(TIP) Increase reception RFXcom433
- mbliek
I just bought this cheap 433 receiver for my RFXcom433 and all switches increased from 4 to 6. Most went 2 up.
You can stick it anywhere you want. And it has an nice long cable.
http://pages.ebay.com/link/?nav=item.vi ... 0935792243
Op zoek naar een Domoticz Start Set?
- sincze
- Domoticz version: 2024.4
Re: (TIP) Increase reception RFXcom433
Tnx. Unfortunately the seller is away.mbliek wrote:I just bought this cheap 433 receiver for my RFXcom433 and all switches increased from 4 to 6. Most went 2 up.
What exactly do you mean switches increased from 4-6 ?
Can that be viewed within Domoticz?
Sandor
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- mbliek
That's too bad.
On the devices tab you see an reception number.
The higher the number. The better the reception is.
roblom
This Store seller is currently away.
Holiday from 2014-9-30 till 2014-10-18,
Please add this Store to your Favorites and come again.
Thank you very much for visiting my store.
We apologize for any inconvenience occurred to you.
- mbliek
There are more antennas like this one.
I bought this one 2 weeks ago.
http://www.ebay.com/sch/i.html?_from=R4 ... a&_sacat=0
- sincze
Ah the links shows me all kind of antennas.mbliek wrote:There are more antennas like this one.
This is the one you mean?
http://www.ebay.com/itm/Antenna-433Mhz- ... 2577763d3e
Does it really work? I just have 1 door/sensor just out of range.
Sándor
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- mbliek
That one could be used.
The higher the dBi the better the range is.
http://www.ebay.com/itm/433Mhz-2-5dBi-a ... 589319081d
http://www.ebay.com/itm/Antenna-433Mhz- ... 2562b558a2
Sappien
A few weeks agot I orderd 2x 5 dBi antennas, and it working indeed much better. ( 1 for sale € 7,50 include shipping)
kimhav
- Domoticz version: 2023.2
Well, I got one of these antennas from ebay; http://www.ebay.com/itm/NEW-Antenna-433 ... netic-base:
vmb
Could you please send a link. I'm interestedSappien wrote:A few weeks agot I orderd 2x 5 dBi antennas, and it working indeed much better. ( 1 for sale € 7,50 include shipping)
vmb
Any experiences yet? Noticed any improvements?kimhav wrote:Well, I got one of these antennas from ebay; http://www.ebay.com/itm/NEW-Antenna-433 ... netic-base:
- bbqkees
- Domoticz version: 4.1x
Did anyone try to build a groundplane antenna like this one http://ukhas.org.uk/guides:payloadantenna?
To me it seems they will work better than the 1 piece antenna's like all in this topic.
I have ordered an extension cable to build such a groundplane antenna but it hasn't arrived yet.
Sappien
The 5 dBi i'm using is working great, without it I had some issues with the lamps in the garden.
vmb
thx! Nice to hear. Ordered one myself.Sappien wrote:The 5 dBi i'm using is working great, without it I had some issues with the lamps in the garden.
schmm
Do you have a link From where you bought it?Sappien wrote:A few weeks agot I orderd 2x 5 dBi antennas, and it working indeed much better. ( 1 for sale € 7,50 include shipping)
- sincze
Ordered one.mbliek wrote:I just bought this cheap 433 receiver for my RFXcom433 and all switches increased from 4 to 6. Most went 2 up.
Received it after 10 days.
And yes indeed it does AMP the reception a bit.
Now I have to figure out the exact placement to cover my 'whole' property.
Thanks for the tip!!
Such a nice forum to share ideas and best practices.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Calzor Suzay
- Target OS: -
- Domoticz version: 4.9700
Dragging up a thread but is the higher the dBi the better the boost/aerial will be?
For example this one claims to be 3 dBi http://www.ebay.co.uk/itm/3db-Antenna-4 ... 45f9e824aa
and this 5 dBi http://www.ebay.co.uk/itm/GSM-Antenna-4 ... 2ed86bc309
I'm looking at this style of aerial as it's behind the TV where the Raspberry Pi is.
Calzor Suzay
- Target OS: -
Well FYI I bought the second one of my links and although it's pretty small it does seem to be picking stuff up that previously didn't and was quite far away.
So far thumbs up although we'll see if it's effected by interference from people etc over time.
- bbqkees
I've got the same antenna a few weeks ago but it did not improve reception at all.Calzor Suzay wrote:Well FYI I bought the second one of my links and although it's pretty small it does seem to be picking stuff up that previously didn't and was quite far away.
Calzor Suzay
- Target OS: -
Maybe my original antenna is badly placed and this just improved it then.
I have it at the back of the house in the lounge where Raspberry Pi is plugged into the TV, I could get most stuff except the Garage (separate building) struggled to pick up motion sensor and I could never get sensor at the top of the stairs. It all seems to pick up fine now. I was a bit sceptical at first as the aerial is tiny, not much more than the original but (touch wood) seems to work ok so far
BTW my house is thick solid brick built, even internal walls.
