Today I have received my new switch from China Aqara Opple (6 buttons)
I have installed on Conbee II -> ok
Then the switch is also recognized by deCONZ
I have added the switch.
But when I press buttons on the switch I don't see reaction in the button log.
Has anyone an idea how I can install / use this switch?
Do I just need a good dzvents script, or is something wrong with the installation?
I hope anyone can help me.
Aqara Opple issue with deCONZ Topic is solved
Thorgal789
- Target OS: -
Re: Aqara Opple issue with deCONZ
Hello, you have set the debuf level at "debug info only" ?Obelix wrote: Thursday 25 March 2021 22:47 But when I press buttons on the switch I don't see reaction in the button log.
Can you show the device JSON (from log for exemple)
Wich one deconz version are you using ?
Have you tried a second inclusion ?
Thorgal789
- Target OS: -
You have solved your problem ?
Obelix
Yes,
problem is solved. The 's' button did the work,
thanks@
thanks@
