How to monitor if Domoticz is still functioning correctly?
Hesmink
Hello All,
Probably answered somewhere, but searching the forum for 'monitor' and 'Domoticz' doesn't really help.
Today I noticed Domoticz was down (crashed because my hs110 smart plug did not function correctly).
I do have a slave Domoticz instance that monitors my energy usage, so I'm thinking of also using that second instance to monitor the primary one (and vice versa).
Has anything already been build for that?
Is there an 'alive' query I can send to a Domoticz server that indicates that it is still functioning correctly?
Maxx
Re: How to monitor if Domoticz is still functioning correctly?
Did something like this some time ago. There are probably better ways to do this but this works for me
Adapt for your system by using your own ip addresses and make the required devices
Put this script in your Secondary system:
And this in your main system:
devices = {},
timer = {'every minute'},
data = { heartbeatCounter = { initial = 0 },
State = { initial = 0 },
timeOut = { initial = 0 },
execute = function(dz, triggeredItem)
local HeartcheckOut = dz.devices('HeartcheckMirror')
if dz.data.State == 0 then
dz.log('Increase heartbeat and send to main')
dz.data.heartbeatCounter = dz.data.heartbeatCounter + 1
local string = 'http://192.168.1.231:8080/json.htm?type=command¶m=udevice&idx=5247&nvalue=0&svalue=' .. dz.data.heartbeatCounter
dz.log(string)
dz.openURL({
url = string,
method = 'GET',
callback = 'dataRetrieved'
dz.data.timeOut = 0
dz.data.State = 1
elseif dz.data.State == 1 then
dz.log('Wait for heartbeat from main')
dz.data.timeOut = dz.data.timeOut + 1
dz.log(HeartcheckOut.counter)
dz.log(dz.data.heartbeatCounter)
dz.log('Timeout timer : ' .. dz.data.timeOut)
if HeartcheckOut.counter == dz.data.heartbeatCounter then
dz.data.State = 0
elseif dz.data.timeOut > 10 then
dz.data.State = 2
elseif dz.data.State == 2 then
dz.log('No response from main')
local text = "No response domoticz main"
dz.notify('Heartbeat ',text,dz.PRIORITY_HIGH,dz.NSS_TELEGRAM)
dz.data.timeOut = 0
dz.data.State = 0
}And this in your main system:
devices = {},
-- logging = {level = domoticz.LOG_DEBUG,
-- marker = "Heart"},
local HeartbeatIn = dz.devices('Heart')
dz.log(HeartbeatIn.counter)
dz.openURL({
url = 'http://192.168.1.232:8080/json.htm?type=command¶m=udevice&idx=33&nvalue=0&svalue='.. HeartbeatIn.counter,
method = 'GET',
}- waltervl
- Domoticz version: 2025.1
For standard monitoring on the primary device (but also on the secondary) you can follow the instructions in the wiki using the application monit:
https://www.domoticz.com/wiki/Monitoring_domoticz
They use the json command url:
and content should have a value with '"status" : "OK"'
You can do the same with a dzVents script if you just want to check the primary from the slave.
http://127.0.0.1:8080/json.htm?type=command¶m=getversionYou can do the same with a dzVents script if you just want to check the primary from the slave.
- Antori91
- Domoticz version: 4.10717
I use this own code (nodeJS code) to both monitor main and backup domoticz servers (and also Mqtt). If main or backup Domoticz is detected down, it tries to restart Domoticz. This code also synchronizes (using Mqtt) choosen devices between main and backup domoticz databases: https://github.com/Antori91/Home_Automa ... Cluster.js
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
Hesmink
Thanks all, I opted for using a modified version of the simple bash shell script from the Wiki.
I modified it to only send a notification once, and use Pushover instead of Telegram.
- erem
- Domoticz version: 2021.1
Here is my script to check if Domoticz is active, and restart it if not.
#!/bin/bash
# program : check-domoticz-active.sh
# programmer : RM
# date : 2020-02-21
# install in cron with crontab -e to run every 5 minutes
# m h dom mon dow command
# */5 * * * * /home/pi/domoticz/scripts/check-domoticz-active.sh >/dev/null 2>&1
# prerequisites
# jq installed (apt-get install jq)
# make sure the cron entry (example above)has the full path to the script!!
# revision
# 0.0.1 2020-23-21 initial release
i=0
while [ $i -lt 3 ]
do
# check if domoticz responds to a json query
DOMOTICZ=`curl -s --connect-timeout 2 --max-time 5 "http://127.0.0.1:8080/json.htm?type=devices&rid=1"`
STATUS=`echo $DOMOTICZ | jq -r '.status'`
if [ "$STATUS" == "OK" ] ; then
echo "Domoticz responded"
break # all ok
i=$(( $i + 1 ))
echo "Domoticz did not respond on try $i "
fi
sleep 5
done
# if we do not have an OK, domoticz did not respond, stop and start it
if [ "$STATUS" != "OK" ] ; then
echo "Stopping domoticz"
sudo systemctl stop domoticz.service
sleep 10
echo "Starting domoticz"
NOW=$(date +"%Y-%m-%d %H:%M:%S")
sudo systemctl start domoticz.service
Exitcode=$? # save systemctl exit code
if [ $Exitcode != 0 ] ; then
echo "$NOW - sudo systemctl start domoticz.service failed with exit code $Exitcode"
echo "$NOW - sudo systemctl start domoticz.service completed with exit code $Exitcode"
fi
fi
# end of source
Regards,
Rob
Rob
twoenter
I use monit. I wrote a complete setup tutorial about it for synology nas:
https://www.twoenter.nl/blog/domoticz/d ... met-monit/
Blog is in Dutch but you can translate with google if you need to
Check my Domoticz tutorials, ESP8266 and Synology blog at https://www.twoenter.nl/blog
jannl
- Domoticz version: 2025.5.x
This is my script, I also check if I (or someone else) is logged on, in that case I do not want Domoticz to be restarted, because it is most likely down intentionally.
#!/bin/bash
# check domoticz
#-m 10 beperkt de duur tot 10 seconden
WHOCOUNT=$( who | wc -l )
if [[ "${WHOCOUNT}" != 0 ]]
then
echo "Someone is logged on. No further actions" >&2
exit
fi
status=`curl -m 20 -s -i -H "Accept: application/json" "http://192.168.1.2:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g
if [ $status ]
then
echo "Domoticz is al gestart"
sudo /etc/init.d/domoticz.sh stop
sleep 30
sudo /etc/init.d/domoticz.sh start
status=`curl -s --form-string "token=XXXX" --form-string "user=XXXX" --form-string "message=Domoticz is opnieuw gestart" https://api.pushover.net/1/messages.json`
fi
lost
Hello,erem wrote: Sunday 11 April 2021 16:45 Here is my script to check if Domoticz is active, and restart it if not.
Just take care that domoticz service may still be up, with event system still running (schedules/scripts always done...) but web server side down so no user interaction possible.
In fact, this is what happened most to me in the past!
So checking service up may not always do the job & you may send a json query like other suggestions, or use httping (after install) in a simple cron triggered script.
On top of that, when http server side is down, stopping/restarting service may no work: At restart, in some situations http port bind was not possible because still 'in-use". I then had to restart whole system...
In the end, as domoticz down whatever the reason will always mean http server down, I just check this and after a retry the next minute, if still down I 1st restart service, wait 1mn for http server being up and if still down, do a full shutdown/reboot after saving last domoticz log lines for post-mortem debug if needed.
The /root/checkDomoticz.sh file:
#!/bin/bash
# Check domoticz (from a crontab) is up a restart whole PI if needed...
domoticzUrl=localhost:8080
BN=`basename $0`
WHOCOUNT=$(who | wc -l)
if [ ${WHOCOUNT} -ne 0 ]
then
logger $BN: Someone is logged on, no check.
exit 0
fi
httping -c 5 -i 0 -t 1 --ts -v -Wsqg $domoticzUrl
STATUS=$?
if [ ${STATUS} -ne 0 ]
then
logger $BN: Domoticz httping-ed KO, retry after 1mn...
sleep 1m
# Retry once
STATUS=$?
then
logger $BN: Still KO. Get last logs and try service restart then wait...
tail -n 20 /tmp/domoticz.txt | logger
service domoticz restart
sleep 1m
logger $BN: Check after service restart...
STATUS=$?
then
logger $BN: Still KO. Get last logs and REBOOT...
/sbin/shutdown --no-wall -r now
STATUS=$?
logger $BN: Service restart OK !
fi
logger $BN: Retry OK !
fi
logger $BN: Domoticz ALIVE !
fi
wait
logger $BN: DONE, status= ${STATUS} !!!
exit ${STATUS}
0,30 * * * * /root/checkDomoticz.sh > /dev/null 2>&1
Just don't forget to stop the cron/rename script when intentionally stopping domoticz service: I screwed a raspbian version update in the middle of the process, with then a non-bootable system & a full reinstall needed!
EDIT : Should add a apt lock check to this script, as I may forget about this when debian 11 will be out...
Added logged user check as suggested hereupper by Janni, that's much better!
