backupdatabase.php results in Unauthorized
Hi everybody,
For months I was using /usr/bin/curl -s http://localhost:8080/backupdatabase.php to get the domoticz database to load it into a small datawarehouse.
But since a few weeks, the php script is returning 401 Unauthorized.
In Domoticz, I have set my subnet (192.168.178.*) as lokal network to avoid logging in.
But the script also fails from my raspberry itself.
Is the script still supported? Or should I set something else?
Maarten
Maarten
- Domoticz version: 2024.7
Re: backupdatabase.php results in Unauthorized
On what version of Domoticz are you?
You should also add 127.0.0.* to the access list in Setup - Settings to be sure when accessing from localhost.
I am using 2021.1 as version.
Already tried to add 127.0.0.1 but that did not work.
Local command: /usr/bin/curl -s http://localhost:8080/backupdatabase.php > domoticz.backup
results in a domoticz.backup file containing
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
- erem
- Domoticz version: 2021.1
which user runs domoticz?
which user rus the curl command?
does work?
does
sudo /usr/bin/curl -s http://localhost:8080/backupdatabase.php > domoticz.backup
Regards,
Rob
Rob
- TomTom
Hi, have the same issue with a returning http 401.
running with sudo does not solve the issue for me.
Any ideas how to solve this?
Thanks and regards, Tom
Trying to run it via localhost entry and with the local ip address in curl parameters, with the pi and sudo user, as well as domoticz user and password in curl parameters - for all combinations always receiving a http 401.erem wrote: ↑Monday 28 June 2021 11:52 ...
doeswork?Code: Select all
Install sqlite3 and do
Of course set the appropriate variables before the command. I backup directly to my NAS every 5 minutes
It is much more efficient and runs faster (approx. 30 Mb in less then 1.5 seconds).
/usr/bin/sqlite3 $SOURCEPATH$SOURCEFILE ".backup $MOUNTPOINT/$BACKUPFILE"
For me this command works perfectly.erem wrote: ↑Monday 28 June 2021 11:52 which user runs domoticz?
I see in the source that you have to be an admin user in Domoticz for this to work. Could that be the problem?
Try using it without the '> domoticz.db' If you skip that part the database backup.db will created in /tmp/backup.db in Linux and userdatafolder/backup.db in Windows
- sincze
- Domoticz version: 2024.4
Mmm interesting.
Domoticz Version: 2023.1 it does give me the DB as a backup
Domoticz Version: 2024.4 gives me 0 bytes
Response Code is
So that does not seem to be unauthorized.
Via the Domoticz Web Interface -> Settings > Backup and Restore -> Backup I also receive 0 bytes in the download.
sudo /usr/bin/curl -v -s http://domo_ip:domo_port/backupdatabase.php > file2.db
Response Code is
HTTP/1.1 200 OK
[31/Mar/2024:11:12:43.561 +0200] "GET /backupdatabase.php HTTP/1.1" 200 0 - "curl/7.74.0"
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
2024.4 gives me normal size backup when doing it through menu Settings > Backup and Restore -> Backup.
So it seems something is wrong in your setup.
- sincze
Hehe probably. But with debug logging on and no errors... hard to find out.
What does the PHP command do?
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
It is some kind of symbolic link into the Domoticz executable that makes a backup.....
Indeed it has nothing to do with php
In this script I use an alternative methode: https://www.domoticz.com/forum/viewtopi ... te#p306625
If you install sqlite3 then this command is much faster and can run outside of Domoticz when ever you want.
The sqlite3 .backup command is made for that.
- sincze
Mm interesting indeed. tried it with running Domoticz but received:Kedi wrote: ↑Monday 01 April 2024 13:45 Indeed it has nothing to do with php
If you install sqlite3 then this command is much faster and can run outside of Domoticz when ever you want.The sqlite3 .backup command is made for that.Code: Select all
sudo sqlite3 /home/pi/domoticz/domoticz.db ".backup /mnt/home/backup/domoticzdb/domoticzups_20240402204245_167_.db"
Error: database is locked
Let me check on the DEMO machine.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
