Control LED with RFXtrx433 USB 433.92MHz
At home I've a couple of LED strips, which are controlled with an IR remote.
I would like to control this with domoticz, now I found this website: http://www.alibaba.com/product-gs/58053 ... B.html?s=p
And I was wondering what the chances are for this to work.
Cheers,
Will
PS. If someone has a different/better solution please let me know.
Cheers,
Will
- Target OS: -
Re: Control LED with RFXtrx433 USB 433.92MHz
The next RFXtrx433 firmware version 68 supports the MDREMOTE LED dimmer:
http://www.ultraleds.co.uk/mini-dimmer- ... ximum.html
RFX-433, RFX-433EMC, RFX-868
waou...didn't know about that one !
do you know if it can handle RGB (and/or RGBW) led strips ?
By the way, where do you get info on the next Rfxtrx433 firmware upgrade ?
On z-wave side, there is the Fibaro RGBW dimmer (around 60€) :
http://www.fibaro.com/en/the-fibaro-sys ... controller
regards,
bistoury.
regards,
bistoury.
also here for netherlands (http://www.123ledstunter.nl/LED-strip/1 ... r-Set.html) and can be found on Ebay as well. There's different variants', I wonder if all are supported by rfxcom and how one can tell.
(edit: never mind, they ship from China so it's of no use)
According to the website the controller supports only single colour LED>bistoury wrote:waou...didn't know about that one !
regards,
bistoury.
So no RGB, don't know if any other will support it.
grrr... have to wait for z-wave.me to implement the fibaro dimmer into the razberry...
I found the RGB version of the MDREMOTE LED, Just ordered it for 6 euro'sbistoury wrote:grrr... have to wait for z-wave.me to implement the fibaro dimmer into the razberry...
Will test it when it arrives and when the new firmware is available.
Keep you posted bistoury.
Cheers,
Will
Dear Bert, the mini dimmers arrived today but still waiting for firmware release 68...b_weijenberg wrote:The next RFXtrx433 firmware version 68 supports the MDREMOTE LED dimmer:
Appreciated anyway.
- Target OS: -
request RFXCOM support for the beta version 68
thanks Bert!b_weijenberg wrote:request RFXCOM support for the beta version 68
- Target OS: -
Did you get this to work? I would love to control LED-strips through domoticz
Lightwaverf RGB LED strips are now appearing in the UK. Be great to control the colour changing through Domoticz - particularly through events.
I don't think they are currently supported on RFXcom?
- Target OS: -
LWRF color commands are supported in the next firmware version and Domoticz would need an update too.
- Target OS: -
when will the new firmware (68) be realeased.
I also wat to use the RGB led functions.
- Target OS: -
Note that the dx.com version cannot be controlled by the RFXtrx433!
This LED dimmer has been tested http://www.ultraleds.co.uk/mini-dimmer- ... ximum.html
- Target OS: -
can this firmware for the led controller already be downloaded?
How can this people tell if it is working or not?
As the firmware is not be realesed.
- Domoticz version: Latest
Beta testing...
Order already at dx, in the time you will receive it the firmware is released
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
