i have an outdoor waterproof box with a wemos d1 mini as well as a power supply. The MCU is connected to a temperature sensor. The MCU firmware is ESP EASY MEGA. I would like to have the temperature printed on another wemos d1 mini MCU in the same LAN with an LCD monitor connected. I don't cant find instructions on the subject, because I don't even know exactly what protocol it uses and what kind of code should esp easy to write in Megan setup lines. How read/receive temperature value/data from another wemos board which is in the same WLAN?
Or if this temp value could be read from device in domoticz
setup line (text box) there is line 1 to 4. What should be written in to this? here is some screen shot picked from web, I think the line1 -line4 is the place to write code, but what?
How to read data from another WEMOS D1 mini and to print it LCD screen Topic is solved
planedo79
- mega.jpg (50.12 KiB) Viewed 1273 times
- erem
- Domoticz version: 2021.1
Re: How to read data from another WEMOS D1 mini and to print it LCD screen
you may have more luck getting an answer on the ESPEasy forum, as this has nothing to do with domoticz.
here: https://www.letscontrolit.com/forum/vie ... 446134f11f
Regards,
Rob
Rob
- Treve
- Domoticz version: v4.11474
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
