Hello guys,
I'm running Domoticz on 2020.2 with RPI 3
I'm interested to upgrade to 2021.1, but the idea is also to upgrade the hardware (RPI 4)
What do you think about this process ?
- Install a new domoticz 2021.1 on RPI 4
- Import database from 2020.2
I presume that the database will be not the same version.
Do you I need to install a fresh 2020.2, import database, and upgrade to 2021.1 ?
But where to find 2020.2 packages ?
I don't have any scripts to backup, only historical datas (database is enough ?)
Thanks !
Migrate database to a new RPI
- waaren
Re: Migrate database to a new RPI
Recognizing the need for- and conversion of the database to a newer domoticz version is part of every domoticz start.
Jeremob
New RPI installed, with last Domoticz version (2021.1)
Database from 2020.2 successfully imported + RFXCOM connected, everything works
Thanks !
Thanks !
