MQTT switch on rpi1 and light on rpi2
goblin
Domoticz version: 2023.1
Post by goblin »
hello experts,
i have two Rpi's with Domoticz and want to use a switch button on the client to switch a light on the server and v.v. via MQTT
Sounds simple but can't get it work.
assume i have a situation like mentioned in "https://www.domoticz.com/wiki/MQTT#Architecture" where "other" is my second Rpi.
Can i use "on Action/Off Action" at edit light-switch ?
Thanks,
RPI 3
Mysensors gateway,
rflink Gateway
esp8266
Domoticz version: 2025.1
Re: MQTT switch on rpi1 and light on rpi2
goblin wrote: Thursday 15 April 2021 23:10 Can i use "on Action/Off Action" at edit light-switch ?
If there is no specific need to use MQTT you could simply use
http://<target domoticz ip: target domoticz port>/json.htm?type=command&param=switchlight&idx=<target device idx>&switchcmd=On
http://<target domoticz ip: target domoticz port>/json.htm?type=command&param=switchlight&idx=<target device idx>&switchcmd=Off
in the On Action / Off Action fields of the edit switch screen of the source system.
You will have to allow password-less access for your home LAN (Settings: LOcal Networks (no username / password) or include passwords in the JSON API for this to work.
Using this method you are not limited by the requirements of the shared devices setup (same endian / same version)
xury
Post by xury »
I've done a Node-Red flow named Domoticz to Domoticz. You can adapt it to you. Is available on the node Red site.
With kind of switch device you use?
goblin
Post by goblin »
tenx
let's dive into it this weekend.
should get something to work :P
