Devices in dashboard
harrykausl
Domoticz version: 2021.1
Post by harrykausl »
For heating I‘m using Z-wave thermostats.Each thermostat has a device for the wanted temperature and one for the measured temperature. I also have some switches for the heating regulation. I put all these devices on the dashboard and in a room heating. When I switch to the dasboard and select the heating room, I see the devices. But if I want to change the wanted temperature, this is not possible in the dashboard. I have to switch to the menue for counters. Would it be possible to change the dashboard, that all devices have the full functionality?
Domoticz version: 2025.1
Re: Devices in dashboard
I am on holiday but I am pretty sure you can set the thermostat setpoint from the dashboard.
What version of Domoticz are you running?
Do you use another theme other than default?
Did you clear your cache?
harrykausl
I am on current release and have no spezial themes. The cache was also cleared several times. You only see the current temperature and can see the protocol of this device. But you can‘t change anything.
