Raspberry Pi has a page with information about the supported power requirements here:
https://www.raspberrypi.org/documentati ... /README.md
In particular:
- Pi 3 needs 2.5 amp
- the official PSU for Pi 3, with a Micro USB, supplies 2.5 amp
- the Pi 3 can supply up to 1.2A to USB devices (such as Zigate)
Using Raspberry Pi 3 and a Zigate stick, I've encountered various issues that could be either the PSU or the cable.
Can anybody comment on any of these issues:
- what is the actual power requirement for each Zigate model? I couldn't find this on the Zigate web site
- can Zigate be put in a low power mode (for example, reducing transmitter power) to ensure it does not stress the Raspberry Pi?
- if the Pi 3 is connected to a supply capable of more than 2.5A, does that make it any more resilient with Zigate?
- not everybody uses the official Pi PSU. For example, some people can take USB power directly from a UPS or some other device. Can anybody comment on how to source Micro USB cables that can carry 2.5A?
Raspberry Pi and Zigate USB power supply requirements, PSU issues, cable issues
Daniel Pocock, Debian Developer
https://danielpocock.com
Thorgal789
- Target OS: -
Re: Raspberry Pi and Zigate USB power supply requirements, PSU issues, cable issues
I can be wrong, but if I remember there is a "fuse" to protect the raspberry so you can't exceed the 2.5 A
Micro USB have no problem to carry 2.5 A.
You can too use powered USB Hub.
