make sure you adjust the line endings from Unix to windows format when copying files...Rfpower666 wrote: ↑Wednesday 09 June 2021 15:36 Thanks - But there is something going wrong when following this. I suspect is has to to with file structure between windows and raspbian..
Copying over those files causes plugin to stop working..
tried modifying the json files and file paths, but still doesnt help..
i am so close!! lol!
Move Zigate from Raspbian to windows
- erem
- Domoticz version: 2021.1
Re: Move Zigate from Raspbian to windows
Regards,
Rob
Rob
I am at my wits end.. I have reinstalled Domoticz on a new Windows server. Restored backup, Z-Wave works great.
I have updated to latest firmware on zigate USB, communication is OK.
Domoticz works fine - UNTIL i install zigate plugin. Domoticz then goes into an endless loop.
Hardware is added, ports configured - all is correct.
Zigate works fine on PI..
If i remove the plugin Domoticz works fine again..
I am about to give up and just get rid of zigbee all together..
Domoticz2021.1 (build 13321)
Dashboard
Switches
Scenes
Temperature
Utility
Setup
All
Status
Filter:
X
2021-06-13 13:20:40.808 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:20:40.824 Status: TCPServer: shared server started...
2021-06-13 13:20:40.824 Status: RxQueue: queue worker started...
2021-06-13 13:20:42.844 ZGI hardware started.
2021-06-13 13:20:42.844 Status: ZGI: (ZGI) Entering work loop.
2021-06-13 13:20:42.844 Status: ZGI: (ZGI) Started.
2021-06-13 13:20:42.844 Status: NotificationSystem: thread started...
2021-06-13 13:20:42.844 Status: EventSystem: reset all events...
2021-06-13 13:20:42.844 Status: EventSystem: reset all device statuses...
2021-06-13 13:20:42.953 Status: Python EventSystem: Initializing event module.
2021-06-13 13:20:42.953 Status: EventSystem: Started
2021-06-13 13:20:42.953 Status: EventSystem: Queue thread started...
2021-06-13 13:20:43.391 ZGI: (ZGI) ZiGate plugin started!
2021-06-13 13:20:43.391 ZGI: (ZGI) load PluginConf
2021-06-13 13:20:43.391 ZGI: (ZGI) Starting LoggingManagement thread
2021-06-13 13:20:43.391 ZGI: (ZGI) start_logging_thread
2021-06-13 13:20:43.391 ZGI: (ZGI) logging_thread - listening
2021-06-13 13:20:43.281 Status: PluginSystem: 1 plugins started.
2021-06-13 13:20:43.359 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-13 13:20:43.375 Status: ZGI: (ZGI) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) Log history not found, no error logged
2021-06-13 13:20:43.391 Status: ZGI: (ZGI) Zigate plugin stable5-5.1.003 started
2021-06-13 13:20:43.391 Status: Zstick: Starting...
2021-06-13 13:20:43.391 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:20:45.648 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 13:20:45.648 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 13:20:45.648 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 13:20:45.648 There is no nautical twilight in the space of 24 hours
2021-06-13 13:20:45.648 There is no astronomical twilight in the space of 24 hours
2021-06-13 13:20:45.726 Active notification Subsystems: email, fcm (2/13)
2021-06-13 13:20:45.757 Starting shared server on: :::9980
2021-06-13 13:20:45.601 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-13 13:20:45.601 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-13 13:20:45.601 Status: Startup Path: C:\Domoticz\
2021-06-13 13:20:45.726 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:20:45.726 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:20:45.757 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:20:45.757 Status: TCPServer: shared server started...
2021-06-13 13:20:45.757 Status: RxQueue: queue worker started...
2021-06-13 13:20:47.802 ZGI hardware started.
2021-06-13 13:20:47.802 Status: ZGI: (ZGI) Entering work loop.
2021-06-13 13:20:47.802 Status: ZGI: (ZGI) Started.
2021-06-13 13:20:47.802 Status: NotificationSystem: thread started...
2021-06-13 13:20:47.802 Status: EventSystem: reset all events...
2021-06-13 13:20:47.802 Status: EventSystem: reset all device statuses...
2021-06-13 13:20:48.198 ZGI: (ZGI) ZiGate plugin started!
2021-06-13 13:20:48.198 ZGI: (ZGI) load PluginConf
2021-06-13 13:20:48.198 ZGI: (ZGI) Starting LoggingManagement thread
2021-06-13 13:20:48.198 ZGI: (ZGI) start_logging_thread
2021-06-13 13:20:48.198 ZGI: (ZGI) logging_thread - listening
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) Log history not found, no error logged
2021-06-13 13:20:48.198 Status: ZGI: (ZGI) Zigate plugin stable5-5.1.003 started
2021-06-13 13:20:48.214 Status: PluginSystem: 1 plugins started.
2021-06-13 13:20:48.308 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-13 13:20:48.355 Status: Zstick: Starting...
2021-06-13 13:20:48.355 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:20:50.493 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 13:20:50.493 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 13:20:50.493 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 13:20:50.493 There is no nautical twilight in the space of 24 hours
2021-06-13 13:20:50.493 There is no astronomical twilight in the space of 24 hours
2021-06-13 13:20:50.571 Active notification Subsystems: email, fcm (2/13)
2021-06-13 13:20:50.618 Starting shared server on: :::9980
2021-06-13 13:20:50.461 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-13 13:20:50.461 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-13 13:20:50.461 Status: Startup Path: C:\Domoticz\
2021-06-13 13:20:50.571 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:20:50.586 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:20:50.602 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:20:50.618 Status: TCPServer: shared server started...
2021-06-13 13:20:50.618 Status: RxQueue: queue worker started...
2021-06-13 13:20:52.649 ZGI hardware started.
2021-06-13 13:20:52.649 Status: ZGI: (ZGI) Entering work loop.
2021-06-13 13:20:52.649 Status: ZGI: (ZGI) Started.
2021-06-13 13:20:52.649 Status: NotificationSystem: thread started...
2021-06-13 13:20:52.649 Status: EventSystem: reset all events...
2021-06-13 13:20:52.649 Status: EventSystem: reset all device statuses...
2021-06-13 13:20:52.759 Status: Python EventSystem: Initializing event module.
2021-06-13 13:20:52.759 Status: EventSystem: Started
2021-06-13 13:20:52.759 Status: EventSystem: Queue thread started...
2021-06-13 13:20:53.103 ZGI: (ZGI) ZiGate plugin started!
2021-06-13 13:20:53.103 ZGI: (ZGI) load PluginConf
2021-06-13 13:20:53.103 ZGI: (ZGI) Starting LoggingManagement thread
2021-06-13 13:20:53.103 ZGI: (ZGI) start_logging_thread
2021-06-13 13:20:53.103 ZGI: (ZGI) logging_thread - listening
2021-06-13 13:20:53.056 Status: PluginSystem: 1 plugins started.
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) Log history not found, no error logged
2021-06-13 13:20:53.103 Status: ZGI: (ZGI) Zigate plugin stable5-5.1.003 started
2021-06-13 13:20:53.165 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-13 13:20:53.212 Status: Zstick: Starting...
2021-06-13 13:20:53.212 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:20:55.345 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 13:20:55.345 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 13:20:55.345 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 13:20:55.345 There is no nautical twilight in the space of 24 hours
2021-06-13 13:20:55.345 There is no astronomical twilight in the space of 24 hours
2021-06-13 13:20:55.423 Active notification Subsystems: email, fcm (2/13)
2021-06-13 13:20:55.454 Starting shared server on: :::9980
2021-06-13 13:20:55.314 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-13 13:20:55.314 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-13 13:20:55.314 Status: Startup Path: C:\Domoticz\
2021-06-13 13:20:55.408 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:20:55.423 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:20:55.439 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:20:55.454 Status: TCPServer: shared server started...
2021-06-13 13:20:55.454 Status: RxQueue: queue worker started...
2021-06-13 13:20:57.488 ZGI hardware started.
2021-06-13 13:20:57.488 Status: ZGI: (ZGI) Entering work loop.
2021-06-13 13:20:57.488 Status: ZGI: (ZGI) Started.
2021-06-13 13:20:57.488 Status: NotificationSystem: thread started...
2021-06-13 13:20:57.488 Status: EventSystem: reset all events...
2021-06-13 13:20:57.488 Status: EventSystem: reset all device statuses...
2021-06-13 13:20:57.597 Status: Python EventSystem: Initializing event module.
2021-06-13 13:20:57.597 Status: EventSystem: Started
2021-06-13 13:20:57.597 Status: EventSystem: Queue thread started...
2021-06-13 13:20:57.878 Status: PluginSystem: 1 plugins started.
2021-06-13 13:20:58.128 ZGI: (ZGI) ZiGate plugin started!
2021-06-13 13:20:58.128 ZGI: (ZGI) load PluginConf
2021-06-13 13:20:58.128 ZGI: (ZGI) Starting LoggingManagement thread
2021-06-13 13:20:58.128 ZGI: (ZGI) start_logging_thread
2021-06-13 13:20:58.128 ZGI: (ZGI) logging_thread - listening
2021-06-13 13:20:58.003 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-13 13:20:58.066 Status: Zstick: Starting...
2021-06-13 13:20:58.066 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:20:58.113 Status: ZGI: (ZGI) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-13 13:20:58.128 Status: ZGI: (ZGI) Log history not found, no error logged
2021-06-13 13:20:58.144 Status: ZGI: (ZGI) Zigate plugin stable5-5.1.003 started
2021-06-13 13:21:00.590 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 13:21:00.591 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 13:21:00.591 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 13:21:00.591 There is no nautical twilight in the space of 24 hours
2021-06-13 13:21:00.591 There is no astronomical twilight in the space of 24 hours
2021-06-13 13:21:00.677 Active notification Subsystems: email, fcm (2/13)
2021-06-13 13:21:00.714 Starting shared server on: :::9980
2021-06-13 13:21:00.554 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-13 13:21:00.555 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-13 13:21:00.555 Status: Startup Path: C:\Domoticz\
2021-06-13 13:21:00.670 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:21:00.681 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:21:00.708 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:21:00.716 Status: TCPServer: shared server started...
2021-06-13 13:21:00.716 Status: RxQueue: queue worker started...
2021-06-13 13:21:02.756 ZGI hardware started.
2021-06-13 13:21:02.756 Status: ZGI: (ZGI) Entering work loop.
2021-06-13 13:21:02.756 Status: ZGI: (ZGI) Started.
2021-06-13 13:21:02.756 Status: NotificationSystem: thread started...
2021-06-13 13:21:02.756 Status: EventSystem: reset all events...
2021-06-13 13:21:02.756 Status: EventSystem: reset all device statuses...
2021-06-13 13:21:02.865 Status: Python EventSystem: Initializing event module.
2021-06-13 13:21:02.865 Status: EventSystem: Started
2021-06-13 13:21:02.865 Status: EventSystem: Queue thread started...
2021-06-13 13:21:03.287 ZGI: (ZGI) ZiGate plugin started!
2021-06-13 13:21:03.287 ZGI: (ZGI) load PluginConf
2021-06-13 13:21:03.287 ZGI: (ZGI) Starting LoggingManagement thread
2021-06-13 13:21:03.287 ZGI: (ZGI) start_logging_thread
2021-06-13 13:21:03.287 ZGI: (ZGI) logging_thread - listening
2021-06-13 13:21:03.131 Status: PluginSystem: 1 plugins started.
2021-06-13 13:21:03.272 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-13 13:21:03.272 Status: ZGI: (ZGI) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) Log history not found, no error logged
2021-06-13 13:21:03.287 Status: ZGI: (ZGI) Zigate plugin stable5-5.1.003 started
2021-06-13 13:21:03.303 Status: Zstick: Starting...
2021-06-13 13:21:03.303 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:21:05.522 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 13:21:05.522 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 13:21:05.522 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 13:21:05.522 There is no nautical twilight in the space of 24 hours
2021-06-13 13:21:05.522 There is no astronomical twilight in the space of 24 hours
2021-06-13 13:21:05.600 Active notification Subsystems: email, fcm (2/13)
2021-06-13 13:21:05.631 Starting shared server on: :::9980
2021-06-13 13:21:05.490 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-13 13:21:05.490 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-13 13:21:05.490 Status: Startup Path: C:\Domoticz\
2021-06-13 13:21:05.600 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:21:05.615 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:21:05.631 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:21:05.631 Status: TCPServer: shared server started...
2021-06-13 13:21:05.631 Status: RxQueue: queue worker started...
2021-06-13 13:21:07.660 ZGI hardware started.
2021-06-13 13:21:07.660 Status: ZGI: (ZGI) Entering work loop.
2021-06-13 13:21:07.660 Status: ZGI: (ZGI) Started.
2021-06-13 13:21:07.660 Status: NotificationSystem: thread started...
2021-06-13 13:21:07.660 Status: EventSystem: reset all events...
2021-06-13 13:21:07.660 Status: EventSystem: reset all device statuses...
2021-06-13 13:21:07.754 Status: Python EventSystem: Initializing event module.
2021-06-13 13:21:07.769 Status: EventSystem: Started
2021-06-13 13:21:07.769 Status: EventSystem: Queue thread started...
2021-06-13 13:21:08.097 ZGI: (ZGI) ZiGate plugin started!
2021-06-13 13:21:08.097 ZGI: (ZGI) load PluginConf
2021-06-13 13:21:08.097 ZGI: (ZGI) Starting LoggingManagement thread
2021-06-13 13:21:08.097 ZGI: (ZGI) start_logging_thread
2021-06-13 13:21:08.097 ZGI: (ZGI) logging_thread - listening
2021-06-13 13:21:08.066 Status: PluginSystem: 1 plugins started.
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) Log history not found, no error logged
2021-06-13 13:21:08.097 Status: ZGI: (ZGI) Zigate plugin stable5-5.1.003 started
2021-06-13 13:21:08.176 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-13 13:21:08.207 Status: Zstick: Starting...
2021-06-13 13:21:08.207 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:21:10.194 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 13:21:10.194 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 13:21:10.194 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 13:21:10.194 There is no nautical twilight in the space of 24 hours
2021-06-13 13:21:10.194 There is no astronomical twilight in the space of 24 hours
2021-06-13 13:21:10.288 Active notification Subsystems: email, fcm (2/13)
2021-06-13 13:21:10.319 Starting shared server on: :::9980
2021-06-13 13:21:10.163 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-13 13:21:10.163 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-13 13:21:10.163 Status: Startup Path: C:\Domoticz\
2021-06-13 13:21:10.272 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:21:10.288 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:21:10.319 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:21:10.319 Status: TCPServer: shared server started...
2021-06-13 13:21:10.319 Status: RxQueue: queue worker started...
2021-06-13 13:21:12.365 ZGI hardware started.
2021-06-13 13:21:12.834 ZGI: (ZGI) ZiGate plugin started!
2021-06-13 13:21:12.834 ZGI: (ZGI) load PluginConf
2021-06-13 13:21:12.834 ZGI: (ZGI) Starting LoggingManagement thread
2021-06-13 13:21:12.834 ZGI: (ZGI) start_logging_thread
2021-06-13 13:21:12.834 ZGI: (ZGI) logging_thread - listening
2021-06-13 13:21:12.365 Status: ZGI: (ZGI) Entering work loop.
2021-06-13 13:21:12.365 Status: ZGI: (ZGI) Started.
2021-06-13 13:21:12.365 Status: NotificationSystem: thread started...
2021-06-13 13:21:12.365 Status: EventSystem: reset all events...
2021-06-13 13:21:12.365 Status: EventSystem: reset all device statuses...
2021-06-13 13:21:12.490 Status: Python EventSystem: Initializing event module.
2021-06-13 13:21:12.490 Status: EventSystem: Started
2021-06-13 13:21:12.490 Status: EventSystem: Queue thread started...
2021-06-13 13:21:12.772 Status: PluginSystem: 1 plugins started.
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) Log history not found, no error logged
2021-06-13 13:21:12.834 Status: ZGI: (ZGI) Zigate plugin stable5-5.1.003 started
2021-06-13 13:21:12.881 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-13 13:21:12.912 Status: Zstick: Starting...
2021-06-13 13:21:12.912 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
© 2012-2021 Domoticz | WWW: Domoticz.com
Dashboard
Switches
Scenes
Temperature
Utility
Setup
All
Status
Filter:
X
Tried various Domitcz versions - beta and stable. Same result..
Here is latest stable without Zigate plugin - Working fine..
2021-06-13 13:33:25.294 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 13:33:25.294 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 13:33:25.294 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 13:33:25.294 There is no nautical twilight in the space of 24 hours
2021-06-13 13:33:25.294 There is no astronomical twilight in the space of 24 hours
2021-06-13 13:33:25.294 BuildManifest: Created directory C:\Domoticz\plugins\
2021-06-13 13:33:25.169 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-06-13 13:33:25.169 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-06-13 13:33:25.169 Status: Startup Path: C:\Domoticz\
2021-06-13 13:33:28.278 Active notification Subsystems: email, fcm (2/13)
2021-06-13 13:33:28.591 Starting shared server on: :::9980
2021-06-13 13:33:28.263 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:33:28.325 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:33:28.575 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:33:28.591 Status: TCPServer: shared server started...
2021-06-13 13:33:28.591 Status: RxQueue: queue worker started...
2021-06-13 13:33:30.669 Status: NotificationSystem: thread started...
2021-06-13 13:33:30.669 Status: EventSystem: reset all events...
2021-06-13 13:33:30.669 Status: EventSystem: reset all device statuses...
2021-06-13 13:33:31.028 Status: Python EventSystem: Initalizing event module.
2021-06-13 13:33:31.028 Status: EventSystem: Started
2021-06-13 13:33:31.028 Status: EventSystem: Queue thread started...
2021-06-13 13:33:31.184 Status: Zstick: OpenZWave: using config in: C:\Domoticz\Config/
2021-06-13 13:33:31.466 Status: Zstick: OpenZWave: Starting...
2021-06-13 13:33:31.466 Status: Zstick: OpenZWave: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:33:46.166 Status: Zstick: OpenZWave: A DNS Error Occurred
2021-06-13 13:33:46.166 Status: Zstick: OpenZWave: ManufacturerSpecificDB Ready
2021-06-13 13:33:46.411 Status: Zstick: OpenZWave: Driver Ready
2021-06-13 13:33:46.411 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 1 (0x01)
2021-06-13 13:33:46.411 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 7 (0x07)
2021-06-13 13:33:46.411 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 12 (0x0c)
2021-06-13 13:33:46.411 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 13 (0x0d)
2021-06-13 13:33:46.411 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 14 (0x0e)
2021-06-13 13:33:46.411 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 15 (0x0f)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 16 (0x10)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 17 (0x11)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 18 (0x12)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 19 (0x13)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 20 (0x14)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 21 (0x15)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 22 (0x16)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 24 (0x18)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 25 (0x19)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 26 (0x1a)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 27 (0x1b)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 28 (0x1c)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 29 (0x1d)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 30 (0x1e)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 31 (0x1f)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 32 (0x20)
2021-06-13 13:33:46.426 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 34 (0x22)
2021-06-13 13:33:46.442 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 35 (0x23)
2021-06-13 13:33:46.442 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 36 (0x24)
2021-06-13 13:33:46.442 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 37 (0x25)
2021-06-13 13:33:46.442 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 38 (0x26)
2021-06-13 13:33:46.442 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 40 (0x28)
2021-06-13 13:33:47.482 Status: Zstick: OpenZWave: A DNS Error Occurred
2021-06-13 13:33:49.598 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 7 (0x07)
2021-06-13 13:33:53.273 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 12 (0x0c)
2021-06-13 13:33:56.637 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 14 (0x0e)
2021-06-13 13:33:58.199 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 15 (0x0f)
2021-06-13 13:33:59.295 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 15 (0x0f)
2021-06-13 13:34:00.344 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 16 (0x10)
2021-06-13 13:34:14.605 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 17 (0x11)
2021-06-13 13:34:15.657 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 18 (0x12)
2021-06-13 13:34:16.702 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 18 (0x12)
2021-06-13 13:34:20.509 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 19 (0x13)
2021-06-13 13:34:21.559 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 20 (0x14)
2021-06-13 13:34:28.930 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 21 (0x15)
2021-06-13 13:34:30.071 Status: Zstick: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 22 (0x16)
As soon as I remove Zigate it all starts working fine..
2021-06-13 13:53:56.338 Starting shared server on: :::9980
2021-06-13 13:53:56.135 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-06-13 13:53:56.136 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-06-13 13:53:56.136 Status: Startup Path: C:\Domoticz\
2021-06-13 13:53:56.270 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 13:53:56.298 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 13:53:56.331 Status: WebServer(SSL) started on address: :: with port 443
2021-06-13 13:53:56.339 Status: TCPServer: shared server started...
2021-06-13 13:53:56.340 Status: RxQueue: queue worker started...
2021-06-13 13:53:56.749 Status: ZG: (ZG) Stop directive received.
2021-06-13 13:53:56.749 Status: ZG: (ZG) Stopping threads.
2021-06-13 13:53:56.749 Status: ZG: (ZG) Stopped.
2021-06-13 13:53:58.356 Status: NotificationSystem: thread started...
2021-06-13 13:53:58.356 Status: EventSystem: reset all events...
2021-06-13 13:53:58.356 Status: EventSystem: reset all device statuses...
2021-06-13 13:53:58.466 Status: Python EventSystem: Initalizing event module.
2021-06-13 13:53:58.466 Status: EventSystem: Started
2021-06-13 13:53:58.466 Status: EventSystem: Queue thread started...
2021-06-13 13:53:58.857 Status: Zstick: OpenZWave: using config in: C:\Domoticz\Config/
2021-06-13 13:53:58.915 Status: Zstick: OpenZWave: Starting...
2021-06-13 13:53:58.931 Status: Zstick: OpenZWave: Version: 1.6.1911.gc6a420ef.dirty
2021-06-13 13:54:00.786 Status: Zstick: OpenZWave: A DNS Error Occurred
2021-06-13 13:54:00.786 Status: Zstick: OpenZWave: ManufacturerSpecificDB Ready
2021-06-13 13:54:01.027 Status: Zstick: OpenZWave: Driver Ready
2021-06-13 13:54:01.029 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 7 (0x07)
2021-06-13 13:54:01.030 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 12 (0x0c)
2021-06-13 13:54:01.030 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 13 (0x0d)
2021-06-13 13:54:01.031 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 14 (0x0e)
2021-06-13 13:54:01.032 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 15 (0x0f)
2021-06-13 13:54:01.033 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 16 (0x10)
2021-06-13 13:54:01.034 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 17 (0x11)
2021-06-13 13:54:01.035 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 18 (0x12)
2021-06-13 13:54:01.036 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 19 (0x13)
2021-06-13 13:54:01.036 Status: Zstick: OpenZWave: New Node added. HomeID: 4119221429, NodeID: 20 (0x14)
- Domoticz version: 2024.7
Did you check the plugin settings (Menu Setup - Hardware)? There were some major changes from Zigate plugin v4 to v5.
You have to set Zigate device, USB device etc again. They could be empty. Fill in all empty Fields
Hi - Yeah. I have even removed it, cleared it, flashed it - re added it. Set all ports (usb, com and so on) - Same result.. As soon as i add the Zigate, Domoticz starts restarting and looping..
Specifically this happes the moment i add ZiGate in Domoticz:
2021-06-13 14:39:33.711 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-06-13 14:39:33.711 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-06-13 14:39:33.711 Status: Startup Path: C:\Domoticz\
2021-06-13 14:39:33.820 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 14:39:33.851 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 14:39:33.867 Status: WebServer(SSL) started on address: :: with port 9980
2021-06-13 14:39:33.882 Status: TCPServer: shared server started...
2021-06-13 14:39:33.882 Status: RxQueue: queue worker started...
2021-06-13 14:39:38.798 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 14:39:38.798 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 14:39:38.798 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 14:39:38.798 There is no nautical twilight in the space of 24 hours
2021-06-13 14:39:38.798 There is no astronomical twilight in the space of 24 hours
2021-06-13 14:39:38.845 Active notification Subsystems: email (1/13)
2021-06-13 14:39:38.860 Starting shared server on: :::9980
2021-06-13 14:39:38.767 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-06-13 14:39:38.767 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-06-13 14:39:38.767 Status: Startup Path: C:\Domoticz\
2021-06-13 14:39:38.845 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 14:39:38.845 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 14:39:38.860 Status: WebServer(SSL) started on address: :: with port 9980
2021-06-13 14:39:38.860 Status: TCPServer: shared server started...
2021-06-13 14:39:38.860 Status: RxQueue: queue worker started...
2021-06-13 14:39:43.902 Sunrise: 04:21:00 SunSet: 22:32:00
2021-06-13 14:39:43.903 Day length: 18:11:00 Sun at south: 13:27:00
2021-06-13 14:39:43.903 Civil twilight start: 03:05:00 Civil twilight end: 23:49:00
2021-06-13 14:39:43.903 There is no nautical twilight in the space of 24 hours
2021-06-13 14:39:43.903 There is no astronomical twilight in the space of 24 hours
2021-06-13 14:39:43.987 Active notification Subsystems: email (1/13)
2021-06-13 14:39:43.859 Status: Domoticz V2021.1 (c)2012-2021 GizMoCuz
2021-06-13 14:39:43.860 Status: Build Hash: 8547c5b7e, Date: 2021-04-17 17:29:11
2021-06-13 14:39:43.860 Status: Startup Path: C:\Domoticz\
2021-06-13 14:39:43.972 Status: PluginSystem: Started, Python version '3.9.5'.
2021-06-13 14:39:43.991 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-13 14:39:44.022 Starting shared server on: :::9980
2021-06-13 14:39:44.014 Status: WebServer(SSL) started on address: :: with port 9980
2021-06-13 14:39:44.022 Status: TCPServer: shared server started...
2021-06-13 14:39:44.023 Status: RxQueue: queue worker started...
Python is known to be not always as compatible between Linux and Windows OS. So perhaps you have an issue here. I think the Zigate Plugin is only tested on Linux machines.
I have at least tried several different python versions.. Same results either way.. :/
Have you tried a fresh install of the ZiGate without restoring the ZiGate data ?
Moderator on Easydomoticz.com, the French DomoticZ forum.
French writer for ZigBeeForDomoticZ Plugin Wiki
In the end I bit the bullet. Installed fresh Ubuntu. Installed domoticz. Restored backup and set ports for zigate and zwave. Everything works. My take is zigate and windows is unstable at best and almost impossible to get up running..
Don't agree on your statement. Quiet a number of people are using it on Windows, but agree that Windows makes the all things more tricky to be setRfpower666 wrote: ↑Sunday 13 June 2021 22:56 In the end I bit the bullet. Installed fresh Ubuntu. Installed domoticz. Restored backup and set ports for zigate and zwave. Everything works. My take is zigate and windows is unstable at best and almost impossible to get up running..
Wiki is available here.
Zigbee for Domoticz FAQ
Yeah - Well all is working well now any how. I am happy.
I do have another issue though - Not Zigbee related - But perhaps someone here has a clue anyway since i have a thread going..
Zwave - Aeontec Gen5 stick - Aeontec garage door opener.
Works fine - Opens and closes - But leaves error in log every time:
2021-06-17 09:17:09.783 Status: Zstick: OpenZWave: Unhandled class: 0x66 (NO OPERATION), NodeID: 42 (0x2a), Index: 1, Instance: 1
2021-06-17 09:17:09.783 Error: Zstick: OpenZWave: Value_Changed: Tried adding value, not succeeded!. Node: 42 (0x2a), CommandClass: NO OPERATION, Label: Barrier State, Instance: 1, Index: 1
Also: I have tried adding an event in blockly with: IF (device) open and time = 0200 - Set (device) to closed - but it's not triggering at all..
