Problem with timer since 2021.1 update  [Solved]
dlube
Post by dlube »
Not sure that it's a dzvents problem...
At 00:30, depending on the water temperature I set the timer (API Json) of the switch (enocean) of the pump.
The steps are these ones:
- Clear the timer
- Add timer to start the pump
- Add timer to stop the pump
Before the last update of Domoticz my script was working fine.
Today, sometimes it works and sometimes I have only the timer to stop the pump or nothing.
There is nothing in the logs which show something wrong.
Do you have any idea of the source of the problem?
Raspbian Buster on Raspberry pi 3 B+ Domoticz Version: 2023.2 (build 15474)
Re: Problem with timer since 2021.1 update
dlube wrote: Saturday 08 May 2021 18:57 Before the last update of Domoticz my script was working fine.
You refer to a possible problem in a dzVents script. To understand what could be the issue it would be helpful to see the script.
dlube
Post by dlube »
This simple script does not work all the time.
domoticz.openURL({url = domoticz.settings['url']..'/json.htm?type=command&param=cleartimers&idx=001})
domoticz.openURL({url = domoticz.settings['url']..'/json.htm?type=command&param=addtimer&idx=001&active=true&timertype=3&hour=6&min=0&randomness=false&command=0&days=1234567'})
domoticz.openURL({url = domoticz.settings['url']..'/json.htm?type=command&param=addtimer&idx=001&active=true&timertype=3&hour=0&min=0&randomness=false&command=1&days=1234567'})
I have the feeling that each openURL are not done in this order.
Sometimes I have both timer 'On and 'Off', sometimes only the 'Off' and sometimes nothing.
However, the log file looks correct.
I'm currently testing a callback in the clearTimer URL and to execute 'On' and 'Off' settings in the HttpResponse.
Re: Problem with timer since 2021.1 update  [Solved]
dlube wrote: Tuesday 11 May 2021 9:52 This simple script does not work all the time.
The order in which commands from Lua / dzVents script will be executed is not guaranteed.
Also: domoticz.openURL() commands are in recent versions executed in separate threads, making the execution order even more unpredictable.
What you could do to improve the predictability is using the .afterSec() option.
e.g.
domoticz.openURL(domoticz.settings['url']..'/json.htm?type=command&param=cleartimers&idx=001')
domoticz.openURL(url = domoticz.settings['url']..'/json.htm?type=command&param=addtimer&idx=001&active=true&timertype=3&hour=6&min=0&randomness=false&command=0&days=1234567').afterSec(2)
domoticz.openURL(url = domoticz.settings['url']..'/json.htm?type=command&param=addtimer&idx=001&active=true&timertype=3&hour=0&min=0&randomness=false&command=1&days=1234567').afterSec(4)
dlube
Post by dlube »
It's important that the cleartimer is executed first.
This is the reason why I added a callBack which seems working fine.
Thank you
