dzvents docker and script  [Solved]
pvklink
Domoticz version: latest b
Post by pvklink »
I have installed docker and use docker for
- mysql
- phpadmin
- mqtt
- domoticz
- dashticz
- nodered
- apache
All seems to work ok, except one script (for now). MY denon script works for years but after docker it, it wont work and no error with a line!
Any one a suggestion, i only send a curl to my denon...
2021-05-28 14:09:28.661 2021-05-28 14:09:28. Scriptname: DZ_denon, Unknown trigger. DENON setting aangepast met ingestelde waarde: STEREO
2021-05-28 14:09:28.661 2021-05-28 14:09:28. Scriptname: DZ_denon, Unknown trigger. DENON setting aangepast met ingestelde waarde: 010440
2021-05-28 14:09:28.661 2021-05-28 14:09:28. Scriptname: DZ_denon, Unknown trigger. DENON setting aangepast met ingestelde waarde: TUNER
2021-05-28 14:09:28.661 2021-05-28 14:09:28. Scriptname: DZ_denon, Unknown trigger. DENON: curl http://192.168.20.26/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/-70
2021-05-28 14:09:28.661 2021-05-28 14:09:28. Scriptname: DZ_denon, Unknown trigger. DENON setting aangepast met ingestelde waarde: -70
local scriptVar = 'DenonCustomEvents'
	on =    {
            devices = {'denon*' },
            customEvents = {scriptVar},
            data = {lastVolumeState = {initial = '',},},
    execute = function(dz, item,info)
    _G.logLevel = dz.helpers.get_logtype(dz)    -- dz.log('debug test',dz.LOG_DEBUG) this will only make it to the log when LOG_DEBUG is set  AND dz.log('blabla',dz.LOG_FORCE) -- this will allways make it tp the log
    _G.logMarker = _G.moduleLabel               -- marker wordt scriptnaam, _G.logMarker = info.scriptName is idem
    local messageTable = {}                     -- log alles, 0 = niets, 1 dom, 2 global, 3 alles... evt per regel ook in te regelen
    -- HIER START DE EXECUTIE
    local ipdenon       = '192.168.20.26'
    local denon_cmd_1   = 'curl http://' .. ipdenon .. '/MainZone/index.put.asp?cmd0='      -- basiscommando1
    local denon_cmd_2   = 'curl http://' .. ipdenon .. '/Tuner/TUNER/index.put.asp?cmd0='   -- basiscommando2
    local denon_volume  = dz.devices('denon_volume')
    local denon_source  = dz.devices('denon_source')
    local denon_radio   = dz.devices('denon_radio')
    local denon_mixer   = dz.devices('denon_mixer')
    local SourceToSet_volume= -50       -- volume, zie ook LET OP!
    local SourceToSet_source= 'TUNER'   -- source receiver
    local SourceToSet_freq  = '009540'  -- frequency
    local SourceToSet_mixer = 'STEREO'  -- mixer
    --local sign          = '+'   -- als je geen + in een var kan opnemen --' .. sign  ..'  DIT LIJKT INEENS NIET MEER NODIG ?
    local volume_states =   { uit=SourceToSet_volume, fluister = SourceToSet_volume-20, zacht = SourceToSet_volume-10, medium = SourceToSet_volume, hard = SourceToSet_volume+10, extra = SourceToSet_volume+20,}
    local source_states =   { Radio = 'TUNER', Tv = 'SAT/CBL', Sonos = 'CD', Kodi = 'MPLAY', Pc = 'GAME', Cast = 'BD'}
    local radio_states  =   { Skyradio = '010440',Qmusic = '009540', Veronica = '009490', ['538'] = '010500',West = '008890' }
    local mixer_states  =   { movie = 'MOVIE', stereo = 'STEREO', ['mch stereo'] = 'MCH+STEREO', ['dolby digital'] = 'DOLBY+DIGITAL', music = 'MUSIC', game = 'GAME', ['pure direct'] = 'PURE+DIRECT',
                            direct = 'DIRECT', standaard = 'STANDARD', simulation = 'SIMULATION', auto = 'AUTO', left='LEFT', ['video game'] = 'VIDEO+GAME',['rock arena'] = 'ROCK+ARENA' }
    local function get_waarde(dev_state, waardebereik, defvalue )  -- haal waarde op voor een dev_state, doorzoek een waardebereik en geef bij geen hit defvalue terug
        for i_state, i_waarde in pairs(waardebereik) do
            if i_state == dev_state then
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON setting aangepast met ingestelde waarde: ' .. tostring(i_waarde),30)
                return i_waarde
        dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON setting bestaat niet ! Aangepast met defaultwaarde: ' .. tostring(defvalue),30)
        return defvalue
    local function activeer_setting()  -- settings zetten
        os.execute (denon_cmd_1 .. 'PutMasterVolumeSet/' .. get_waarde(denon_volume.state,volume_states , SourceToSet_volume));             -- Denon volume
        vartmp = denon_cmd_1 .. 'PutMasterVolumeSet/' .. get_waarde(denon_volume.state,volume_states , SourceToSet_volume);
        dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON: ' .. vartmp,10)
        os.execute (denon_cmd_1 .. 'PutZone_InputFunction%2F' .. get_waarde(denon_source.state,source_states , SourceToSet_source));        -- Denon wordt op source gezet
        os.execute (denon_cmd_2 .. 'PutTunerFrequency%2F' .. get_waarde(denon_radio.state,radio_states , SourceToSet_freq));                -- Denon radio zender wordt gezet
        os.execute (denon_cmd_1 .. 'PutSurroundMode%2F' .. get_waarde(denon_mixer.state,mixer_states , SourceToSet_mixer) );                -- Denon mixer wordt gezet
        dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON(AAN) is ingesteld met volume(' .. string.upper(denon_volume.state) .. '), Source(' .. string.upper(denon_source.state) .. '), Zender(' .. string.upper(denon_radio.state) .. '), Mixer(' .. string.upper(denon_mixer.state) .. ')' ,30)
    if item.isDevice then
        if  item.name == 'denon_volume' then
           if item.nValue == 0 then                                        -- numerieke waarde van de state van denon_volume (0=off, 1 = on)
                dz.data.lastVolumeState = 'Off'
                os.execute (denon_cmd_1 .. 'PutZone_OnOff%2FOFF' );         -- zet denon uit
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add',' DENON(UIT), denon is uitgezet',30)
            else                                                            -- denon_volume staat aan
                if dz.data.lastVolumeState == 'Off' then                    -- als vorige waarde off was
                    dz.data.lastVolumeState = item.levelName                -- vorige_state wordt op aan gezet!
                    os.execute (denon_cmd_1 .. 'PutZone_OnOff%2FON' )       -- zet denon aan, check de previous waarde als die uit was dan aanzetten anders niet, dan alleen setings doorvoeren !
                vartmp2 = denon_cmd_1 .. 'PutZone_OnOff%2FON';
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON: ' .. vartmp2,30)
                    dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON(AAN), denon is voor ze zekerheid aangezet',30)
                    dz.emitEvent(scriptVar).afterSec(5)
                else                                                        -- vorige waarde was een volume waarde, dus stond al aan!
            if dz.devices('denon_volume').state == 'uit' then
                denon_volume.switchSelector('medium').silent()              -- LET OP! als de denon uit staat, heeft volume de waarde uit, dus zal bij waarde ophalen waarde bij uit worden gepakt. De selector moet dan ook op bijpassende waarde worden gezet en dat is medium
                os.execute (denon_cmd_1 .. 'PutZone_OnOff%2FON' );          -- zet denon aan
                vartmp3 = denon_cmd_1 .. 'PutZone_OnOff%2FON';
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON: ' .. vartmp3,30)
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON(AAN), denon is aangezet door een ander denon onderdeel',30)
                dz.helpers.globalMessage2(dz,item,info,messageTable,'add',  ' DENON(AAN), denon stond al aan',30)   -- overtollig, dus op 0 gezet
                dz.emitEvent(scriptVar)                                     -- mag gelijk worden uitgevoerd, staat al aan
    elseif item.isCustomEvent then
        activeer_setting()
    dz.helpers.globalMessage2(dz,item,info,messageTable,'chg')              -- dump
Jablotron connection, Ikea
Re: dzvents docker and script
pvklink wrote: Friday 28 May 2021 14:16 All seems to work ok, except one script (for now). MY denon script works for years but after docker it, it wont work and no error with a line!
os.execute does not return anything so you cannot know if the curl command was found and if so if it was executed without issues.
If possible better to change this to dz.openURL with a callback or to executeShellCommand (also with a callback) in both cases you will see more to work with.
pvklink
Post by pvklink »
ahhhhhhhh.... I remembered i wise lesson (from you) to eliminate the script by pelling it off... So i did in the wrong order and after two hours (1 minute a agoo i came to the conclusion: that execute dos not work with docker...
thanks waaren, i wil test the other option! :-)
	on =    {
            devices = {'testxx' },
    var1 = 'curl http://192.168.20.26/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON'
    var2 = 'curl http://192.168.20.26/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FOFF'
        os.execute (var2);          -- zet denon aan
pvklink
Post by pvklink »
The openURL part works Great!
I like to pass a command from within a docker to the host, i testen the below command from $ and that works.
Now i want this os command to exec from within dzvents.
Is this the way to go ? i have my doubts on the mycommand part
this part works on the $ sshpass -f <(printf '%s\n' 2286MA11@) ssh [email protected] "sudo docker stop nodered"
function call_exec(mycmd)
            dz.executeShellCommand(
                                    command = mycmd,
                                    callback = scriptVar,
                                    timeout = 120           -- in seconds
mycommand = "sshpass -f <(printf '%s\n' xxxx@) ssh [email protected] 'sudo docker stop nodered')"
call_exec(mycommand)
pvklink
Post by pvklink »
@solved by moving the actual command to a script an call the script...
pvklink
Post by pvklink »
My denon script works with the new commands within docker but gives an error without line number.
2021-05-30 17:54:05.209 Status: dzVents: Info: ------ Finished DZ_denon
2021-05-30 17:54:05.244 Error: Error opening url: http://192.168.20.26/MainZone/index.put ... tion/TUNER
2021-05-30 17:54:05.258 Error: Error opening url: http://192.168.20.26/MainZone/index.put ... MCH+STEREO
2021-05-30 17:54:05.264 Error: Error opening url: http://192.168.20.26/MainZone/index.put ... umeSet/-70
It happens when the function activeer_setting() executes and kicks some urls...
I can cut and paste the urls in my browser and they work.
The procedure i followed: (denon was already on)
- put my volume harder (denon_volume)
-- docker ondersteunt geen os.execute,
-- gebruik dz.openURL
-- HAAL OOK DE ; weg achter de procedure zoals van oorsprong wel bij os.execute wordt gebruikt
-- fouten bij functie activeer settings, maar lijkt allemaal toch goed te gaan, kan alle vanaf http gewoon in de browser kloppen en dan werkt t, de callback werkt dan blijkbaar niet goed om de fout te zien
-- 2021-05-30 17:09:11.181 Error: Error opening url: http://192.168.20.26/MainZone/index.put.asp?cmd0=PutZone_InputFunction/TUNER
-- 2021-05-30 17:09:11.186 Error: Error opening url: http://192.168.20.26/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/-60
-- 2021-05-30 17:09:11.192 Error: Error opening url: http://192.168.20.26/MainZone/index.put.asp?cmd0=PutSurroundMode/MCH+STEREO
local scriptVar2 = 'DenonhttpEvents'
	on =    {
            httpResponses = {scriptVar2},
    logging = { level = domoticz.LOG_DEBUG },
    --_G.logLevel = dz.helpers.get_logtype(dz)    -- dz.log('debug test',dz.LOG_DEBUG) this will only make it to the log when LOG_DEBUG is set  AND dz.log('blabla',dz.LOG_FORCE) -- this will allways make it tp the log
    --_G.logMarker = _G.moduleLabel               -- marker wordt scriptnaam, _G.logMarker = info.scriptName is idem
--    local denon_cmd_1   = 'curl http://' .. ipdenon .. '/MainZone/index.put.asp?cmd0='      -- basiscommando1
--    local denon_cmd_2   = 'curl http://' .. ipdenon .. '/Tuner/TUNER/index.put.asp?cmd0='   -- basiscommando2
    local denon_cmd_1   = 'http://' .. ipdenon .. '/MainZone/index.put.asp?cmd0='      -- basiscommando1
    local denon_cmd_2   = 'http://' .. ipdenon .. '/Tuner/TUNER/index.put.asp?cmd0='   -- basiscommando2
    local function call_url(myurl)
        dz.openURL({
        url = myurl,
        method = 'GET',
        callback = scriptVar2
                return i_waarde
        return defvalue
    local function activeer_setting()  -- settings zetten nu de dz.openURL functie gebruikt en %2F vervangen door / anders werk DZopenURL niet
        call_url (denon_cmd_1 .. 'PutMasterVolumeSet/' .. get_waarde(denon_volume.state,volume_states , SourceToSet_volume))              -- Denon volume
        call_url (denon_cmd_1 .. 'PutZone_InputFunction/' .. get_waarde(denon_source.state,source_states , SourceToSet_source))           -- Denon wordt op source gezet
        call_url (denon_cmd_2 .. 'PutTunerFrequency/' .. get_waarde(denon_radio.state,radio_states , SourceToSet_freq))                   -- Denon radio zender wordt gezet
        call_url (denon_cmd_1 .. 'PutSurroundMode/' .. get_waarde(denon_mixer.state,mixer_states , SourceToSet_mixer))                    -- Denon mixer wordt gezet
        -- nieuwe opzet docker, met oude waarden, dus ook %2F die volges mij niet werken in dzopenURL
        --call_url (denon_cmd_1 .. 'PutMasterVolumeSet/' .. get_waarde(denon_volume.state,volume_states , SourceToSet_volume))                -- Denon volume
        --call_url (denon_cmd_1 .. 'PutZone_InputFunction%2F' .. get_waarde(denon_source.state,source_states , SourceToSet_source))           -- Denon wordt op source gezet
        --call_url (denon_cmd_2 .. 'PutTunerFrequency%2F' .. get_waarde(denon_radio.state,radio_states , SourceToSet_freq))                   -- Denon radio zender wordt gezet
        --call_url (denon_cmd_1 .. 'PutSurroundMode%2F' .. get_waarde(denon_mixer.state,mixer_states , SourceToSet_mixer))                    -- Denon mixer wordt gezet
        -- oude waarde zonder docker, dit werkte met os.execute
        --os.execute (denon_cmd_1 .. 'PutMasterVolumeSet/' .. get_waarde(denon_volume.state,volume_states , SourceToSet_volume));             -- Denon volume
        --os.execute (denon_cmd_1 .. 'PutZone_InputFunction%2F' .. get_waarde(denon_source.state,source_states , SourceToSet_source));  -- Denon wordt op source gezet
        --os.execute (denon_cmd_2 .. 'PutTunerFrequency%2F' .. get_waarde(denon_radio.state,radio_states , SourceToSet_freq));        -- Denon radio zender wordt gezet
        --os.execute (denon_cmd_1 .. 'PutSurroundMode%2F' .. get_waarde(denon_mixer.state,mixer_states , SourceToSet_mixer) );         -- Denon mixer wordt gezet
                call_url (denon_cmd_1 .. 'PutZone_OnOff/OFF' )
                --call_url (denon_cmd_1 .. 'PutZone_OnOff%2FOFF' )
                --os.execute (denon_cmd_1 .. 'PutZone_OnOff%2FOFF' );         -- zet denon uit
                    call_url (denon_cmd_1 .. 'PutZone_OnOff/ON' )
                    --call_url (denon_cmd_1 .. 'PutZone_OnOff%2FON' )
                    --os.execute (denon_cmd_1 .. 'PutZone_OnOff%2FON' )       -- zet denon aan, check de previous waarde als die uit was dan aanzetten anders niet, dan alleen setings doorvoeren !
                else                                                        -- vorige waarde was een volume waarde, dus stond al aan! en wordt dus van volume waarde veranderd
                    --pvkactie= denon_cmd_1 .. 'PutMasterVolumeSet/' .. get_waarde(denon_volume.state,volume_states , SourceToSet_volume)
                    --call_url (pvkactie)              -- Denon volume
                --os.execute (denon_cmd_1 .. 'PutZone_OnOff%2FON' );          -- zet denon aan
        activeer_setting()
    elseif item.isShellCommandResponse then
        if item.ok then
            dz.log('xxxx successfully send', dz.LOG_DEBUG)
            dz.log('No valid response from xxx command: ' .. item.statusCode, dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
    elseif (item.isHTTPResponse) then
        if (item.ok) then
            --  local current = item.json.consumption
            --  dz.devices('myCurrentUsage').updateEnergy(current)
pvklink
Post by pvklink »
I have an easier script with the same problem, an error and the script works within docker
2021-05-30 18:26:28.493 Status: dzVents: Info: ------ Finished DZ_service_clear_log
2021-05-30 18:26:28.299 Error: Error opening url: http://192.168.20.48:82/json.htm?idx=14 ... arlightlog
2021-05-30 18:26:28.474 Error: dzVents: Error: (3.1.8) HTTP/1.1 response: 401 ==>> Unauthorized
All the files of my data are unprotected, so that coukd be the problem..
Has to do something with docker and domoticz
local scriptVar = 'cleartextCustomEvents'
            devices = {'clear_log'},
            httpResponses = { 'clean_response' },
    function clean_hist()
        -- er is een url om de historie te schonen
        dz.openURL({
        url = 'http://192.168.20.48:82/json.htm?idx=1472&type=command&param=clearlightlog',
        method = 'GET',
        callback = 'clean_response'})
    if (item.isDevice and item.state == 'On') or (item.isCustomEvent) then
        -- zie de del optie hieronder, dit schoont alleen de actuele / laatste msg, niet de historie
        dz.helpers.globalMessage2(dz,item,info,messageTable,'del',dz.time.rawDate .. '  ' .. dz.time.rawTime .. ' :' .. ' TIMERLOG CLEAR: log wordt geschoond...' .. '<br>',30) -- delete
        clean_hist()
        dz.devices('clear_log').switchOff().silent().afterSec(1)    --device weer in de off stand zetten zonder script uit te voeren
        if (item.ok) then
pvklink wrote: Sunday 30 May 2021 17:39 -- docker ondersteunt geen os.execute,
I doubt if that is the right conclusion. os.execute is generic Lua code
I suspect that curl cannot be found from within docker and that's more likely the reason why that part fails.
Re: dzvents docker and script  [Solved]
pvklink wrote: Sunday 30 May 2021 18:29 I have an easier script with the same problem, an error and the script works within docker
Did you follow below
Also make sure that in the Security section in the settings (Setup > Settings > System > Local Networks (no username/password) you allow 127.0.0.1 (and / or ::1 when using IPv6 ) to not need a password. dzVents does use this port to get the location settings and to send certain commands to Domoticz.
pvklink
Post by pvklink »
I just installed curl (was already there) and still get
2021-05-30 21:51:43.730 Status: dzVents: Info: ------ Start internal script: DZ_service_clear_log: HTTPResponse: "clean_response"
2021-05-30 21:51:43.749 Status: dzVents: Info: ------ Finished DZ_service_clear_log
2021-05-30 21:51:43.508 Error: Error opening url: http://192.168.20.48:82/json.htm?idx=14 ... arlightlog
2021-05-30 21:51:43.731 Error: dzVents: Error: (3.1.8) HTTP/1.1 response: 401 ==>> Unauthorized
When i go to the device via the domoticz ux and clean the log is does work ,
and when using the browser and
http://192.168.20.48:82/json.htm?idx=14 ... arlightlog it works
Butbelow dzvents script it wont work and gives an error
        dz.openURL({
        method = 'GET',
        clean_hist()
        if (item.ok) then
These are my settings of domoticz in the container: (local and all my vlans are there)
127.0.0.1;192.168.1.*;192.168.10.*;192.168.20.*;192.168.30.*;192.168.70.1
But the default docker domoticz/docker uses a bridge mode i think, does that change anything ?
This is my domoticz compose part
version: '3.6'
[code]
services:
  mosquitto:
    container_name: mosquitto
    image: eclipse-mosquitto
    restart: unless-stopped
    user: "1000"
    ports:
    - "1883:1883"
    volumes:
    - "/home/pi/pvkmenu/IOTstack/volumes/mosquitto/data:/mosquitto/data"
    - "/home/pi/pvkmenu/IOTstack/volumes/mosquitto/log:/mosquitto/log"
    - "/home/pi/pvkmenu/IOTstack/volumes/mosquitto/pwfile:/mosquitto/pwfile"
    - "/home/pi/pvkmenu/IOTstack/volumes/mosquitto/config:/mosquitto/config:ro"
    network_mode: bridge
  domoticz:
    container_name: domoticz
    #build: /home/pi/pvkmenu/IOTstack/services/domoticz/.
    image: domoticz/domoticz:latest
    ports:
    - "82:8080"
    - "444:443"
    devices:
    - '/dev/ttyUSB0:/dev/ttyUSB0'
    - '/dev/ttyACM0:/dev/ttyACM0'
    - '/dev/ttyUSB1:/dev/ttyUSB1'
    volumes:
    - "/home/pi/pvkmenu/IOTstack/volumes/domoticz/data:/opt/domoticz/userdata"
    environment:
    - PUID=1000
    - PGID=1000
    - LOG_PATH=/opt/domoticz/userdata/domoticz.log
  dashticz:
    container_name: dashticz
    build: /home/pi/pvkmenu/IOTstack/services/dashticz/.
    #context: .
    restart: always
    ports:
      - "80:80"
    volumes:
      - /etc/localtime:/etc/localtime:ro
      - type: bind
        source: /home/pi/pvkmenu/IOTstack/volumes/dashticz/
        target: /var/www/html/
my dockerfile (need small add-on to the original docker mage because of the need to start and stop other dockers within the domoticz docker. I use sshpass for that. I start and stop a motion docker when security is off..
FROM domoticz/domoticz:latest
USER root
RUN apt-get update -y -q
RUN apt-get install apt-utils -y -q
RUN apt-get install sshpass -y -q
pvklink
Post by pvklink »
It is solved, with a perfect hint from @waaren
Had to do with the ip-range in domoticz setup.
The docker uses bridging and another ip-range, 172.17.0.*
adding this range solved it!
