Unfortunately the device was nog recognized by OpenZwave. I spent some time on it and fortunately i managed to get it to work by creating my own openzwave config. I was happily surprised by the feature of the plug. Not only does it have a normal relay function and energy measurement. It also has a built in temperature sensor and can act as a thermostat. combined with the ability to go to 16A makes this a very interesting device.
Hopefully it will be added to the OpenZwave database in the near future, but If anyone else would already like to try: Here's the workaround how to make it work till it's added to the OpenZwave DB:
1. Add the following lines to
<Manufacturer id="0330" name="Robb Shop"> <!-- new manufacturer id for Neo Coolcam -->
<Product config="robb/smartplug.xml" id="d004" name="ROB_100-017-0 Robb Smarrt Power plug 3680Watt" type="0200"/>
</Manufacturer>2. Create a directory "robb" under domoticz/Config (so it will be domoticz/Config/robb)
3. in that direcotry create a file names smartplug.xml with the following contents:
<Product Revision="1" xmlns="https://github.com/OpenZWave/open-zwave">
<!-- Please refer to https://github.com/OpenZWave/open-zwave/wiki/Adding-Devices for instructions -->
<MetaData>
<MetaDataItem name="Name">ROBB Smarrt Wallplug Z-Wave 3680watt</MetaDataItem>
<MetaDataItem name="Description">https://www.robbshop.nl/en/detail/522f5f563f694f00872bd7f17a7fb082</MetaDataItem>
<MetaDataItem name="OzwInfoPage">http://www.openzwave.com/device-database/XXXX:YYYY:ZZZZ</MetaDataItem>
<MetaDataItem name="ProductPage">https://www.robbshop.nl/en/detail/522f5f563f694f00872bd7f17a7fb082</MetaDataItem>
<MetaDataItem name="ProductSupport">https://www.robbshop.nl/en/detail/522f5f563f694f00872bd7f17a7fb082</MetaDataItem>
<MetaDataItem name="ProductPic"><!-- path to images/vendor/product.png --></MetaDataItem>
<MetaDataItem name="ProductManual"><!-- URL to the product manual. - Prefer to use something hosted on the products.z-wavealliance.org pages --></MetaDataItem>
<MetaDataItem name="WakeupDescription">Hit the button 3 times</MetaDataItem>
<MetaDataItem name="InclusionDescription">Press the include button on your controller and hit the button 3 times</MetaDataItem>
<MetaDataItem name="ExclusionDescription">Press the include button on your controller and hit the button 3 times</MetaDataItem>
<MetaDataItem name="ResetDescription"><!-- Short Description on how to Factory Reset the Device --></MetaDataItem>
<ChangeLog>
<Entry author="akamming" date="27 May 2021" revision="1">1st attempt</Entry>
</ChangeLog>
</MetaData>
<!-- Configuration Command Class - All Configuration Parameters should be entered into the section below -->
<CommandClass id="112">
<Value genre="config" index="7" label="Device Operating Mode" max="1" min="0" size="1" type="list" value="0">
<Help>Switch Mode enables to control relay output directly using basic or binary set, Thermostat Mode will control the relay output automatically according to the temperature value set</Help>
<Item label="Switch Mode" value="0"/>
<Item label="Thermostat Mode" value="1"/>
</Value>
<Value genre="config" index="8" label="Reporting" max="1" min="0" size="1" type="list" value="0">
<Help>When configured as thermostat: if Thermostat Setpoint or mode changes, whether to report it actively</Help>
<Item label="No Reporting" value="0"/>
<Item label="Report Actively" value="1"/>
</Value>
<Value genre="config" index="9" label="Temperature Compensation" max="50" min="-50" type="byte" units="0.1Celsius" value="0">
<Help>
Temperature Compensation Value
</Help>
</Value>
<Value genre="config" index="10" label="Temperature protection" max="60" min="0" type="byte" units="1 Celsius" value="36">
<Help>
Temperature Protection Value. 0: Disable Temperature protection, 30-60: Set a treshold. If this treshold is reached, the relay is switched off
</Help>
</Value>
<Value genre="config" index="11" label="Temperature Reporting Treshold" max="50" min="2" type="byte" units="0.1 Celsius" value="5">
<Help>
When to report changed value to gateway. 0: Disable report. 2-50: Set a treshold
</Help>
</Value>
<Value genre="config" index="12" label="Time Interval Temperature Report" max="65536" min="10" type="short" units="Seconds" value="300">
<Help>
Set Time Interval for reporting Temperature to gateway.
</Help>
</Value>
<Value genre="config" index="13" label="Power Reporting Treshold" max="255" min="1" type="byte" units="W" value="2">
<Help>
When to report changed value to gateway. 0: Disable report. 1-255: Absolute treshold
</Help>
</Value>
<Value genre="config" index="14" label="Voltage Reporting Treshold" max="255" min="1" type="byte" units="V" value="2">
<Help>
</Help>
</Value>
<Value genre="config" index="15" label="Current Reporting Treshold" max="255" min="1" type="byte" units="0.1A" value="1">
<Help>
</Help>
</Value>
<Value genre="config" index="17" label="Time Interval Voltage Report" max="65536" min="10" type="short" units="Seconds" value="300">
<Help>
Set Time Interval for reporting Voltage to gateway.
</Help>
</Value>
<Value genre="config" index="18" label="Device State After Power Reset" max="2" min="0" size="1" type="list" value="2">
<Help>Device State After Power Reset.</Help>
<Item label="Relay (Switch Mode) or HVAC (Thermostat Mode) Off" value="0"/>
<Item label="Relay (Switch Mode) or HVAC (Thermostat Mode) On" value="1"/>
<Item label="Last State before Power Reset" value="1"/>
</Value>
<Value genre="config" index="19" label="Lifeline behaviour" max="2" min="0" size="1" type="list" value="1">
<Help>Enable/Disable to send SWITCH_BINARY_REPORT to the Lifeline when the plug (under switch mode) state changes, reset power of the plug and factory reset the plug.</Help>
<Item label="Disable to Send" value="0"/>
<Item label="Enable to Send" value="1"/>
</Value>
<Value genre="config" index="20" label="Current Protection Treshold" max="16" min="0" type="byte" units="A" value="16">
<Help>
Enable/Disable current protection function. 0=disable, 10-16 is set a Treshold in A
</Help>
</Value>
</CommandClass>
<!-- The Association Group Information -->
<CommandClass id="133">
<Associations num_groups="1">
<Group index="1" label="LifeLine" max_associations="5"/>
</Associations>
</CommandClass>
</Product>5. Include the device like you would normally do
Last but not least: The manufactur_specific.xml file will be overwritten at every domoticz upgrade. So as long as the device is not in the OpenZWave Database, you have to reapply the change from step 1 if you want to do a device refresh or device inclusion after a domoticz upgrade.
