DzVents script to create CSV file for further processing
I created this script for a forum member who had the need to create a rolling csv file to publish the data as a graph using Google charts.
Have Fun !!
    script to create a CSV file with following layout.
    now,inside,target,outside,lounge,greenhouse,heating  [header row]
    22:10,21.2,7.0,12.7,21.3,11.8,0   [oldest data: 24 hours minus 10 mins. ago]
    22:20,21.1,7.0,12.7,21.3,11.8,0   [next data: 10 mins. later]
    22:00,21.1,7.0,9.4,22.0,8.0,0     [latest data]
        History:
        20200108: Start coding
        20200110: Start testing on life situation (thanks to MikeF)
        20200122: First public release
return
    on =
        timer =
            -- already quite busy at round minutes so shift a couple of minutes. Choose the one you prefer by uncommenting the line
            'at *:03', 'at *:13', 'at *:23', 'at *:33', 'at *:43', 'at *:53',
            -- 'every 10 minutes',
    data =
        rows =
            history = true, maxItems = 300, maxHours = 48, -- max is whatever is reached first (what will be written to csv is a subset of this)
    logging =
        level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
        marker = 'createCSV',
    execute = function(dz)
        local dataTable = {}
        -- Enter header line of your csv text file (or nil if you don't need one )
        -- Enter devicenames / methods in the required order. This will determine what attribute-values will be written to the csvFile
        -- Enter location/name of your csv text file
        -- Enter time-span to be written to csv file
        local header =  'now,inside,target,outside,lounge,greenhouse,heating'
        dataTable[1] = dz.time.rawTime:sub(1, 4) .. '0' -- consistent times even if script is not triggered precisely every x0 minutes
        dataTable[2] = dz.utils.round(dz.devices('inside').temperature, 1)
        dataTable[3] = dz.utils.round(dz.devices('target').temperature, 1)
        dataTable[4] = dz.utils.round(dz.devices('outside').temperature, 1)
        dataTable[5] = dz.utils.round(dz.devices('lounge').temperature, 1)
        dataTable[6] = dz.utils.round(dz.devices('greenhouse').temperature, 1)
        dataTable[7] = dz.devices('heating').active and 5 or 0
        local output = '/tmp/myFile.csv' -- location/name of your csv text file
        local span   = '23:59:00'  -- time-span to be written to csv file
        -- No changes required below these lines
        local function makePersistentData()
            local row = {}
            for index, value in ipairs(dataTable) do
                row[index] = value
            return row
        local function writeCSV()
            local relevantRows = dz.data.rows.subsetSince(span)
            local csvFile = assert(io.open(output, "w"))
            if header then csvFile:write(header ..'\n') end
            for index = #relevantRows, 1, -1 do
                dz.log(table.concat(relevantRows[index].data, ','), dz.LOG_DEBUG)
                csvFile:write(table.concat(relevantRows[index].data, ',') ..'\n')
            csvFile:close()
            dz.log((#relevantRows) .. ' data-rows written.', dz.LOG_DEBUG)
        -- main
        dz.data.rows.add(makePersistentData())  -- store in persistent historical data
        writeCSV()
Mibeus
Re: DzVents script to create CSV file for further processing
Post by Mibeus »
this is excellent.
Please can you help me for modification? I need log one month. I dont know what I need change for log more as 24 hours. Now I have this modification for more data limits but still after 24 hours stop recording.
return
    on = { timer = {'every 1 hours'},
    data =
        rows =
            history = true, maxItems = 3000, maxHours = 3000, -- max is whatever is reached first (what will be written to csv is a subset of this)
    logging =
        local header =  'Date,Time,SMT Humidity,SMT Temperature, THT Humidity,THT Temperature, Operators Humidity, Operators Temperature, CC1 Humidity, CC1 Temperature, CC2 Humidity, CC2 Temperature, Storage Humidity, Storage Temperature'
        dataTable[1] = dz.time.rawDate
        dataTable[2] = dz.time.rawTime:sub(1, 4) .. '0' -- consistent times even if script is not triggered precisely every x0 minutes
        dataTable[3] = dz.utils.round(dz.devices('SMTsensor').humidity, 1)
        dataTable[4] = dz.utils.round(dz.devices('SMTsensor').temperature, 1)
        dataTable[5] = dz.utils.round(dz.devices('THTsensor').humidity, 1)
        dataTable[6] = dz.utils.round(dz.devices('THTsensor').temperature, 1)
        dataTable[7] = dz.utils.round(dz.devices('Operatorssensor').humidity, 1)
        dataTable[8] = dz.utils.round(dz.devices('Operatorssensor').temperature, 1)
        dataTable[9] = dz.utils.round(dz.devices('CC1sensor').humidity, 1)
        dataTable[10] = dz.utils.round(dz.devices('CC1sensor').temperature, 1)
        dataTable[11] = dz.utils.round(dz.devices('CC2sensor').humidity, 1)
        dataTable[12] = dz.utils.round(dz.devices('CC2sensor').temperature, 1)
        dataTable[13] = dz.utils.round(dz.devices('Storagesensor').humidity, 1)
        dataTable[14] = dz.utils.round(dz.devices('Storagesensor').temperature, 1)
        local output = '/home/pi/Desktop/GPV_data/Humidity'..dz.time.rawDate..'.csv' -- location/name of your csv text file
            local row = {}
                row[index] = value
            return row
            csvFile:close()
        -- main
        writeCSV()
Mibeus wrote: Monday 03 May 2021 19:22 this is excellent.
does it really stops recording? you can check by looking at first and last entry in the data file.
(<domoticz dir>/scripts/dzVents/data/__data_<scriptname>.lua)
Can you try changing line
to
            local relevantRows = dz.data.rows.subset(1)
Mibeus
Post by Mibeus »
This is file
2021-05-02,20:00,43.0,19.0,39.0,19.9,41.0,21.9,41.0,21.8,41.0,22.0,38.0,22.8
2021-05-02,21:00,43.0,18.8,39.0,19.6,41.0,21.7,41.0,21.5,41.0,21.9,38.0,22.7
2021-05-02,22:00,44.0,18.6,40.0,19.5,41.0,21.6,41.0,21.3,42.0,21.7,39.0,22.5
2021-05-02,23:00,44.0,18.4,40.0,19.3,41.0,21.4,41.0,21.1,42.0,21.5,39.0,22.4
2021-05-03,00:00,44.0,18.2,40.0,19.0,41.0,21.3,42.0,20.9,42.0,21.4,39.0,22.3
2021-05-03,01:00,44.0,18.0,40.0,18.9,41.0,21.2,42.0,20.8,42.0,21.2,39.0,22.2
2021-05-03,02:00,44.0,17.7,40.0,18.6,41.0,21.0,41.0,20.6,41.0,21.1,39.0,22.1
2021-05-03,03:00,44.0,17.6,39.0,18.5,41.0,20.9,41.0,20.5,41.0,21.0,38.0,22.0
2021-05-03,04:00,44.0,17.1,40.0,18.1,41.0,20.6,41.0,20.2,41.0,20.8,38.0,21.8
2021-05-03,05:00,44.0,17.0,40.0,18.0,41.0,20.4,41.0,20.1,41.0,20.6,38.0,21.6
2021-05-03,06:00,44.0,16.8,39.0,18.0,40.0,20.3,41.0,19.9,41.0,20.4,38.0,21.5
2021-05-03,07:00,41.0,18.5,37.0,19.2,40.0,20.7,40.0,20.8,40.0,20.8,37.0,21.6
2021-05-03,08:00,38.0,21.1,35.0,20.8,39.0,21.2,38.0,22.2,40.0,21.4,37.0,21.8
2021-05-03,09:00,36.0,22.5,33.0,22.0,38.0,21.7,37.0,22.7,38.0,22.0,36.0,22.1
2021-05-03,10:00,34.0,23.5,32.0,23.0,37.0,22.2,36.0,23.0,38.0,22.5,35.0,22.5
2021-05-03,11:00,32.0,24.4,29.0,23.8,36.0,22.7,35.0,23.6,37.0,22.9,34.0,22.8
2021-05-03,12:00,30.0,24.9,28.0,24.3,35.0,23.1,33.0,23.9,35.0,23.0,33.0,23.0
2021-05-03,13:00,29.0,25.1,27.0,24.5,34.0,23.0,32.0,24.8,35.0,23.1,32.0,23.2
2021-05-03,14:00,28.0,25.6,26.0,25.0,34.0,23.2,32.0,25.4,34.0,23.2,32.0,23.4
2021-05-03,15:00,28.0,26.2,26.0,25.5,34.0,23.5,31.0,25.3,35.0,22.5,31.0,23.6
2021-05-03,16:00,27.0,26.5,25.0,25.9,33.0,23.7,31.0,24.9,34.0,22.2,31.0,23.9
2021-05-03,17:00,27.0,26.7,24.0,26.0,33.0,23.9,30.0,24.9,34.0,22.5,30.0,24.0
2021-05-03,18:00,26.0,26.8,24.0,26.1,32.0,24.0,30.0,24.8,34.0,22.3,30.0,24.1
2021-05-03,19:00,25.0,26.6,23.0,26.0,31.0,24.0,29.0,24.6,33.0,22.0,29.0,24.0
Mibeus wrote: Monday 03 May 2021 20:53 This is file
This is the csv file. What are the first and last record of the persistent data file? (see my previous post)
Mibeus
Post by Mibeus »
this is first rows
-- Persistent Data
local multiRefObjects = {
} -- multiRefObjects
local obj1 = {
	["rows"] = {
and last
return obj1
Mibeus wrote: Monday 03 May 2021 22:05 this is first rows
and last
Between these first and last rows you will find the actual records. I am interested in the first and last record. They will look similar to
               [1] = {
                        ["time"] = "2021-5-3 22:0:0.168";
                        ["data"] = {
                                [1] = "2021-05-04";
                                [2] = "00:00";
                                [3] = 52.0;
                                [4] = 12.0;
btw it is probably a bad idea to use persistent historical data for a months worth of hourly data of these sensors. It will slow down dzVents quite significant.
Performance wise it would probably be (much) better to trigger an offline OS script to do the work for you.
What is your domoticz version ?
waaren wrote: Tuesday 04 May 2021 0:13 Performance wise it would probably be (much) better to trigger an offline OS command to do the work for you.
New version without persistent Historical data
    Requires:
        dzVents 3.1.0
        Linux based system with awk
    22:10,21.2,7.0,12.7,21.3,11.8,0   [oldest data: set by user]
    22:20,21.1,7.0,12.7,21.3,11.8,0   [next data: depends on script execution frequency]
        History:
        20210504: Do not use historical persistent data as it slows down domoticz when having large amount of records
local datafileHousekeepingTimerule = 'at 05:37' -- choose a quiet time on your system
return
    on =
        timer =
            'every hour',
            datafileHousekeepingTimerule,
    logging =
    execute = function(dz,item,info)
        local row = {}
        -- Enter time-span to be written to csv file in daysInCSV
        row[1] = dz.time.rawDate
        row[#row+1]= dz.time.rawTime:sub(1, 4) .. '0' -- consistent times even if script is not triggered precisely every x0 minutes
        row[#row+1]= dz.utils.round(dz.devices('SMTsensor').humidity, 1)
        row[#row+1]= dz.utils.round(dz.devices('SMTsensor').temperature, 1)
        row[#row+1]= dz.utils.round(dz.devices('THTsensor').humidity, 1)
        row[#row+1]= dz.utils.round(dz.devices('THTsensor').temperature, 1)
        row[#row+1]= dz.utils.round(dz.devices('Operatorssensor').humidity, 1)
        row[#row+1]= dz.utils.round(dz.devices('Operatorssensor').temperature, 1)
        row[#row+1]= dz.utils.round(dz.devices('CC1sensor').humidity, 1)
        row[#row+1] = dz.utils.round(dz.devices('CC1sensor').temperature, 1)
        row[#row+1] = dz.utils.round(dz.devices('CC2sensor').humidity, 1)
        row[#row+1] = dz.utils.round(dz.devices('CC2sensor').temperature, 1)
        row[#row+1] = dz.utils.round(dz.devices('Storagesensor').humidity, 1)
        row[#row+1] = dz.utils.round(dz.devices('Storagesensor').temperature, 1)
        local csvFile = '/home/pi/Desktop/GPV_data/Humidity' .. dz.time.rawDate .. '.csv' -- location/name of your csv text file
        local daysInCSV = 31
        local dataFile = 'scripts/dzVents/data/__data_' ..  info.scriptName
        local function appendRow2Data(row)
            local out = assert(io.open(dataFile, "a"))
            out:write(table.concat(row, ',') ..'\n')
            out:close()
        local function cleanDatafile(cutofDate)
            local tmp = os.tmpname()
            local cmd =  'awk -v d="' .. cutofDate .. '" \'$1 > d\' ' .. dataFile .. ' >> '  .. tmp .. '; mv -f ' .. tmp .. ' ' .. dataFile
            dz.executeShellCommand(cmd)
        local function createCSVfile(fromDate)
            local out = assert(io.open(csvFile, "w"))
            local cmd =  'awk -v d="' .. fromDate .. '" \'$1 > d\' ' .. dataFile .. ' >> '  .. csvFile -- strips old dates from data
            if header then
                out:write(header ..'\n')
                out:close()
        local function makeFromDate(d)
            return dz.time.addDays(-d).rawDate
        -- main
        if dz.time.matchesRule(datafileHousekeepingTimerule) then
            cleanDatafile(makeFromDate(daysInCSV + 30 ) )
            appendRow2Data(row)
            createCSVfile(makeFromDate(daysInCSV))
Mibeus
Post by Mibeus »
Here is full script :)
-- Persistent Data
local obj1 = {
	["rows"] = {
		[1] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "15:00";
				[3] = 30.0;
				[4] = 26.5;
				[5] = 29.0;
				[6] = 26.0;
				[7] = 37.0;
				[8] = 25.2;
				[9] = 33.0;
				[10] = 25.9;
				[11] = 38.0;
				[12] = 23.6;
				[13] = 36.0;
				[14] = 24.9;
			["time"] = "2021-5-4 13:0:0.50";
		[2] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "14:00";
				[3] = 31.0;
				[4] = 26.6;
				[5] = 29.0;
				[6] = 26.1;
				[7] = 39.0;
				[8] = 25.3;
				[9] = 34.0;
				[10] = 26.1;
				[11] = 38.0;
				[12] = 23.6;
				[13] = 38.0;
				[14] = 24.8;
			["time"] = "2021-5-4 12:0:0.129";
		[3] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "13:00";
				[3] = 31.0;
				[4] = 27.0;
				[5] = 30.0;
				[6] = 26.4;
				[7] = 42.0;
				[8] = 24.9;
				[9] = 36.0;
				[10] = 25.7;
				[11] = 39.0;
				[12] = 24.0;
				[13] = 40.0;
				[14] = 24.6;
			["time"] = "2021-5-4 11:0:0.140";
		[4] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "12:00";
				[3] = 33.0;
				[4] = 25.7;
				[5] = 34.0;
				[6] = 25.0;
				[7] = 64.0;
				[8] = 21.4;
				[9] = 39.0;
				[10] = 24.3;
				[11] = 41.0;
				[12] = 23.1;
				[13] = 45.0;
				[14] = 24.1;
			["time"] = "2021-5-4 10:0:0.314";
		[5] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "11:00";
				[3] = 31.0;
				[4] = 25.7;
				[5] = 32.0;
				[6] = 24.9;
				[7] = 37.0;
				[8] = 24.0;
				[9] = 36.0;
				[10] = 24.2;
				[11] = 45.0;
				[12] = 23.1;
				[13] = 41.0;
				[14] = 23.8;
			["time"] = "2021-5-4 9:0:0.195";
		[6] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "10:00";
				[3] = 29.0;
				[4] = 25.7;
				[5] = 28.0;
				[6] = 25.1;
				[7] = 33.0;
				[8] = 24.3;
				[9] = 32.0;
				[10] = 24.3;
				[11] = 35.0;
				[12] = 22.5;
				[13] = 33.0;
				[14] = 23.9;
			["time"] = "2021-5-4 8:0:0.176";
		[7] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "09:00";
				[3] = 28.0;
				[4] = 25.0;
				[5] = 27.0;
				[6] = 24.4;
				[7] = 32.0;
				[8] = 23.9;
				[9] = 31.0;
				[10] = 23.7;
				[11] = 34.0;
				[12] = 22.3;
				[13] = 32.0;
				[14] = 23.7;
			["time"] = "2021-5-4 7:0:0.202";
		[8] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "08:00";
				[3] = 28.0;
				[4] = 24.2;
				[5] = 26.0;
				[6] = 23.6;
				[7] = 31.0;
				[8] = 23.4;
				[9] = 31.0;
				[10] = 23.0;
				[11] = 33.0;
				[12] = 22.7;
				[13] = 31.0;
				[14] = 23.4;
			["time"] = "2021-5-4 6:0:0.229";
		[9] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "07:00";
				[3] = 28.0;
				[4] = 23.5;
				[5] = 26.0;
				[6] = 22.9;
				[7] = 31.0;
				[8] = 23.0;
				[9] = 31.0;
				[10] = 22.8;
				[11] = 32.0;
				[12] = 23.1;
				[13] = 30.0;
				[14] = 23.3;
			["time"] = "2021-5-4 5:0:0.267";
		[10] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "06:00";
				[3] = 28.0;
				[4] = 23.3;
				[5] = 26.0;
				[6] = 22.6;
				[7] = 31.0;
				[8] = 22.9;
				[9] = 31.0;
				[10] = 22.8;
				[11] = 32.0;
				[12] = 22.9;
				[13] = 30.0;
				[14] = 23.2;
			["time"] = "2021-5-4 4:0:0.295";
		[11] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "05:00";
				[3] = 28.0;
				[4] = 23.2;
				[5] = 26.0;
				[6] = 22.7;
				[7] = 31.0;
				[8] = 22.9;
				[9] = 31.0;
				[10] = 22.9;
				[11] = 32.0;
				[12] = 23.0;
				[13] = 30.0;
				[14] = 23.3;
			["time"] = "2021-5-4 3:0:0.337";
		[12] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "04:00";
				[3] = 28.0;
				[4] = 23.2;
				[5] = 26.0;
				[6] = 22.7;
				[7] = 32.0;
				[8] = 23.0;
				[9] = 31.0;
				[10] = 22.8;
				[11] = 32.0;
				[12] = 23.0;
				[13] = 30.0;
				[14] = 23.3;
			["time"] = "2021-5-4 2:0:0.350";
		[13] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "03:00";
				[3] = 28.0;
				[4] = 22.9;
				[5] = 27.0;
				[6] = 22.4;
				[7] = 32.0;
				[8] = 23.0;
				[9] = 31.0;
				[10] = 22.9;
				[11] = 32.0;
				[12] = 23.9;
				[13] = 30.0;
				[14] = 23.3;
			["time"] = "2021-5-4 1:0:0.428";
		[14] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "02:00";
				[3] = 28.0;
				[4] = 22.9;
				[5] = 27.0;
				[6] = 22.4;
				[7] = 32.0;
				[8] = 23.1;
				[9] = 31.0;
				[10] = 23.1;
				[11] = 33.0;
				[12] = 23.4;
				[13] = 31.0;
				[14] = 23.4;
			["time"] = "2021-5-4 0:0:0.489";
		[15] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "01:00";
				[3] = 28.0;
				[4] = 23.2;
				[5] = 27.0;
				[6] = 22.6;
				[7] = 32.0;
				[8] = 23.2;
				[9] = 31.0;
				[10] = 23.6;
				[11] = 33.0;
				[12] = 23.0;
				[13] = 31.0;
				[14] = 23.5;
			["time"] = "2021-5-3 23:0:0.461";
		[16] = {
			["data"] = {
				[1] = "2021-05-04";
				[2] = "00:00";
				[3] = 28.0;
				[4] = 23.9;
				[5] = 26.0;
				[6] = 23.2;
				[7] = 32.0;
				[8] = 23.3;
				[9] = 31.0;
				[10] = 24.1;
				[11] = 33.0;
				[12] = 23.3;
				[13] = 31.0;
				[14] = 23.7;
			["time"] = "2021-5-3 22:0:0.540";
		[17] = {
			["data"] = {
				[1] = "2021-05-03";
				[2] = "23:00";
				[3] = 27.0;
				[4] = 24.5;
				[5] = 26.0;
				[6] = 23.7;
				[7] = 32.0;
				[8] = 23.5;
				[9] = 31.0;
				[10] = 23.7;
				[11] = 33.0;
				[12] = 23.7;
				[13] = 30.0;
				[14] = 23.7;
			["time"] = "2021-5-3 21:0:0.34";
		[18] = {
			["data"] = {
				[1] = "2021-05-03";
				[2] = "22:10";
				[3] = 27.0;
				[4] = 25.0;
				[5] = 25.0;
				[6] = 24.4;
				[7] = 32.0;
				[8] = 23.6;
				[9] = 31.0;
				[10] = 23.1;
				[11] = 33.0;
				[12] = 22.6;
				[13] = 30.0;
				[14] = 23.8;
			["time"] = "2021-5-3 20:11:0.225";
		[19] = {
			["data"] = {
				[1] = "2021-05-03";
				[2] = "22:10";
				[3] = 27.0;
				[4] = 25.0;
				[5] = 25.0;
				[6] = 24.4;
				[7] = 32.0;
				[8] = 23.6;
				[9] = 31.0;
				[10] = 23.0;
				[11] = 33.0;
				[12] = 22.6;
				[13] = 30.0;
				[14] = 23.8;
			["time"] = "2021-5-3 20:10:0.294";
		[20] = {
			["data"] = {
				[1] = "2021-05-03";
				[2] = "22:00";
				[3] = 27.0;
				[4] = 25.0;
				[5] = 25.0;
				[6] = 24.4;
				[7] = 32.0;
				[8] = 23.6;
				[9] = 31.0;
				[10] = 23.0;
				[11] = 34.0;
				[12] = 22.6;
				[13] = 30.0;
				[14] = 23.8;
			["time"] = "2021-5-3 20:9:0.193";
		[21] = {
			["data"] = {
				[1] = "2021-05-03";
				[2] = "22:00";
				[3] = 27.0;
				[4] = 25.0;
				[5] = 25.0;
				[6] = 24.4;
				[7] = 32.0;
				[8] = 23.6;
				[9] = 30.0;
				[10] = 23.0;
				[11] = 34.0;
				[12] = 22.6;
				[13] = 30.0;
				[14] = 23.8;
			["time"] = "2021-5-3 20:8:0.167";
return obj1
Mibeus
Post by Mibeus »
Hello this edit works, now saving continous over day.
Best solution will be save this data in internal database, but this is over me :(.
Now saveing every 5 minutes into sqllite. But I need save only one per hour but during 2 years :(.
waaren wrote: Monday 03 May 2021 20:42
to
My version of Domoticz is
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3
Mibeus wrote: Wednesday 05 May 2021 0:21 Best solution will be save this data in internal database, but this is over me :(.
Now saving every 5 minutes into sqlite. But I need save only one per hour but during 2 years :(.
You might want to look at influxDB. Seems to be an exact match for your requirements.
