Apologies if this is a RTFM query - but I can't seem to find the answer!
I am using openURL in a dzVents script to call a url. It takes 25 seconds to return, which is expected - but by this point the request has generally timed out at domoticz.
Is the timeout configurable?
Cheers!
openUrl timeout?
- waaren
Re: openUrl timeout?
No it is not. Connection timeout is set at 10 seconds and max time for the total call is set at 90 seconds in httpclient/HTTPClient.cpp
If you use a recent version you could build your own curl command (with the timeout values you need) using the executeShellCommand() in dzVents and return the result back to your script with a callback to shellCommandResponses. (see the wiki)
Thanks - I will try that - though 90 seconds should in fact be long enough!
Cheers
Cheers
Ah - found the problem I think:
It wasn't timing out, but the call returned no data - which was interpreted by domoticz as an error.
I've added a response to the call, and it seems fine now
