Doors and Window status monitoring for heater control
franzelare
Post by franzelare »
Some airconditioning units for thermostats for heaters have a door open functionality, in case the door is open for more then x minutes the heater or cooler is disabled to save energy.
Since winter is coming and I now have door sensors installed and my heating runing through domoticz I started a script today to monitor doors and windows to stop my heating when the door is left open (later option would also be to send a notification)
The script is now setup for 8 doors and windows (just an easy number) and when one or more are open for more than 5 minutes the heater control setpoint is changed, the old value stored in a variable and when all doors and windows are closed again the old setpoint is put back in place.
When the setpoint is changed by this script, I also toggle a virtual switch, which i use to grey out the button to increase the temperature setpoint on my frontpage when the switch is active... and show a little door open icon
-- Purpose of this script is to power down the heating when doors or windows are open for over a number of minutes to safe energy by not heating up the entire globe.
-- The script is now set up for max 8 doors and 8 windows but could be extended to include items like a fire place or air conditioning units.
-- variable to be made is an integer "TempStorage" for temporarely storing the old temperature setpoint when powering down the heating
-- variable to be made is an integer "DoorCounter" to track the time a door is open
-- define the number of doors and windows to be monitored
Door_Count = 2			-- exact number of doors to be monitored (max 8 in current script)
Window_Count = 2		-- exact number of windows to be monitored (max 8 in current script)
Time_Out = 5			-- time in minutes for doors to be open before heating is powered off
Low_Temp = 5			-- setpoint to be used when powering off the heating
THERMOSTAT_NAME = 'WoonkamerSetpoint'		-- exact name of thermostat to be changed
TEMP_IDX = 102					-- idx of thermostat to be changed
TEMPDOWN_NAME = 'AutoTempDown'      --exact name of virual switch to temp down
TEMPDOWN_IDX = 229                  --idx of temp down switch
DOOR_NAME1 = 'VoorDeurSensor'		-- exact name of the door to be monitored
DOOR_NAME2 = 'SchuurDeur'	-- exact name of the door to be monitored
DOOR_NAME3 = 'AchterDeurSensor'		-- exact name of the door to be monitored
DOOR_NAME4 = 'NA'		-- exact name of the door to be monitored
DOOR_NAME5 = 'NA'		-- exact name of the door to be monitored
DOOR_NAME6 = 'NA'		-- exact name of the door to be monitored
DOOR_NAME7 = 'NA'		-- exact name of the door to be monitored
DOOR_NAME8 = 'NA'		-- exact name of the door to be monitored
WINDOW_NAME1 = 'RaamBenedenVoorLinks'		-- exact name of the window to be monitored
WINDOW_NAME2 = 'RaamBenedenVoorRechts'		-- exact name of the window to be monitored
WINDOW_NAME3 = 'NA'		-- exact name of the window to be monitored
WINDOW_NAME4 = 'NA'		-- exact name of the window to be monitored
WINDOW_NAME5 = 'NA'		-- exact name of the window to be monitored
WINDOW_NAME6 = 'NA'		-- exact name of the window to be monitored
WINDOW_NAME7 = 'NA'		-- exact name of the window to be monitored
WINDOW_NAME8 = 'NA'		-- exact name of the window to be monitored
PRINT_MODE = true		-- when true wil print output notifications to the log
PRINT_MODE_ALL = false		-- when true wil print output all data to the log
TEST_MODE = false
-- get the global variables:
Counter = tonumber(uservariables['DoorCounter'])
Temp_Storage = tonumber(uservariables['TempStorage'])
-- Retrieve values from devices
Dev_TempSetpoint = otherdevices_svalues[THERMOSTAT_NAME]
-- create local arrey's to store names and binary values
local DOOR_BIN = {1,1,1,1,1,1,1,1}
local DOOR_NAME = {DOOR_NAME1,DOOR_NAME2,DOOR_NAME3,DOOR_NAME4,DOOR_NAME5,DOOR_NAME6,DOOR_NAME7,DOOR_NAME8}
local WINDOW_BIN = {1,1,1,1,1,1,1,1}
local WINDOW_NAME = {WINDOW_NAME1,WINDOW_NAME2,WINDOW_NAME3,WINDOW_NAME4,WINDOW_NAME5,WINDOW_NAME6,WINDOW_NAME7,WINDOW_NAME8}
-- check if the counter is active and increment if so
if (Counter > 0) then
	Counter = Counter+1
	if PRINT_MODE == true then
	   	print('Incrementing door counter to ' .. Counter)
-- check the status of all doors
for i=1, Door_Count, 1 do
	if (otherdevices[DOOR_NAME[i]]=='Open') then
    	DOOR_BIN[i]=0
	        print('Door '.. DOOR_NAME[i] ..' is Open')
    elseif (otherdevices[DOOR_NAME[i]]=='Closed') then
        DOOR_BIN[i]=1
	        print('Door '.. DOOR_NAME[i] ..' is Closed')
        DOOR_BIN[i]=1
	        print('Door '.. DOOR_NAME[i] ..' has an incorrect status')
DOOR_SUM=0
for i=1, 8, 1 do
 	Current=tonumber(DOOR_BIN[i])
 	DOOR_SUM=DOOR_SUM+Current
	if PRINT_MODE_ALL == true then
 	    print('Door ' .. i .. ' bindary is ' .. DOOR_BIN[i])
     	print('Doorsum is ' .. DOOR_SUM)
-- check the status of all windows
for i=1, Window_Count, 1 do
	if (otherdevices[WINDOW_NAME[i]]=='Open') then
    	WINDOW_BIN[i]=0
	        print('Window '.. WINDOW_NAME[i] ..' is Open')
    elseif (otherdevices[WINDOW_NAME[i]]=='Closed') then
        WINDOW_BIN[i]=1
	        print('Window '.. WINDOW_NAME[i] ..' is Closed')
         WINDOW_BIN[i]=1
	        print('Window '.. WINDOW_NAME[i] ..' has an incorrect status')
WINDOW_SUM=0
for i=1, 8, 1 do
 	Current=tonumber(WINDOW_BIN[i])
 	WINDOW_SUM=WINDOW_SUM+Current
 	    print('Window ' .. i .. ' bindary is ' .. WINDOW_BIN[i])
     	print('Windowsum is ' .. WINDOW_SUM)
-- See if the counter has to be started
if (DOOR_SUM + WINDOW_SUM < 16) and (Counter == 0) then
	Counter = 1
			 if (DOOR_SUM < 8) then
			    print('DoorSum is ' .. DOOR_SUM)
			    print('A door has been openend starting counter')
			 if (WINDOW_SUM < 8) then
    			 print('WindowSum is ' .. WINDOW_SUM)
	    		 print('A window has been openend starting counter')
-- check if when the counter is running, the doors are open for more than the set limit and the heater has to be powered down
if (Counter == Time_Out) then
			print('A door or window is open for more than the preset time of ' .. Time_Out .. 'Minutes')
	commandArray[TEMPDOWN_NAME]='On'
	-- convert temperature livingroom into numbers
		Wu_TempSetpoint = tonumber(Dev_TempSetpoint)
		commandArray['Variable:TempStorage'] = tostring(Wu_TempSetpoint)
		print('Storing current heater setpiont of ' .. Wu_TempSetpoint .. 'C')
		print('Lowering the heating temperature to ' .. Low_Temp .. 'C')
	commandArray['UpdateDevice'] = TEMP_IDX .. '|0|' .. Low_Temp
-- when the counter is active, check if it has to be set back to 0 because all doors and windows are closed again
if (DOOR_SUM + WINDOW_SUM == 16) then
		   	print('All doors and windows are closed, check if the counter is runing and need to be stopped')
    if (otherdevices[TEMPDOWN_NAME] == 'On') then
    	commandArray[TEMPDOWN_NAME]='Off'
		    print('Timer was active for : ' .. Counter .. ' Minutes')
    		print('Restoring temperature setpoint to: ' .. Temp_Storage .. ' C')
	    commandArray['UpdateDevice'] = TEMP_IDX .. '|0|' .. Temp_Storage
	    Counter = 0
		    print('Timer is not active no action needed')
-- save the globals
commandArray['Variable:DoorCounter'] = tostring(Counter)
enjoy! and if you have any questions, or improvement suggestions, please let me know.
Dellie
Domoticz version: 4.9
Re: Doors and Window status monitoring for heater control
Post by Dellie »
Looks like a great script, way beyond my league but is supposed to do exactly what I want. Supprised there are no reactions at all.
Some questions
What kind of dummy switch should I make for the "AutoTempDown".
I only use 1 door magnet, so I set all the other door and windowswitches to 'NA' and 'Door_Count = 1' and 'Window_Count = 0'
What do you mean with "Low_Temp = 5 -- setpoint to be used when powering off the heating". Is this the temp the "THERMOSTAT" is set to when the door is open?
Would be great to get a reaction
