Presence detection using UniFi Controller and DzVents  [Solved]
rgroothuis
Re: Presence detection using UniFi Controller and DzVents
Post by rgroothuis »
waaren wrote: Thursday 25 March 2021 11:45
rgroothuis wrote: Thursday 25 March 2021 11:18 @waaren: just sent you a PM with the log file info.
I have not received it.
Sorry, my fault, made a mistake, it is sent now.
basmaaks
Post by basmaaks »
anybody here to help me out ?
Got myself a cloud key gen 2, this needs another way to authenticate. I modified the script to the code below, it works but the file domocookie.txt needs to be removed to get it work. Now I've got a bash script that removes the file domocookie.txt every 2 minutes. I think there should be a better solution but can't figure it out myself
        timer = { 'every 3 minutes' },
        -- domoticz.utils.osExecute("bash /home/pi/domoticz/scripts/remove.sh")
        httpResponses = { 'unifi_loggedin' , 'unifi_data' }
    data = {
        presenceHistory = { history = true, maxMinutes = 6 } 		-- Change maxMinutes value to appropriate for your devices
        local controllerUrl = 'https://192.168.178.42/' 	--Change IP and Port to your Unifi Controller settings
        local controllerLogin = 'some user'						-- Your username for Unifi Controller
        local controllerPassword = 'my password'-- Your password for Unifi Controller
        local devices = {
            ['fc:66:cf:8f:5d:6f'] = 784,	-- phone 1
            ['62:6e:70:7f:6b:45'] = 783,	-- phone 2
        if (item.isTimer) then
            domoticz.openURL({
                url = controllerUrl .. 'api/auth/login',
                method = 'POST',
                postData = {
                    ['password'] = controllerPassword,
                    ['username'] = controllerLogin
                callback = 'unifi_loggedin'
        if (item.isHTTPResponse and item.ok) then
            if (item.trigger == 'unifi_loggedin') then
                domoticz.openURL({
                    url = controllerUrl .. 'proxy/network/api/s/default/stat/sta',
                    method = 'GET',
                    callback = 'unifi_data'
            if (item.trigger == 'unifi_data') then
                local presenceHistory = domoticz.data.presenceHistory
                for mac, device in pairs(devices) do
                    local isPresent = string.find(item.data, mac)
                    presenceHistory.add({
                        ['mac'] = mac,
                        ['isPresent'] = not (isPresent == nil)
                    local wasPresent = presenceHistory.reduce(function(acc, item)
                        if (item.data.mac == mac and item.data.isPresent) then
                            acc = acc + 1
                        return acc
                    end, 0)
                    if (wasPresent == 0) then
                        domoticz.devices(device).switchOff().checkFirst()
                        domoticz.devices(device).switchOn().checkFirst()
basmaaks wrote: Saturday 15 May 2021 10:00 anybody here to help me out ?
You practically have a solution already in your script.
Can you try changing
            domoticz.openURL({
                method = 'POST',
                postData = {
to
             local cookie = 'full qualified name of coookie'
	    domoticz.utils.osExecute('rm ' .. cookie .. ' &' )
            domoticz.openURL({
                method = 'POST',
                postData = {
basmaaks
Post by basmaaks »
waaren wrote: Saturday 15 May 2021 10:22
            domoticz.openURL({
                method = 'POST',
                postData = {
to
            domoticz.openURL({
                method = 'POST',
                postData = {
Thanks, you are my hero !!! Works like a charm
basmaaks
Post by basmaaks »
Next question, apple device's uses a different Mac adres every time. How do I modify the script to find hostnames in stead of Mac addresses ?
    data = {
        local devices = {
            domoticz.openURL({
                method = 'POST',
                postData = {
                domoticz.openURL({
                    method = 'GET',
                        ['mac'] = mac,
                            acc = acc + 1
                        return acc
                    end, 0)
basmaaks
Post by basmaaks »
basmaaks wrote: Monday 24 May 2021 11:40
    data = {
        local devices = {
            domoticz.openURL({
                method = 'POST',
                postData = {
                domoticz.openURL({
                    method = 'GET',
                        ['mac'] = mac,
                            acc = acc + 1
                        return acc
                    end, 0)
Never mind, find the solution myself. Had a - in the hostname and that's not working. Now with one "kfhasdjaksdk" its working perfect !
rgroothuis
The json response is also giving the device name back, besides the MAC address. You can check on device name as well. I can share my script (created with support from Warren) if you are interested. Currently not at home, cannot copy and paste. Let me know if you need this example script.
erem
Domoticz version: 2021.1
Post by erem »
on an iPhone you can switch this off per wifi network.
i have it switched off for my home network.
settings-wifi- choose network-switch off private address
Regards,
Rob
Hellrazr
Post by Hellrazr »
Hi, I got the same problem. Also have the cloudkey gen2. I Need to delete the domocookie.txt to get the script to work. If I don't delete it I get this:
Error: dzVents: Error: (3.1.7) HTTP/1.1 response: 404 ==>> Not Found
Anyone have any ideas how to fix it?
            --domoticz.utils.osExecute("bash /home/pi/domoticz/scripts/remove.sh")
    data = {
        local controllerUrl = 'https://192.168.1.136/' 	--Change IP and Port to your Unifi Controller settings
        local controllerLogin = 'user'						-- Your username for Unifi Controller
        local controllerPassword = 'password'-- Your password for Unifi Controller
        local devices = {
            ['5c:87:30:c1:6b:1d'] = 159,	-- Phone1
            ['da:de:a0:fd:08:46'] = 158,	-- Phone2
            domoticz.openURL({
                method = 'POST',
                postData = {
                domoticz.openURL({
                    method = 'GET',
                        ['mac'] = mac,
                            acc = acc + 1
                        return acc
                    end, 0)
Cheers
Gerald
Post by Gerald »
yes, you need to change the path of the cookie in the script:
In my case it is:
local cookie = /opt/domoticz/userdata/domocookie.txt
Changing this should make the message 404 ==> not found disappear
Hellrazr
Post by Hellrazr »
Thx Gerald, working now :)
madvisionz
Domoticz version: 4.10327
Post by madvisionz »
Had this thing working like a charm in the passed with an USG and Domoticz running on Synology. Moved to an UDM-SE and it's not working anymore. Changed the script to the same like post by basmaaks » Saturday 15 May 2021 10:00 (not the cooky part).
Getting error: dzVents: Error: (3.0.1) HTTP/1.1 response: 404 ==>> Not Found
How can I get this working again on my UDM-SE? Also, FW is enabled on UDM, rule needed to read from Domoticz to Unifi?
Thnx in advanced.
