Wanting to jump in to smarting out my home and thinking of doing it with Domoticz. Even though that Pi4 has been released for a while now I can’t seem to find any pros for it, but I do read some (minor?) cons. It’s hard getting a Pi3B+ around here, all in backorder, so I’m thinking of going with the Raspberry Pi4.
It has better hardware but I don’t think Domoticz is in need of that. The thing I keep reading is that it is not yet possible to boot from SSD.
What are your thoughts on the Pi 4, and its pros and cons for Domoticz?https://omegle.onl/ vshare
Raspberry Pi4 compatibility with Domoticz?
- Treve
- Domoticz version: v4.11474
Re: Raspberry Pi4 compatibility with Domoticz?
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
- Domoticz version: Stable
RPI4 has been bootable from USB-SSD for about a year now, here is just one of many links you will find if you google it.
https://jamesachambers.com/new-raspberr ... oot-guide/
- HansOtten
- Domoticz version: 2021-1
Domoticz runs fine on a Raspberry Pi 4 booting from SSD. A new Pi4 will boot without even needing a SD, image the SSD wit the Raspberry Pi Imager.
Make sure you have a USB controller with the ASMEDIA IC. https://thepihut.com/products/retroflag ... -enclosure e.g. (alas the cheaper one at Pihut is sold out)
You will like the speed and have enough disk space for growth.
Very stable also. Only reboot when you update or add something.
Raspberry Pi 4, SSD, RFlink, P1 Smart Meter. Many Zigbee devices CR2562 USB stick. Bresser via Weather Underground
Switched to Home Assistant!
