect to the server and
      allow admin: monit                      # require user 'admin' with password 'monit'
(snip)
  check process domoticz with pidfile /var/run/domoticz.pid
  start program = "/etc/init.d/domoticz.sh start"
  stop  program = "/etc/init.d/domoticz.sh stop"
  if failed
     url http://127.0.0.1:8080/json.htm?type=command&param=getversion
         and content = '"status" : "OK"'
     for 2 cycles
     then restart
  if 5 restarts within 5 cycles then exec "/sbin/reboot"
The web interface shows me "connection failed" for Domoticz.
Any help appreciated! :)
Greetz,
Sjonnie
Edit: These are the contents of the email I get from monit (so notification works ;) )
Connection failed Service domoticz
	Date:        Sat, 30 Sep 2017 15:29:06
	Action:      restart
	Host:        RPi3
	Description: failed protocol test [HTTP] at [127.0.0.1]:8080/json.htm?type=command&param=getversion [TCP/IP] -- Connection refused
Your faithful employee,
Monit
YouLess Energy meter
SweetPants
Re: Monit - Error receiving data -- Connection reset by peer ??
Post by SweetPants »
Is 127.0.0.1 in the list of IP's that can login without username/password Setup->Settings->Local networks?
Sjonnie2017
Tx for your reply! :)
This is what I have in Local Networks in the settings:
127.0.0.*;192.168.16.*
Thought that would be enough. Is it?
Greetz,
Sjonnie
SweetPants
Yes, should be enough. Can you post your monit config file?
Sjonnie2017
Tx for your continued support!
Is there another file than this one?
/etc/monit/monitrc
Because I showed the relevant contents of that file in my previous post. If you need the full contents I'll be happy to comply (need to anonimize it first though ;) )
If there is another config file please let me know.
Greetz,
Sjonnie
SweetPants
For every service i use a separate .conf file in /etc/monit/conf.d
For domoticz i only check the PID like:
start program "/etc/init.d/domoticz.sh start"
stop program "/etc/init.d/domoticz.sh stop"
Sjonnie2017
Removed the "if failed ..." condition and now monit is working.
Tx! Much appreciated!
Verstuurd vanaf mijn YOGA Tablet 2-1050F met Tapatalk
rolandtwilt
Post by rolandtwilt »
I have had the same problem as above (connection reset by peer) I did 2 things to fix it:
1. Replace this:
  if failed
     for 2 cycles
     then restart
With this:
and
2. this:
with:
      use address <address of pi>                     # only accept connection from localhost
      allow <local network range>/255.255.255.0                   # allow localhost to connect to the server and
Domoticz version: 2025.1
rolandtwilt wrote: Friday 10 September 2021 11:36 I have had the same problem as above (connection reset by peer) I did 2 things to fix it:
As described in section webservice of the wiki: https://www.domoticz.com/wiki/Monitoring_domoticz
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
Have you configured Domoticz on port 8080?
Are you running Domoticz in a docker container? In that case use the network ip-address of this server/raspberry. something like 192.168.x.x or 10.x.x.x
instead of 127.0.0.1.
