Move Zigate from Raspbian to windows
So i have installed Domoticz on my windows machine, moved all from rasbian - config, restored database, and have successfully got everything running fine.
Python is ok, z-wave is running, all devices on Z-wave work as before.
installed Zigate Domoticz plugin, and all looks good. until i try controlling a zigbee device. Then my log is flooded with these messages:
2021-06-09 12:17:15.087 Error: ZG: (ZG) [663] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 12:17:16.083 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 12:17:16.084 Error: ZG: (ZG) [664] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 12:17:17.083 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 12:17:17.084 Error: ZG: (ZG) [665] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
tested the zigate using the stated test tool, and all there seems good and works..
i am at a loss.. Any ideas?
The Zigate plugin initializes fine and seems to be working. Zigate COM port has been set in domticz correctly..
021-06-09 12:20:17.801 Sunrise: 04:23:00 SunSet: 22:28:00
2021-06-09 12:20:17.801 Day length: 18:05:00 Sun at south: 13:26:00
2021-06-09 12:20:17.801 Civil twilight start: 03:09:00 Civil twilight end: 23:43:00
2021-06-09 12:20:17.801 There is no nautical twilight in the space of 24 hours
2021-06-09 12:20:17.801 There is no astronomical twilight in the space of 24 hours
2021-06-09 12:20:17.818 Active notification Subsystems: email, fcm (2/13)
2021-06-09 12:20:17.826 Starting shared server on: :::9980
2021-06-09 12:20:17.788 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-09 12:20:17.790 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-09 12:20:17.790 Status: Startup Path: C:\Domoticz\
2021-06-09 12:20:17.817 Status: PluginSystem: Started, Python version '3.8.6'.
2021-06-09 12:20:17.819 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-09 12:20:17.825 Status: WebServer(SSL) started on address: :: with port 443
2021-06-09 12:20:17.827 Status: TCPServer: shared server started...
2021-06-09 12:20:17.827 Status: RxQueue: queue worker started...
2021-06-09 12:20:19.865 ZG hardware started.
2021-06-09 12:20:19.865 Status: ZG: (ZG) Entering work loop.
2021-06-09 12:20:19.865 Status: ZG: (ZG) Started.
2021-06-09 12:20:19.865 Status: NotificationSystem: thread started...
2021-06-09 12:20:19.865 Status: EventSystem: reset all events...
2021-06-09 12:20:19.865 Status: EventSystem: reset all device statuses...
2021-06-09 12:20:19.894 Status: Python EventSystem: Initializing event module.
2021-06-09 12:20:19.894 Status: EventSystem: Started
2021-06-09 12:20:19.894 Status: EventSystem: Queue thread started...
2021-06-09 12:20:20.039 ZG: (ZG) ZiGate plugin started!
2021-06-09 12:20:20.040 ZG: (ZG) load PluginConf
2021-06-09 12:20:20.041 ZG: (ZG) Starting LoggingManagement thread
2021-06-09 12:20:20.041 ZG: (ZG) start_logging_thread
2021-06-09 12:20:20.042 ZG: (ZG) logging_thread - listening
2021-06-09 12:20:20.048 ZG: (ZG) Plugin Database: DeviceList-3.txt
2021-06-09 12:20:20.119 ZG: (ZG) Connection open: None
2021-06-09 12:20:20.038 Status: ZG: (ZG) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-09 12:20:20.041 Status: ZG: (ZG) enablegroupmanagement set to 1
2021-06-09 12:20:20.041 Status: ZG: (ZG) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-09 12:20:20.041 Status: ZG: (ZG) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-09 12:20:20.041 Status: ZG: (ZG) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-09 12:20:20.041 Status: ZG: (ZG) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-09 12:20:20.041 Status: ZG: (ZG) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-09 12:20:20.041 Status: ZG: (ZG) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-09 12:20:20.041 Status: ZG: (ZG) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-09 12:20:20.041 Status: ZG: (ZG) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-09 12:20:20.041 Status: ZG: (ZG) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-09 12:20:20.043 Status: ZG: (ZG) Zigate plugin stable5-5.1.003 started
2021-06-09 12:20:20.050 Status: ZG: (ZG) DeviceConf loaded
2021-06-09 12:20:20.096 Status: ZG: (ZG) load ListOfDevice
2021-06-09 12:20:20.121 Status: ZG: (ZG) 9 Entries loaded from C:\Domoticz\plugins\Domoticz-Zigate\Data/DeviceList-3.txt
2021-06-09 12:20:20.122 Status: ZG: (ZG) Transport mode: USB
2021-06-09 12:20:20.339 Status: PluginSystem: 1 plugins started.
2021-06-09 12:20:20.370 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-09 12:20:20.380 Status: Zstick: Starting...
2021-06-09 12:20:20.380 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
Re: Move Zigate from Raspbian to windows
I suggest that you have a look to the Domoticz Hardware menu and looks the different parameters of the ZiGate plugin.
Currently it seems that you have configured the plugin to not use any communication
Wiki is available here.
Zigbee for Domoticz FAQ
I have checked several times.. It is configured to USB, and correct COM port.. Just checking now to see if the plugin version on the rasbian is different..
So on my pi zigate plugin is pre 4.1 - Could this be the issue? that my zigate firmware doesn't work with the latest zigate plugin?
plugin pre 4.1 is pretty old stuff. Which ZiGate firmware are you ?
old-- lol! You - if it's not broke don't fix it.. here is log from raspbian that works fine atm...
2021-06-09 12:37:49.339 Status: OpenZWave: Driver Ready
2021-06-09 12:37:49.679 Status: (ZG) Entering work loop.
2021-06-09 12:37:49.680 Status: (ZG) Initialized version pre-4.1, author 'zaraki673 pipiche38'
2021-06-09 12:37:49.684 Status: (ZG) Zigate plugin (pre 4.1.x) started
2021-06-09 12:37:49.684 Status: (ZG) Python Version - 3.5.3 (default, Sep 27 2018, 17:25:39)
2021-06-09 12:37:49.684 [GCC 6.3.0 20170516]
2021-06-09 12:37:49.684 Status: (ZG) Switching Hearbeat to 5 s interval
2021-06-09 12:37:49.684 Status: (ZG) DomoticzVersion: 4.10717
2021-06-09 12:37:49.684 Status: (ZG) DomoticzHash: b38b49e5
2021-06-09 12:37:49.684 Status: (ZG) DomoticzBuildTime: 2019-05-09 13:04:08
2021-06-09 12:37:49.920 Status: (ZG) Opening DomoticzDB in raw
2021-06-09 12:37:49.921 Status: (ZG) load PluginConf
2021-06-09 12:37:49.931 Status: (ZG) PluginConf: /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf.txt
2021-06-09 12:37:49.944 Status: (ZG) -vibrationAqarasensitivity: medium
2021-06-09 12:37:49.944 Status: (ZG) -enablegroupmanagement: 1
2021-06-09 12:37:49.944 Status: (ZG) -resetMotiondelay: 30
2021-06-09 12:37:49.944 Status: (ZG) -logFORMAT: 0
2021-06-09 12:37:49.944 Status: (ZG) -logLQI: 0
2021-06-09 12:37:49.945 Status: (ZG) -channel: ['11', '15', '19', '20', '25', '26']
2021-06-09 12:37:49.979 Status: (ZG) Plugin Database: DeviceList-3.txt
2021-06-09 12:37:50.180 (ZG) Configure Permit To Join
2021-06-09 12:37:50.180 (ZG) Request discovery mode for 254 seconds
2021-06-09 12:37:50.004 Status: (ZG) DeviceConf loaded
2021-06-09 12:37:50.004 Status: (ZG) load ListOfDevice
2021-06-09 12:37:50.169 Status: (ZG) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-3.txt : 9
2021-06-09 12:37:50.176 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: /dev/ttyUSB0
2021-06-09 12:37:50.282 Status: (ZG) Major Version Num: 0003
2021-06-09 12:37:50.282 Status: (ZG) Installer Version Number: 030f
2021-06-09 12:37:50.486 Status: (ZG) Zigate in Permit Join: On
2021-06-09 12:37:50.592 Status: (ZG) Zigate addresses ieee: 00158d0001edb6e6 , short addr: 0000
2021-06-09 12:37:50.592 Status: (ZG) Network state UP, PANID: edb9 extPANID: 0x4f3290be8d94805e Channel: 11
2021-06-09 12:37:50.703 Status: (ZG) Number of devices recently active in Zigate = 5
anyway i can specify using git on windows to install pre-4.1 version of zigate plugin?
Ok. so very old firmware and you have a quiet recent plugin version from the log I see version 5.1, I have doubt that it works. But still your problem is not due to that.
Can you share the all logs ( Log+Status+Errors) and from the start of the plugin to the time you get those retry .. As stated in my initial post,
Relate to the configuration problem in the Domoticz Hardware menu in the plugin settings2021-06-09 12:20:20.119 ZG: (ZG) Connection open: None
2021-06-09 13:44:21.878 Sunrise: 04:23:00 SunSet: 22:28:00
2021-06-09 13:44:21.878 Day length: 18:05:00 Sun at south: 13:26:00
2021-06-09 13:44:21.878 Civil twilight start: 03:09:00 Civil twilight end: 23:43:00
2021-06-09 13:44:21.878 There is no nautical twilight in the space of 24 hours
2021-06-09 13:44:21.878 There is no astronomical twilight in the space of 24 hours
2021-06-09 13:44:21.916 Active notification Subsystems: email, fcm (2/13)
2021-06-09 13:44:21.926 Starting shared server on: :::9980
2021-06-09 13:44:21.861 Status: Domoticz V2021.1 (build 13321) (c)2012-2021 GizMoCuz
2021-06-09 13:44:21.861 Status: Build Hash: 94d31bd21, Date: 2021-06-07 11:42:09
2021-06-09 13:44:21.861 Status: Startup Path: C:\Domoticz\
2021-06-09 13:44:21.914 Status: PluginSystem: Started, Python version '3.8.6'.
2021-06-09 13:44:21.917 Status: WebServer(HTTP) started on address: :: with port 8080
2021-06-09 13:44:21.924 Status: WebServer(SSL) started on address: :: with port 443
2021-06-09 13:44:21.926 Status: TCPServer: shared server started...
2021-06-09 13:44:21.926 Status: RxQueue: queue worker started...
2021-06-09 13:44:22.086 Status: Incoming connection from: 127.0.0.1
2021-06-09 13:44:23.969 ZG hardware started.
2021-06-09 13:44:23.970 Status: ZG: (ZG) Entering work loop.
2021-06-09 13:44:23.970 Status: ZG: (ZG) Started.
2021-06-09 13:44:23.971 Status: EventSystem: reset all events...
2021-06-09 13:44:23.971 Status: NotificationSystem: thread started...
2021-06-09 13:44:23.972 Status: EventSystem: reset all device statuses...
2021-06-09 13:44:24.029 Status: Python EventSystem: Initializing event module.
2021-06-09 13:44:24.029 Status: EventSystem: Started
2021-06-09 13:44:24.029 Status: EventSystem: Queue thread started...
2021-06-09 13:44:24.439 Status: PluginSystem: 1 plugins started.
2021-06-09 13:44:24.484 Status: Zstick: using config in: C:\Domoticz\Config/
2021-06-09 13:44:24.513 Status: Zstick: Starting...
2021-06-09 13:44:24.514 Status: Zstick: Version: 1.6.1911.gc6a420ef.dirty
2021-06-09 13:44:25.951 Status: ZG: (ZG) Initialized version 5.1, author 'zaraki673 pipiche38'
2021-06-09 13:44:25.979 Status: ZG: (ZG) enablegroupmanagement set to 1
2021-06-09 13:44:25.979 Status: ZG: (ZG) filename set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf-03.json
2021-06-09 13:44:25.979 Status: ZG: (ZG) pluginHome set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-09 13:44:25.979 Status: ZG: (ZG) homedirectory set to C:\Domoticz\plugins\Domoticz-Zigate\
2021-06-09 13:44:25.979 Status: ZG: (ZG) pluginData set to C:\Domoticz\plugins\Domoticz-Zigate\Data/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginConfig set to C:\Domoticz\plugins\Domoticz-Zigate\Conf/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginOTAFirmware set to C:\Domoticz\plugins\Domoticz-Zigate\OTAFirmware/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginReports set to C:\Domoticz\plugins\Domoticz-Zigate\Reports/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginWWW set to C:\Domoticz\plugins\Domoticz-Zigate\www/
2021-06-09 13:44:25.980 Status: ZG: (ZG) pluginLogs set to C:\Domoticz\plugins\Domoticz-Zigate\Logs/
2021-06-09 13:44:26.844 Zstick: Value_Added: Node: 28 (0x1c), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.844 Zstick: Value_Added: Node: 28 (0x1c), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.845 Zstick: Value_Added: Node: 28 (0x1c), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.845 Zstick: Value_Added: Node: 29 (0x1d), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.846 Zstick: Value_Added: Node: 29 (0x1d), CommandClass: SWITCH MULTILEVEL, Label: On, Instance: 1, Index: 1
2021-06-09 13:44:26.846 Zstick: Value_Added: Node: 29 (0x1d), CommandClass: SWITCH MULTILEVEL, Label: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.847 Zstick: Value_Added: Node: 30 (0x1e), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2021-06-09 13:44:26.848 Zstick: Value_Added: Node: 32 (0x20), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2021-06-09 13:44:26.850 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.851 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.851 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.851 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.852 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.852 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.852 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.853 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.854 Zstick: Value_Added: Node: 35 (0x23), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.855 Zstick: Value_Added: Node: 35 (0x23), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.855 Zstick: Value_Added: Node: 35 (0x23), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.857 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.858 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.858 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.859 Zstick: Value_Added: Node: 35 (0x23), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.860 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.860 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.861 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.862 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.863 Zstick: Value_Added: Node: 36 (0x24), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.865 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.865 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.866 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.866 Zstick: Value_Added: Node: 36 (0x24), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.867 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.867 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.868 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.869 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.870 Zstick: Value_Added: Node: 37 (0x25), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.871 Zstick: Value_Added: Node: 37 (0x25), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.871 Zstick: Value_Added: Node: 37 (0x25), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.871 Zstick: Value_Added: Node: 37 (0x25), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.873 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.873 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.873 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.874 Zstick: Value_Added: Node: 37 (0x25), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.875 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Level, Instance: 1, Index: 0
2021-06-09 13:44:26.875 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Level, Instance: 2, Index: 0
2021-06-09 13:44:26.875 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: On, Instance: 1, Index: 1
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: On, Instance: 2, Index: 1
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Off, Instance: 1, Index: 2
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Off, Instance: 2, Index: 2
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Step Size, Instance: 1, Index: 6
2021-06-09 13:44:26.876 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Step Size, Instance: 2, Index: 6
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Inc, Instance: 1, Index: 7
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Inc, Instance: 2, Index: 7
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 1: Dec, Instance: 1, Index: 8
2021-06-09 13:44:26.877 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SWITCH MULTILEVEL, Label: Instance 2: Dec, Instance: 2, Index: 8
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SCENE ACTIVATION, Label: Scene, Instance: 1, Index: 0
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SCENE ACTIVATION, Label: Duration, Instance: 1, Index: 1
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: SENSOR MULTILEVEL, Label: Power, Instance: 1, Index: 4
2021-06-09 13:44:26.878 Zstick: Value_Added: Node: 38 (0x26), CommandClass: METER, Label: Electric - kWh, Instance: 1, Index: 0
2021-06-09 13:44:26.879 Zstick: Value_Added: Node: 38 (0x26), CommandClass: METER, Label: Electric - W, Instance: 1, Index: 2
2021-06-09 13:44:26.879 Zstick: Value_Added: Node: 38 (0x26), CommandClass: METER, Label: Exporting, Instance: 1, Index: 256
2021-06-09 13:44:26.880 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: Heat, Instance: 1, Index: 4
2021-06-09 13:44:26.881 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.881 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: System, Instance: 1, Index: 9
2021-06-09 13:44:26.881 Zstick: Value_Added: Node: 38 (0x26), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.882 Zstick: Value_Added: Node: 40 (0x28), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1, Index: 0
2021-06-09 13:44:26.883 Zstick: Value_Added: Node: 40 (0x28), CommandClass: ALARM, Label: Power Management, Instance: 1, Index: 8
2021-06-09 13:44:26.883 Zstick: Value_Added: Node: 40 (0x28), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
2021-06-09 13:44:26.017 Status: ZG: (ZG) Zigate plugin stable5-5.1.003 started
2021-06-09 13:44:26.053 Status: ZG: (ZG) DeviceConf loaded
2021-06-09 13:44:26.467 Status: Zstick: A DNS Error Occurred
2021-06-09 13:44:26.467 Status: Zstick: ManufacturerSpecificDB Ready
2021-06-09 13:44:26.788 Status: Zstick: Driver Ready
2021-06-09 13:44:26.799 Status: Zstick: Unhandled class: 0x66 (NO OPERATION), NodeID: 13 (0x0d), Index: 1, Instance: 1
2021-06-09 13:44:26.884 Status: Zstick: New Node added. HomeID: 4119221429, NodeID: 26 (0x1a)
2021-06-09 13:44:28.474 ZG: (ZG) Connection open: None
2021-06-09 13:44:28.387 Status: ZG: (ZG) load ListOfDevice
2021-06-09 13:44:28.474 Status: ZG: (ZG) 9 Entries loaded from C:\Domoticz\plugins\Domoticz-Zigate\Data/DeviceList-3.txt
2021-06-09 13:44:28.476 Status: ZG: (ZG) Transport mode: USB
2021-06-09 13:44:29.913 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 7 (0x07)
2021-06-09 13:44:32.934 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 12 (0x0c)
2021-06-09 13:44:33.950 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 13 (0x0d)
2021-06-09 13:44:42.319 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 17 (0x11)
2021-06-09 13:44:43.333 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 18 (0x12)
2021-06-09 13:44:52.361 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 20 (0x14)
2021-06-09 13:44:53.369 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 21 (0x15)
2021-06-09 13:44:58.404 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 24 (0x18)
2021-06-09 13:45:04.451 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 27 (0x1b)
2021-06-09 13:45:05.471 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 28 (0x1c)
2021-06-09 13:45:19.999 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 31 (0x1f)
2021-06-09 13:45:23.015 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 32 (0x20)
2021-06-09 13:45:26.029 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 34 (0x22)
2021-06-09 13:45:28.077 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:28.085 Error: ZG: (ZG) [ 61] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:29.048 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 35 (0x23)
2021-06-09 13:45:29.075 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:29.081 Error: ZG: (ZG) [ 62] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:30.078 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:30.084 Error: ZG: (ZG) [ 63] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:31.076 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:31.084 Error: ZG: (ZG) [ 64] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:32.063 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 36 (0x24)
2021-06-09 13:45:32.075 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:32.084 Error: ZG: (ZG) [ 65] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:33.070 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 37 (0x25)
2021-06-09 13:45:33.064 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:33.075 Error: ZG: (ZG) [ 66] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:34.122 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:34.128 Error: ZG: (ZG) [ 67] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:35.116 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:35.121 Error: ZG: (ZG) [ 68] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:36.109 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:36.118 Error: ZG: (ZG) [ 69] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:37.101 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:37.109 Error: ZG: (ZG) [ 70] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:38.093 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:38.100 Error: ZG: (ZG) [ 71] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:39.089 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:39.102 Error: ZG: (ZG) [ 72] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:40.087 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:40.091 Error: ZG: (ZG) [ 73] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:41.091 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:41.096 Error: ZG: (ZG) [ 74] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:42.112 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 40 (0x28)
2021-06-09 13:45:42.093 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:42.102 Error: ZG: (ZG) [ 75] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:43.098 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:43.101 Error: ZG: (ZG) [ 76] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:44.099 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:44.107 Error: ZG: (ZG) [ 77] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:45.248 Status: Zstick: Received timeout notification from HomeID: 4119221429, NodeID: 13 (0x0d)
2021-06-09 13:45:45.103 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:45.105 Error: ZG: (ZG) [ 78] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:46.094 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:46.101 Error: ZG: (ZG) [ 79] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:47.895 Zstick: General/kWh (kWh Meter)
2021-06-09 13:45:47.945 Zstick: General/kWh (kWh Meter)
2021-06-09 13:45:47.084 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:47.095 Error: ZG: (ZG) [ 80] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
2021-06-09 13:45:48.078 Error: ZG: (ZG) [ ] Stop the plugin and check ZiGate.
2021-06-09 13:45:48.088 Error: ZG: (ZG) [ 81] I have hard time to get ZiGate Version. Mostlikly ZiGate communication doesn't work
Is that a new ZiGate ? Did you do the Initialisation step ?
Same zigate.. just moved it from PI to my PC to test..
plugging it back into PI and all works fine..
i have a feeling it has to do with firmware version and plugin version.. Do you know how i can specify pre-4.1 for git download in windows?
git checkout pre-4.1
C:\Domoticz\plugins>git checkout pre-4.1
fatal: not a git repository (or any of the parent directories): .git
OK - So a lot closer.. IT is all about versions not working together.. Installed same (old) versions as on my PI on windows and got it all running.
Only some errors about devices.. Do you know where and what files to copy over to sort these messages out? what files in what folders contain this missing info.. I can copy it from my pI over to correct folder in windows..
2021-06-09 15:04:24.196 Status: OpenZWave: Version: 1.4.3244.gbb874f6a.dirty
2021-06-09 15:04:24.349 Status: OpenZWave: Driver Ready
2021-06-09 15:04:24.661 Status: (ZG) Entering work loop.
2021-06-09 15:04:24.661 Status: (ZG) Initialized version pre-4.1, author 'zaraki673 pipiche38'
2021-06-09 15:04:24.663 Status: (ZG) Zigate plugin (pre 4.1.x) started
2021-06-09 15:04:24.664 Status: (ZG) Python Version - 3.5.3 (v3.5.3:1880cb95a742, Jan 16 2017, 15:51:26) [MSC v.1900 32 bit (Intel)]
2021-06-09 15:04:24.664 Status: (ZG) Switching Hearbeat to 5 s interval
2021-06-09 15:04:24.664 Status: (ZG) DomoticzVersion: 4.10717
2021-06-09 15:04:24.664 Status: (ZG) DomoticzHash: b38b49e5
2021-06-09 15:04:24.664 Status: (ZG) DomoticzBuildTime: 2019-05-09 13:04:08
2021-06-09 15:04:24.671 Status: (ZG) Opening DomoticzDB in raw
2021-06-09 15:04:24.672 Status: (ZG) load PluginConf
2021-06-09 15:04:24.673 Status: (ZG) PluginConf: C:\Domoticz\plugins\Domoticz-Zigate\Conf/PluginConf.txt
2021-06-09 15:04:24.674 Status: (ZG) -vibrationAqarasensitivity: medium
2021-06-09 15:04:24.674 Status: (ZG) -enablegroupmanagement: 0
2021-06-09 15:04:24.674 Status: (ZG) -resetMotiondelay: 30
2021-06-09 15:04:24.674 Status: (ZG) -logFORMAT: 0
2021-06-09 15:04:24.674 Status: (ZG) -logLQI: 0
2021-06-09 15:04:24.674 Status: (ZG) -channel: ['11', '15', '19', '20', '25', '26']
2021-06-09 15:04:24.674 Status: (ZG) Plugin Database: DeviceList-3.txt
2021-06-09 15:04:24.677 Status: (ZG) DeviceConf loaded
2021-06-09 15:04:24.678 Status: (ZG) load ListOfDevice
2021-06-09 15:04:24.678 Status: (ZG) Connection Name: Zigate, Transport: Serial, Address: COM5
2021-06-09 15:04:24.678 Error: (ZG) checkListOfDevice2Devices - Subwoofer Stue - 000d6ffffe2fdd0d not found in Plugin Database
2021-06-09 15:04:24.678 Error: (ZG) checkListOfDevice2Devices - Lys Sjenk - d0cf5efffec15bcc not found in Plugin Database
2021-06-09 15:04:24.678 Error: (ZG) checkListOfDevice2Devices - KjøkkenBenk - 90fd9ffffe04c813 not found in Plugin Database
2021-06-09 15:04:24.678 Error: (ZG) checkListOfDevice2Devices - Lader Stue - 000d6ffffe7c0189 not found in Plugin Database
2021-06-09 15:04:24.678 Error: (ZG) checkListOfDevice2Devices - Lampe Kristiansen - d0cf5efffeef4ebf not found in Plugin Database
2021-06-09 15:04:24.678 Error: (ZG) checkListOfDevice2Devices - Lampe Ryan - d0cf5efffe72d337 not found in Plugin Database
2021-06-09 15:04:25.181 (ZG) Configure Permit To Join
2021-06-09 15:04:25.182 (ZG) Request discovery mode for 254 seconds
2021-06-09 15:04:25.304 Status: (ZG) Major Version Num: 0003
2021-06-09 15:04:25.305 Status: (ZG) Installer Version Number: 030f
2021-06-09 15:04:25.550 Status: (ZG) Zigate in Permit Join: On
2021-06-09 15:04:25.743 Status: (ZG) Zigate addresses ieee: 00158d0001edb6e6 , short addr: 0000
2021-06-09 15:04:25.744 Status: (ZG) Network state UP, PANID: edb9 extPANID: 0x4f3290be8d94805e Channel: 11
2021-06-09 15:04:25.857 Status: (ZG) Number of devices recently active in Zigate = 5
2021-06-09 15:04:25.857 Status: (ZG) [00] DevID = 28 Network addr = 3e4b IEEE = d0cf5efffeef4ebf LQI = 075 Power = 01 not found in ListOfDevices
2021-06-09 15:04:25.857 Status: (ZG) [01] DevID = 29 Network addr = 501a IEEE = 000d6ffffe7c0189 LQI = 061 Power = 01 not found in ListOfDevices
2021-06-09 15:04:25.857 Status: (ZG) [02] DevID = 2a Network addr = 7dc6 IEEE = d0cf5efffe72d337 LQI = 046 Power = 01 not found in ListOfDevices
2021-06-09 15:04:25.857 Status: (ZG) [03] DevID = 2b Network addr = f990 IEEE = 90fd9ffffe04c813 LQI = 052 Power = 01 not found in ListOfDevices
2021-06-09 15:04:25.857 Status: (ZG) [04] DevID = 2c Network addr = 7ab3 IEEE = 000d6ffffe2fdd0d LQI = 044 Power = 01 not found in ListOfDevices
2021-06-09 15:04:27.429 Status: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 7 (0x07)
2021-06-09 15:04:30.887 Status: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 13 (0x0d)
2021-06-09 15:04:33.895 Status: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 14 (0x0e)
2021-06-09 15:04:34.949 Status: (ZG) Plugin with Zigate firmware 030f correctly initialized
2021-06-09 15:04:36.913 Status: OpenZWave: Received timeout notification from HomeID: 4119221429, NodeID: 15 (0x0f)
I think you should find all you need in the Wiki and especially here https://github.com/pipiche38/Domoticz-Z ... _Backup.md
Thanks - But there is something going wrong when following this. I suspect is has to to with file structure between windows and raspbian..
Copying over those files causes plugin to stop working..
tried modifying the json files and file paths, but still doesnt help..
i am so close!! lol!
i might just end up flashing firmware - installing latest plugins and re pairing the 5 zigbee devices i have.. should have started with that.. haha!! Would have saved myself hours of work..
