build 13151 seems to break the script 'graaddagen'  [Solved]
plugge
Post by plugge »
Since build 13151 the script graaddagen (below) breaks:
2021-04-13 03:38:00.239  Error: dzVents: Error: (3.1.7) graaddagen: An error occurred when calling event handler graaddagen
2021-04-13 03:38:00.239  Error: dzVents: Error: (3.1.7) graaddagen: ...omoticz\scripts\dzVents\generated_scripts/graaddagen.lua:57: attempt to index a nil value (local '_')
13151 removed duplicate templates https://github.com/domoticz/domoticz/co ... 02992a886a
Maybe that has something to do with it?
waaren wrote: Wednesday 11 November 2020 16:26 Below example uses lodash (standard packaged with dzVents) to do the iteration for you
local scriptVar = 'averageTemp'
return
    on =
        timer =
            'at 23:45',
        httpResponses =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
        marker = scriptVar,
    execute = function(dz, item)
        local _ = dz.utils._           -- lodash
        if item.isTimer then
            dz.log('Calling dz temp average..', dz.LOG_DEBUG)
            dz.openURL(
                -- 131 outdoor temp sensor
                url = dz.settings['Domoticz url'] ..  '/json.htm?type=graph&sensor=temp&idx=131&range=month',
                callback = scriptVar,
            return
        if item.isHTTPResponse and item.isJSON then
            local heatingStart = 18 -- standard correction factor
            local rt = item.json.result
            dz.log('Finding today in the result table using lodash find', dz.LOG_DEBUG)
            local today = _.find(rt, function (rt) return rt.d == dz.time.rawDate end )
            if today and ( heatingStart - today.ta ) > 0 then
                -- idx 267 Graaddagen dummy sensor
                dz.log('Average temp for today is ' .. dz.utils.round(today.ta, 2 ) .. ' °C ', dz.LOG_DEBUG)
                dz.devices(267).updateTemperature( dz.utils.round( today.ta, 2 ) )
            dz.log('Return table is not OK', dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
Re: build 13151 seems to break the script 'graaddagen'
plugge wrote: Tuesday 13 April 2021 11:09 Since build 13151 the script graaddagen (below) breaks:
thx for reporting!
Is indeed caused by a change in this commit. Will be fixed in a next build but you can already workaround it by changing
line
to
       local _ = require('lodash')          -- lodash
