I have a problem checking the correct execution of the commands sent by domoticz to Tasmota.
In addition to my zwave devices, I added 2 sonoff s26 plug, flashed with Tasmota, to test. Everything works perfectly, with Mqtt only.
My dummy switch controls the plug well, and when I press the button on the plug, I have the status feedback on my dummy switch on the domoticz side.
BUT... When I unplug the plug to simulate a fault, and I activate my dummy switch to change the state of the relay, I have no error on the domoticz side, like the zwave switch that becomes red when the connection is lost.
Do you have a solution to get that kind of feedback on my dummy switch? Bexause without using Sonoff is not really reliable...
Thanks for your help!
Jimmy
Tasmota + Mqtt Get the confirmation of a command
Jimmy06
- Domoticz version: 2021.1
Synology 1010+ & DS216+ & DS720+ / PI 3 & Domoticz 2021.1 / RFPlayer / ZStick gen5 / Tasmota / Espeasy
- Domoticz version: 2025.1
Re: Tasmota + Mqtt Get the confirmation of a command
Do you use the Tasmota mqtt discovery plugin?
https://github.com/emontnemery/domoticz_mqtt_discovery
As the plugin could get some status back I believe (but not sure as i do not have Tasmota devices)
There is also a Tasmoticz plugin but that seems to be less powerfull. https://github.com/joba-1/Tasmoticz
Jimmy06
Thank you Waltervl, I am going to check that. I did not use any plugin.
I have only Espeasy devices on my esp. I flashed Tasmota on my sonoff to get a try...
Jimmy06
It works perfectly!waltervl wrote: Monday 12 July 2021 12:12 Do you use the Tasmota mqtt discovery plugin?
It's so easy... when you know how to do!
Thank you very much
You're welcome
