I recently bought an RFlink 868 gateway, so I could use my Visonic devices (868) within Domoticz. Today I soldered the connectors to the boards, uploaded the software and checked the debug log from the RFlink loader to see if some of the devices (MCT-302) were detected. When opening and closing the contact I saw data on the screen. So far so good, connected it to the RPi with Domoticz and added the hardware. Detected in the Domoticz log and even an init. Try to add the sensor with devices, but no luck. Although the Visonic devices are supported (?) by the RFlink, I can't configure them in Domotic.
Anyone tried this or had any luck with it? Suggestions?
Btw:the Visonic devices are not connected to a Powermax.
RFlink support Visonic 868 devices
- phoenixblue
Re: RFlink support Visonic 868 devices
As far I know are the visonic 868mhz sensors not yet supported by the RFLink.
When you check the debug screen you see the received signals but they are not decoded by the RFLink so you can not use them inside Domoticz.
Maybe there will be an support in the future.... I hope
Hi Phoenixblue,
The RFlink 868 certainly supports Visonic devices as of R45.
http://www.rflink.nl/blog2/devlist and look for the 868Mhz section.
Maybe one of the stuntteam member(s) can answer this question?
I bought the 868 kit with the "Aurel Tranceiver RTX MID 868.3 OOK" from nodo shop to receive Visonic 868 devices. I do receive a lot of information in domoticz from other devices (more than 100). These are either from neigbours or just random fuzz as I can not believe there are so many devices in the air. The devices also just appear once and than never again or in rara cases twice. I really would like to know what receiver is used to receive Visonic devices by the person that got it up and running. I did asked the stuntteam if they could bring me in contact with that person.
You must have a 868.95 Mhz module to get it to work with Visonic.
I ripped the rx-board out of my old Powermax+ and soldered it on the card instead of the Aurel.
Works just fine.
Because there are separate bords for rx and tx in the Powermax+ I'm now only able to receive with RFlink, but it doesn't support tx to Visonic devices anyway.
Works just fine.
- phoenixblue
Do you have for me an photo of the used module?fridde wrote:You must have a 868.95 Mhz module to get it to work with Visonic.
Works just fine.
At this moment (Strange enough) some of the sensors I can receive with the default rflink module and some of them not (door contact)
My visonic is still in full working order so I desided for a different solution to get the sensors in Domoticz. I used the Visonic Mysensors sulution and I have all my PIR en door sensors in Domoticz. I can also turn on or off the alarm and can see if the alarm was tuned on or off and. In case of an alarm I get that in Dommoticz as well. The only thing not working is the flood sensor... But that is minor issue.
Hi,fridde wrote: ↑Tuesday 07 January 2020 1:09 You must have a 868.95 Mhz module to get it to work with Visonic.
Works just fine.
As @phoenixblue mentioned too, i would like to hear that. I've a old Powermax laying around, and i would like to use the 868 module from that device. However, there's many pins, and i'm unsure, if i can use it, or not?
- Domoticz version: 2020.2
Hi, what is the status of this?
I have an AlphaHome alarm (no codes) with Visionic sensors.
Will this aso work for my case?
