Call other LUA as subroutine?
manjh
Post by manjh »
It would be great if I could call another LUA script as a subroutine somehow. This would allow coding of frequently used logic on one place, and use it in many places.
The only way I can see how to do this, is to write a LUA script and store it on disk or SD card, and call that from the LUA script.
One disadvantage is the fact that I cannot write and update from the normal user interface, but have to go in (e,g, Putty) and use a local editor in the R-Pi.
Another disadvantage is the way I can back this code up: it is not included in the normal backup from the Domoticz settings tab, but has to be done separately.
Am I missing a more simple way?
Hans
Varazir
Re: Call other LUA as subroutine?
Post by Varazir »
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
manjh
Post by manjh »
Varazir wrote: Tuesday 07 September 2021 20:44 You can use the global_data file to create you own helper functions
https://www.domoticz.com/wiki/DzVents:_ ... _scripting
https://www.domoticz.com/wiki/DzVents:_ ... _functions
I see how this works, but it still has the disadvantage that the code is not included in the Domoticz backup...
Hans
Varazir
Post by Varazir »
manjh wrote: Wednesday 08 September 2021 16:19
Yes it is. It's stored in the DB as far as I understand.
erem
Domoticz version: 2021.1
Post by erem »
only if you use the internal events editor. then the script are stored in domoticz.db
from the wiki: Note: there can be only one global_data.lua on your system. Either in /path/to/domoticz/scripts/dzVents/script or in Domoticz’ internal GUI web editor.
if you put global_data.lua in /path/to/domoticz/scripts/dzVents/script, it is your responsibility to back it up.
Regards,
Rob
Varazir
Post by Varazir »
erem wrote: Wednesday 08 September 2021 16:52
fromthe wiki: Note: there can be only one global_data.lua on your system. Either in /path/to/domoticz/scripts/dzVents/script or in Domoticz’ internal GUI web editor.
Ahh okay, I only use the internal editor.
manjh
Post by manjh »
This method only works for dzVents, right?
Hans
EddyG
Post by EddyG »
If you want to automatically backup ALL Domoticz files you could use rsnapshot. I use it for years now to backup to an USB-stick, and it works perfect.
Then global_data.lua is also included.
