Wait for Blinds to be at level then set new level  [Solved]
Nephylim
Post by Nephylim »
Hi there,
I have a question regarding an event involving my venetian blinds.
I want to control them at to bes set to predefined levels like 25% blinds closed or 25% blinds open.
To be sure that the blinds are closed at 25% they have to come from a lower level.
For example if the blinds are at 75% and i set them 25% the flaps would be rotated open.
So to be sure that they are at 25% closed they have to go to a lower level first.
I made an event that looks like this
if (dz.devices(Schalter).level == 10) then
            if(dz.devices(Jalousie).level < 25) then
                dz.devices(Jalousie).dimTo(25).silent()
            else dz.devices(Jalousie).dimTo(20).silent()  at this point the next step should only be executed once this position is reached
the problem now is that the blinds always directly go to 25%.
To work correctly they should go to 20% wait till they are at 20% and then go to 25%
Can someone help me with that?
Re: Wait for Blinds to be at level then set new level
Nephylim wrote: Saturday 08 May 2021 12:29 To work correctly they should go to 20% wait till they are at 20% and then go to 25%
Can you try
    dz.devices(Jalousie).dimTo(25).silent().afterSec(10) -- adjust to your needs or change number to calculated value based on current level
Nephylim
Re: Wait for Blinds to be at level then set new level  [Solved]
Post by Nephylim »
thank you that works.
