Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee) Topic is solved
Thorgal789
Re: Python Zigbee plugin, deCONZ bridge (Using Conbee or Raspbee)
Post by Thorgal789 »
If you can see it in the API (so in phoscon and the custom panel), you need to see it too in domoticz.
You haven't disabled the new device addition in the option "Accept new Hardware Devices" ?
Else you can see new device in the "devices" tab.
If you enable logs "debug info only", and restart the plugin hardware/deconz/update, you can see some information that can help you.
Patricen
Domoticz version: Beta rel
Post by Patricen »
Thorgal789 wrote: Thursday 05 August 2021 19:34 If you can see it in the API (so in phoscon and the custom panel), you need to see it too in domoticz.
Thanks for the input.
I finally figured out that I was using a sensor that had already been registered within Domoticz, it was already in the devices list under another name :)
Thorgal789
Hello, just a comment about the new version (somes days ago).
Siren have now a new widget, the old one was a on/off one the new one is a selector with more command. To enable the new one, just delete the actual device in domoticz and restart the plugin > hardware/deconz/update.
If I m right both version are still compatible, but haven't tested on my side, so can explain if you have issue with sirens.
And the front end to config device is repaired again.
veitk
Post by veitk »
Hi, i'm trying to get my Ikea Styrbar set up with domoticz so that i can use all of its functions including long press.
I'm seeing the nValues / sValues which doesn't seem to be usefull in case of longpress.
deCONZ is sending button events which are described here: https://dresden-elektronik.github.io/de ... on_events/
and i can see them in the domoticz log just fine, a long press always starts with a 1 at the end and finishes with a 3 (eg 2001 .... 2003) - a short click is always with a 2 in the end.
but i don't know how i can get the value "buttonevent" in a domoticz script.
after reading a lot here i don't understand how you are doing this. any help appreciated - thx in advance!
(i switched to beta branch as well ... and an also very interesting post was this one, but i don't fully understand the solution: viewtopic.php?p=253983#p253983)
Domoticz version: 2025.1
veitk wrote: Friday 26 November 2021 11:47 but i don't know how i can get the value "buttonevent" in a domoticz script.
Can you post a screenshot of the edit screen of the domoticz device showing all selector levels (10,20 30 etc).
in dzVents you can use something like
if domoticz.devices('Ikea Styrbar').levelname == 'long click' then
--- do something
.levelname is case sensitive!
.level can also be used, then it are the corresponding level numbers (eg 10, 20 30 etc)
For far more info on dzVents look here: https://www.domoticz.com/wiki/DzVents:_ ... or_etc..29
veitk
Post by veitk »
so the thing is i added the level values by myself to the switch and for that part it is working.
could that be automatically generated somehow?
but even without setting the level numbers to names i have a problem, i took the values out of the domoticz log:
up short click -> 10
down short click -> 20 .... and so on, left 30, right 40 ...
BUT !!!
if i press up LONG click then it also sends 20 and down long sends 40, so i can't differentiate between right short and down long.
this problem can be reproduced with other zigbee switches as well.
the values in the logs from deconz contain the value "buttonevent" which solve this problem.
2021-11-26 15:23:24.647 deCONZ plugin: onMessage called
2021-11-26 15:23:24.648 deCONZ plugin: ### WebSocket Data : {'attr': {'id': '8', 'lastannounced': None, 'lastseen': '2021-11-26T14:23Z', 'manufacturername': 'IKEA of Sweden', 'modelid': 'Remote Control N2', 'name': 'Styrbar die eine', 'swversion': '1.0.024', 'type': 'ZHASwitch', 'uniqueid': '84:fd:27:ff:fe:07:75:ff-01-1000'}, 'e': 'changed', 'id': '8', 'r': 'sensors', 't': 'event', 'uniqueid': '84:fd:27:ff:fe:07:75:ff-01-1000'}
2021-11-26 15:23:24.648 deCONZ plugin: onMessage called
2021-11-26 15:23:24.648 deCONZ plugin: ### WebSocket Data : {'e': 'changed', 'id': '8', 'r': 'sensors', 'state': {'buttonevent': 4002, 'lastupdated': '2021-11-26T14:23:24.631'}, 't': 'event', 'uniqueid': '84:fd:27:ff:fe:07:75:ff-01-1000'}
2021-11-26 15:23:24.649 deCONZ plugin: ### Update device (Styrbar die eine) : {'nValue': 40, 'sValue': '40'}
i will add .levelname to the log and see if this could work
I do not understand. Do you mean that when you do a long click that would send level 40 it would also first send 20 (being the short click)?
Because that would be a failure in the Ikea device. Else you have to wait for a "maybe to come" long click if you get a short click.
That is of course also possible but how long to wait?
veitk
Post by veitk »
it doesn't send the short click if i do a long click. it sends a nValue 0 (with sValue Off) and then the 40 after i let go.
i have 3 of them - all behaving the same way.
i paired one with a zigbee led panel through phoscon and everything works there, i can short click for on/off and long click for dim.
and: the log from deconz shows the values for buttonevents which are perfect, but i don't know how to reach this value through dzevents or lua
veitk
Post by veitk »
UPDATE:
after switching to beta, deleting the device and adding it new i now have generated levels from 10 to 90. i will check if this fixed my problem.
Ah good. I do not think it has anything to do with beta Domoticz but OK.
Check the log file of the button device in domoticz (click on log button of device, not the main log). There you see the list of selected button levels you have pressed.
In dzVents you can get the current level with the .level or .levelname
veitk
Post by veitk »
i was talking about the beta from the deconz plugin.
so the levels are named B1 to B9 (from 10 to 90) - but it stays about the same, in the device log: with a long down press i get a B4 after i release the button, and i get the same after a short click.
and yes i can get that levelname in dzvents and react to it.
maybe i'll take a look in the plugin-source code ... thanks so far walter!
Thorgal789
Yep, can be my fault.
On the plugin there is a generic fonction to manage switches, and it s something not reliable, because there is so much combinaison possible according to model.
So there is too special part for some device
                  Type = 'Tradfri_on/off_switch'
                elif 'lumi.remote.b186acn01' in Model:
                    Type = 'Xiaomi_single_gang'
                elif Model.startswith('lumi.remote.b286acn0'):
                    Type = 'Xiaomi_double_gang'
                #Used for all opple switches
                elif Model.endswith('86opcn01'):
                    Type = 'Xiaomi_Opple_6_button_switch'
                #Used for all tuya switch
                elif Model.startswith('TS004'):
                    Type = 'Tuya_button_switch'
                #Used by philips remote
                elif Model == 'RWL021':
                    Type = 'Philips_button_switch'
                else:
                    Type = 'Switch_Generic'
If your device have different value on log X00Y, but same value on domoticz 1>100, it s possible to add a specific code for it in the plugin.
I just need the value visible on log you need (not all are usefull) and the device model id.
veitk
Post by veitk »
okay great - i will contact you on your github repository for the plugin.
update: yes since it is a different model name it will not jump to the right function. i will send you the details or make a pr.
Sjonnie2017
Domoticz version: Latest ß
Post by Sjonnie2017 »
I am lost! I placed a new router today and now Domoticz can't connect to DeCONZ anymore. I can still operate all devices from deconz. This is the screen I am looking at:
I see this in the log:
2021-11-28 18:51:33.086 Error: ConBee2: (ConBee2) Connection problem (3) with Gateway, check your API key, or Use Request lib > V2.4.2
For the life of me I do not know how to correct this.
I tried to get a new API key but I couldn't make that work :(
PS. The PI is up to date
YouLess Energy meter
Thorgal789
You can use this url to find your IP https://phoscon.de/discover need to use internalipaddress on setting. So for you need to work with 192.168.16.165.
If you use the same url with the same inernal port 8080, in a browser you need to see phoscon.
Deconz and domoticz aren't on the same machine ? If they are on the same mchine better to use 127.0.0.1 as IP.
If they are on different machine, you need too 'authenticate app' when making the API key, but if you don't do that, you are not able to have an api key, so don't think it s the problem.
If you have just added a router, without touching to domoticz or deconz, I think it have modified ip adress on your network. Try the url on a browser (192.168.16.165:8080) , you can perhaps have information about the problem.
Sjonnie2017
Tx, Thorgal. It seems the new setup changed the port number somehow. Or maybe I did it. However when I change the plugin settings from port 8090 (as it was) to 8080 all seems to be working again. Tx again for your support!
Patricen
Post by Patricen »
Just hassled with a Tradfri light bulb I finally associated with Phoscon, works Ok with Phoscon, appears in "Custom ==> DeCONZ" control panel within Domoticz, but does not appears within devices (accept new hardware devices checked! ;) ).
Log displays :
2021-12-05 14:05:48.159 Error: Zigbee Deconz: (Zigbee Deconz) Can't Update Unit > 18 (lights) : {'nValue': 1, 'sValue': '99', 'Color': '{"m":2,"r":0,"g":0,"b":0,"t":199,"ww":199,"cw":56}'}
Does anybody have an idea about this issue?
Sjonnie2017
Remove device and re-add to Domoticz. Sometimes that helps. Do not remove from deCONZ/Phoscon
Patricen
Post by Patricen »
Sjonnie2017 wrote: Sunday 05 December 2021 17:42 Remove device and re-add to Domoticz. Sometimes that helps. Do not remove from deCONZ/Phoscon
Thanks!!!
Ughh I forgot resetting Deconz plugin, now it works!
Thorgal789
Or you can just wait.
This error message is normal, it just mean you have received a request for a device not present in domoticz (a new one), but just after the plugin ask for information about the new device to add it.
Having this message one time is normal, in loop mode no.
