Something strange.
I made a virtual sensor for Temp+Hum+Baro
All looks normal. In Devices I see the sensor and the data field contains the items 0.0C,50%,1010hPa
But after I ran my python/json script this field changed into : 0, 9.0;70.0;1030.03
The values 9.0 70.0 and 1030.03 are ok but what is the 0, at the first position coming from?
Because of this the sensor is not working.
The log file shows that every thing is ok and there is no 0, in the json call.
Who can see what I do wrong?
curl -s "http://192.168.2.235:8080/json.htm?type ... .0;1030.03"
"status" : "OK",
"title" : "Update Device"
I will attach the Python script to this case.
Strange 0, in the Device data field. (temp/hum/baro) Topic is solved
willem9136
- Domoticz version: 2026.2
- weer.py.zip
- (779 Bytes) Downloaded 63 times
- waaren
re: Strange 0, in the Device data field. (temp/hum/baro)
This type of sensor expects 5 values in svalue (separated by semicolons).willem9136 wrote: Friday 16 April 2021 13:24 I made a virtual sensor for Temp+Hum+Baro
See API / JSON wiki
willem9136
Re: Strange 0, in the Device data field. (temp/hum/baro)
Solved. Supplied 5 Paramus.
