Hello everybody,
I am trying to build a DZVents script that will activate my watering system. I'd like to be able to calculate the total rain for the past x days and then determine the watering needs based on that.
Is it possible to return the total value of a counter (or rain meter) for the past x days ?
cheers,
Claude
Total count for past x days
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
- Domoticz version: 2024.7
Re: Total count for past x days
In the following topic lots of examples how to extract data out of in this case energy counters (gas and electricity). Should be adaptable for rain counters. https://domoticz.com/forum/viewtopic.ph ... 4&start=20
Hi, thank you very much for link. I have successfully modified the script to calculate the total rain for the past 7 days, which is then stored in a dz variable.
I use this value to control how much water I supply to my young trees. I am not sure how effective it is but the trees are looking healthy
local scriptVar = 'Rain this week'
return
on =
timer =
'every 15 minutes',
httpResponses =
scriptVar .. '*',
logging =
level = domoticz.LOG_DEBUG,
marker = scriptVar,
data =
Rain =
initial = {},
execute = function(dz, item)
-- ***** Your settings below this line
local Rain = dz.devices('Rain') -- change to name of your RainMeter between quotes or id without quotes
local AverageRain = dz.variables('AverageRain') -- change to name of Rain variable
-- ***** No changes required below this line
local function getGraphData(period, id)
if period == nil then period = 'year' end
if id == nil then id = Rain.id end
url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=rain&range=' .. period .. '&idx=' .. id
dz.openURL({ url = url, callback = scriptVar .. '_' .. period })
local function processJSON(t)
local weekVolume = 0, 0, 0
local day = 86400 -- (24 * 60 * 60)
local startDay = os.date("%Y-%m-%d",os.time()-(7*day)) --Past 7 days
for index, Rain in ipairs(t) do
if Rain.d:match(dz.time.year) then
if Rain.d >= startDay then -- will sum everything which is on or after startofWeek
weekVolume = weekVolume + Rain.mm
AverageRain.set(weekVolume)
-- main
if item.isHTTPResponse and item.isJSON then
processJSON(item.json.result)
elseif item.isTimer or item.isDevice then
getGraphData()
dz.log('Error while retrieving Rain data. Result is ' .. item.statusText ..' ; Response is: ' .. item.data,LOG_ERROR)
