deCONZ in combination with master/slave Domoticz
najtram
Domoticz version: v4.9700
Post by najtram »
Somehow I can’t share my deCONZ (ConBee II) devices to my master Domoticz. I can share other devices so it’s setup ok.
Any help appriciated.
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
Thorgal789
Re: deCONZ in combination with master/slave Domoticz
Post by Thorgal789 »
Can you explain me what you are making ? I dont use master/slave feature, and idk if it s the "sensor setting" or if you have 2 domoticz running.
Domoticz version: 2024.7
Master/Slave is not working with Python plugin managed devices. There are already some issues in GitHub on this issue eg https://github.com/domoticz/domoticz/issues/2484
najtram
Post by najtram »
Thanks Walter for your issues link. This is exactly the problem.
If I'm understanding correctly gizmocuz added it at June '18. → So my conclusion is to aim for a workaround.
I connect the master with the slave now with dummy switches on the one side and json/url commands in the on/off of the dummy's.
This work around only works "fine" for on/off state. Not for temperature etc.
ZigBee → ConBee II
LAN → Enphase Envoy
najtram wrote: Monday 05 July 2021 13:53
You could use dzVents or lua scripts for that. If master temp changes, send it to slave with http json/url commands
Edit: See for example viewtopic.php?t=31618
