[SOLVED]Problem with HTML custom block
Diplo95
Domoticz version: 2021.1
Post by Diplo95 »
I'm a beginner with dashticz and I try to use an HTML custom block on my screen. I use the example of the wiki and try to retrieve the met of my location.
Here is the code from weatherwidget.io :
<a class="weatherwidget-io" href="https://forecast7.com/fr/48d542d66/melun/" data-label_1="Moissy-Cramayel" data-icons="Climacons Animated" data-mode="Current" data-theme="pure" >Moissy-Cramayel</a>
<script>
!function(d,s,id){var js,fjs=d.getElementsByTagName(s)[0];if(!d.getElementById(id)){js=d.createElement(s);js.id=id;js.src='https://weatherwidget.io/js/widget.min.js';fjs.parentNode.insertBefore(js,fjs);}}(document,'script','weatherwidget-io-js');
</script>
I created the file WeatherwidgetMelunCurrent.html in /home/pi/Dashticz/Program/custom
Then, I created my block :
blocks['weatherwidgetCurrent'] = {
    htmlfile: 'WeatherwidgetMelunCurrent.html',
	width: 6,
	title: 'Melun'
And finally, I put it in a column :
columns = {}
columns[1] = {}
columns[1]['blocks'] = ['weatherwidgetCurrent']
columns[1]['width'] = 6;
Here is the result :
Any idea where I go wrong ?
Thx
Domoticz v2021.1 on Raspberry Pi 3B+
Raspbian Buster
ConBee II + Xiaomi devices
Zwave
Lokonli
Re: Problem with HTML custom block
Post by Lokonli »
Diplo95 wrote: Friday 10 September 2021 10:26 Hi,
<script>
</script>
	width: 6,
	title: 'Melun'
columns = {}
columns[1] = {}
Thx
The htmlfile parameter is relative to the Dashticz custom folder ./custom
So your custom html file might be in the wrong location. (or is Program the name of your Dashticz folder?)
Naming is case sensitive. So you should check that as well.
Diplo95
Post by Diplo95 »
I used the automatic installation, and I don't remember the path I chose. But, as you can see, this is the folder containing my CONGIG.js and custom.css files.
Raspbian Buster
Zwave
Diplo95
Post by Diplo95 »
I found my stupid error :
I had defined the weatherwidget blocks before the line
blocks{}
in CONFIG.js !!!
Raspbian Buster
Zwave
