Parkside Smart Watering Timer
Lidl sells a zigbee Parkside Smart Watering Timer in Holland now € 29,99. Has somebody got it working with Domoticz?
- Domoticz version: 2024.7
Re: Parkside Smart Watering Timer
It is still work in progress on Zigbee2MQTT and Deconz see for example: https://github.com/Koenkk/zigbee2mqtt/issues/7695
Zigate I have no idea
For Zigate, we need to have a tester with the product. From what I see this is based on a Tuya specific cluster (not Zigbee standard), which would need some decoding/integration .waltervl wrote: ↑Wednesday 23 June 2021 11:09 It is still work in progress on Zigbee2MQTT and Deconz see for example: https://github.com/Koenkk/zigbee2mqtt/issues/7695
Wiki is available here.
Zigbee for Domoticz FAQ
They are still struggling overthere to get some connection. It is not hopefull. An other group working on it https://github.com/dresden-elektronik/d ... ssues/4958
Hi,pipiche wrote: ↑Wednesday 23 June 2021 13:00For Zigate, we need to have a tester with the product. From what I see this is based on a Tuya specific cluster (not Zigbee standard), which would need some decoding/integration .waltervl wrote: ↑Wednesday 23 June 2021 11:09 It is still work in progress on Zigbee2MQTT and Deconz see for example: https://github.com/Koenkk/zigbee2mqtt/issues/7695
I bought one today, and also use zigate. I can help you if you tell me what information you need.
Best regards
Before pairing enable some debug parameters out of WebUi -> Tools -> Debug (Advanced)physiker123 wrote: ↑Thursday 08 July 2021 11:43Hi,pipiche wrote: ↑Wednesday 23 June 2021 13:00For Zigate, we need to have a tester with the product. From what I see this is based on a Tuya specific cluster (not Zigbee standard), which would need some decoding/integration .waltervl wrote: ↑Wednesday 23 June 2021 11:09 It is still work in progress on Zigbee2MQTT and Deconz see for example: https://github.com/Koenkk/zigbee2mqtt/issues/7695
Best regards
- debugPairing
- debugTuya
- debugInRawAPS
The logs will be combined with Domoticz logs so it might be good that you are able to get the Domoticz logs in a file or via journalctl
If you can send me the logs of the pairing that would be great
then it would be great if you could provide me the export.json from WebUI->Tools-> Plugin Raw Devices (Json)
You can also reach me on keybase.io https://keybase.io/pipiche/chat
After updating my firmware and deleting the conf/Certified/Tuya/TS0601* files, I reincluded the device, an on/off-Switch is created and I am able to control the valve via domoticz. Just when I control it with the button, domoticz does not recognize it. So far so good!
have added my parkside water valve to zigbee2mqtt. domoticz plugin 3.1 beta, the valve is recognized by domoticz, adding devices is on while pairing but no devices are created. any suggestions?
delete the parkside and the two not working devices, removed the parkside from the zigbee configuration file, and finaly paired again. now we have 4 usefull devices in domoticz
Not sure, but are you using zigbee2mqtt or Zigbee for Domoticz ?
