I upgraded from version 3.6 to 3.8. After starting, I received the following error message:
I also tried a basic config.js file, but no change.
What does the 'find' property mean?
Anyone have any ideas?
Windows Server 2019STD (IIS), PHP 7.3.7
Console:
Cannot read property 'find' of undefined or upgrade failed from 3.6 to 3.8
Lokonli
Re: Cannot read property 'find' of undefined or upgrade failed from 3.6 to 3.8
This seems to be bug in the startup sequence of Dashticz. I think it only becomes visible on IIS. Thanks for reporting.Mad6 wrote: Thursday 13 May 2021 23:59 I upgraded from version 3.6 to 3.8. After starting, I received the following error message:
Console:
I've created a fix in master 3.8.0.2 which I expect will solve this issue.
Could you test master 3.8.0.2?
I installed the new version and the error message changed.
Lokonli
If your Domoticz IP and/or Domoticz authentication is not correct you will get this error.Mad6 wrote: Saturday 15 May 2021 21:33 Hello,
If you open DevTools (F12) and refresh Dashticz, then probably on the DevTools Network tab you see a network request with an error status.
You might see some errors on the DevTools console tab as well.
I found the problem.
I receive this on the console: Next try open the url in the webserver: I install the ASP, or ASP. net (but why...
), and create a handler mapping to *.tpl. (https://support.plesk.com/hc/en-us/arti ... -Not-Found)
IISreset aaand working.
Thanks for the new version, and the new idea!
Lokonli
O yes, indeed.
On iis a handler for .tpl files needs to be installed.
I'll try to improve the error handling.
Verstuurd vanaf mijn AC2003 met Tapatalk
