Detection VPN connection ASUS Merlin Router [Solved]
- Domoticz version: 2021.1
I want to monitor if my internet connection is connected with a VPN or not. So when the VPN is down I want to see that, and get an alarm/message etc.
The VPN provider I have got rotates my VPN connection several times per day/week to get the best/fastest connection available all the time.
Sometimes the VPN connection fails, and I want to know when it does (without looking in my router to see if the VPN is (dis)connected).
My VPN connection is setup in my ASUS RT-AC86U router (running asuswrt-merlin firmware) using openVPN, so all my internet traffic is always routed via this VPN.
I did some google searching, and found out that there's a possibility to use commands via ssh to configure the VPN on/off.
Status of the VPN connection: nvram get vpn_client1_state
Set VPN connection ON: service start_vpnclient1
Set VPN connection OFF: service stop_vpnclient1
But how to get this into a dzVents script? I want something that gives me a status change whenever the VPN is OFF (so I can use this status change of an IDX to make it visible in dashticz), and maybe whenever the VPN status is detected as OFF that automatically the VPN service is started again after like 10 seconds. And have an IDX to switch ON/OFF the VPN connection manually without logging into the router to do so.
I looked at a script which does setup a SSH connection to a ASUS router, but I cannot manage to reform that script with the functionality I need.
viewtopic.php?f=59&t=30755
edit:
I tried the above commands directly via putty logged into the ASUS router and they work OK, I could see the (dis)connecting of the VPN Client in the GUI of the router.
Connected state:
Admin@RT-AC86U-6B08:/tmp/home/root# nvram get vpn_client1_state
2
VPN Service Stop:
Admin@RT-AC86U-6B08:/tmp/home/root# service stop_vpnclient1
Done.
VPN Service Start:
Admin@RT-AC86U-6B08:/tmp/home/root# service start_vpnclient1
Done.
edit:
Connected state:
2
VPN Service Stop:
Done.
VPN Service Start:
Done.
Domoticz beta | Dashticz beta | Synology DS415+ | Wall tablet Teclast 11.6inch (Android) | TADO v3 controlled heating
- erem
Re: Detection VPN connection ASUS Merlin Router
why do you want this from dzVents?
two simple shell scripts will do this for you
1 script to get status from router and update a switch in domoticz thru http/json via curl.
a second switch in domoticz to switch the vpn on/off
2 a script to turn the vpn on/off to be called from the switch
see: https://www.linuxtechi.com/execute-linu ... -over-ssh/
that will get you started
Regards,
Rob
Rob
I'm a total noob with programming and scripts/linux, and found the mentioned post with the dzvents example.
So that's why I thaught maybe that's the way to go.
Even your link is mostly abracadabra for me.
- erem
that makes it more challenging, specially as i do not have an asus router.
all scripting solutions ( dzVents, bash, etc) will require passswordless ssh access to the router.
here is a way to do that. ( google is my friend )
https://www.htpcguides.com/enable-ssh-a ... -ssh-keys/
if you can use ssh without having to enter a passsword we can take the next step.
Regards,
Rob
Rob
- waaren
When you have passwordless ssh between the system with domoticz and the ASUS router, a dzVents script could check the status and restart the VPN service.
I will look and figure out the passwordless part today. Maybe running domoticz on my Synology NAS will give me some struggles to get the passwordless to work.
I prefer the dzVents script as I allready have 2 other of those running for other stuff.
OK, I have enabled the SSH access using this guide:
But when using Putty I still have to login with a username/password.
Next step I did is generating a public key with puttgen, and placing this public key int the ASUS Autohrizated key part of the config.
After rebooting the router and using Putty I still have to login with a username/password.
I can see that the key is stored in the authorized_keys file located in /root/.ssh, and that one is the same as configured in the webGUI.
What are the next steps to do?
- waaren
Did you also created the keyset on your domoticz server and copied the public key to the ASUS Router?
A howto can be found here
The keygen command does not work, but I found another interesting post:
https://www.snbforums.com/threads/dropb ... ord.21070/
and followed those steps.
But run into some issues when the creation of the directory step is not OK. I think that's maybe due to restrictions on my Synology Nas?
The step:
Admin@RT-AC86U-6B08:/jffs/.ssh# ssh [email protected] mkdir -p ~/.ssh
[email protected]'s password:
mkdir: cannot create directory '/root': Permission denied
Maybe my user account does not have enough R/W rights?
The next step after that:
cat /jffs/.ssh/id_rsa.pub | ssh [email protected] 'cat >> ~/.ssh/authorized_keys'
puts the file in the /volume1/homes/Chris/.ssh directory
When now trying to login from my NAS to the ASUS router:
ssh -i /jffs/.ssh/id_rsa [email protected] -p 2211
Warning: Identity file /jffs/.ssh/id_rsa not accessible: No such file or directory.
Looking at the directory on the NAS I can see the copied authorized_keys file.
Looking in the routers directory I see the id_rsa.pub file and the authorized_keys file. The content of the last one matches the contents of the file on the NAS.
The step:
- erem
you are trying to get ssh working from the router to the nas, where you should go from nas to router
ssh is not bidirectional.
on your nas generate a key pair.
leave passphrase empty.
then paste the contents of <home>/.ssh/id_rsa.pub into your router as in the link i sent previously
then, from your nas open a terminal session and ssh into the router.
you should get a question about unknown host, answer yes. (this is one time only)
subsequent logins should now be password free.
ssh-keygen -t rsa
Regards,
Rob
Rob
Aha, that's the sollution!
It now works fine (had to change the file permissions of the genereated id_rsa to 600 as well)
So now passwordless login from my NAS to the ASUS router works!
ssh [email protected] -p 2211
ASUSWRT-Merlin RT-AC86U 386.1_2 Fri Feb 12 22:48:22 UTC 2021
- erem
ok, so you can now use the script ( modified) from your initial post in dzVents on your domoticz from your nas.
if you need help with dzVents, post your questions.
suc6
suc6
Regards,
Rob
Rob
Hi Rob, I think that's a little bridge to far for me... but I will give it a try this evening to figure out that script and rebuild it with the commands I need.
- erem
]Chris,
i am no that good with dzVents, but here is something to visualize the VPN state in domoticz if you are up for it.
you need a virtual switch in domoticz, and remember it's idx number
then create this script
name it getstate.sh and make it executable (chmod +x ./getstate.sh)
update the switch index and domoticz port number in the script to your values
then if you run the script the virtual switch will be updated with the state of the VPN.
#!/bin/bash
# user setup area
routerIP=" 192.168.1.1"
domIPPort="127.0.0.1:8080" #domoticz ip:port
connState="2" # output of VPN connected
dzIdx=17 # change to idx of virtual switch
cmd="nvram get vpn_client1_state"
# NO changes below this line
state=$(ssh Admin@$routerIP -p 2211 $cmd)
echo "VPN state is $state"
if [[ $state -eq $connState ]]
then
echo $state
echo $connState
curl -s "http://$domIPPort/json.htm?type=command¶m=switchlight&idx=$dzIdx&switchcmd=On" >/dev/null
echo false
curl -s "http://$domIPPort/json.htm?type=command¶m=switchlight&idx=$dzIdx&switchcmd=Off" >/dev/null
fi
Regards,
Rob
Rob
Hi Rob, thanks for the script example. I added a dummy hardware and a virtual switch device (idx 1155)
I tried your script but I get a lot of errors because of the used # and $ signs, I think this is a different scripting language you created the script in.
Maybe @waaren can help me out, he has created a lot of scripts and the example posted earlier is made by him as well.
- waaren
Happy to help. What is your domoticz version?
Version: 2020.2 (build 12731)
- waaren
A first version
local scriptVersion = '0.20210324'
local scriptVar = 'SSH_' .. scriptVersion
This dzVents script is used to monitor open VPN state of a ASUS RT-AC86U router loaded with asuswrt-merlin firmware
The script use io.popen to trigger a nvram and when required do a service restart command on a remote system via ssh
(the router must be accessible by the user that is running the domoticz service, via password-less
SSH (with public / private key setup)
Before activating the script:
Read the GETTING STARTED section of the dzVents wiki.
Change the values in the script to reflect your setup
return
on =
timer =
'every minute', -- change to required frequency
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
marker = scriptVar,
execute = function(dz, item)
remoteHost = '192.168.1.1' -- change to router IP
message = 'OpenVPN not connected. Check it out'
-- NO changes required below this line
--commands to execute remote
local commands =
status = 'nvram get vpn_client1_state ',
stop = 'service stop_vpnclient1 ',
start = 'service start_vpnclient1 ',
commands.restart = commands.stop .. '; ' .. commands.start
local function osCommand(cmd)
dz.log('Executing Command: ' .. cmd,dz.LOG_DEBUG)
local fileHandle = assert(io.popen(cmd .. ' 2>&1 || echo ::ERROR::', 'r'))
local commandOutput = assert(fileHandle:read('*a'))
local returnTable = {fileHandle:close()}
if commandOutput:find '::ERROR::' then -- something went wrong
dz.log('Error ==>> ' .. tostring(commandOutput:match('^(.*)%s+::ERROR::') or ' ... but no error message ' ) ,dz.LOG_DEBUG)
else -- all is fine!!
dz.log('ReturnCode: ' .. returnTable[3] .. '\ncommandOutput:\n' .. commandOutput, dz.LOG_DEBUG)
return commandOutput,returnTable[3] -- rc[3] contains returnCode
local function buildSSHCommand(cmd)
local sshBOL = "sudo ssh " .. remoteHost .. " \'"
local sshEOL = ";\'"
local cmd = sshBOL .. cmd .. sshEOL
return cmd
-- Main
local result, rc = osCommand(buildSSHCommand(commands.status))
dz.log(result,dz.LOG_DEBUG)
if result ~= 2 then
dz.log(message, dz.LOG_ERROR)
dz.notify(scriptVar, message, dz.PRIORITY_HIGH)
osCommand(buildSSHCommand(commands.restart))
@waaren, thanks for creating such a script!
I loaded/installed it in domoticz, and after saving checked the logfile that shows (after 1 minute)
I think this is because ssh is running on port 2211 on my ASUS router.
So maybe add a port parameter so the script is more general for other users as well (if needed).
I tried to add it to the script but then it gives some errors:
Can you add another thing as well: adding the status of the VPN to an device in domoticz (I already created a virtaul switch with id 1155) ?
So I can have a visual of the VPN is on/off, and can see how many times it had to be resetted.
2021-03-24 22:09:00.390 Status: dzVents: Info: SSH_0.20210324: ------ Start internal script: VPN Status:, trigger: "every minute"
2021-03-24 22:09:00.390 Status: dzVents: Debug: SSH_0.20210324: Executing Command: sudo ssh 192.168.1.1 'nvram get vpn_client1_state ;'
2021-03-24 22:09:00.537 Status: dzVents: Debug: SSH_0.20210324: Error ==>> ssh: connect to host 192.168.1.1 port 22: Connection refused
2021-03-24 22:09:00.537 Status: dzVents: Debug: SSH_0.20210324: ssh: connect to host 192.168.1.1 port 22: Connection refused
2021-03-24 22:09:00.537 ::ERROR::
2021-03-24 22:09:00.537 Status: dzVents: Debug: SSH_0.20210324: Executing Command: sudo ssh 192.168.1.1 'service stop_vpnclient1 ; service start_vpnclient1 ;'
2021-03-24 22:09:00.681 Status: dzVents: Debug: SSH_0.20210324: Error ==>> ssh: connect to host 192.168.1.1 port 22: Connection refused
2021-03-24 22:09:00.681 Status: dzVents: Info: SSH_0.20210324: ------ Finished VPN Status
2021-03-24 22:09:00.682 Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2021-03-24 22:09:00.795 Status: Notification: SSH_0.20210324
2021-03-24 22:09:00.537 Error: dzVents: Error: (3.0.18) SSH_0.20210324: OpenVPN not connected. Check it out
2021-03-24 22:22:00.832 ...icz/var/scripts/dzVents/generated_scripts/VPN Status.lua:68: unexpected symbol near '" -p 2211"'
2021-03-24 22:22:00.908 Error: dzVents: Error: (3.0.18) error loading module 'VPN Status' from file '/usr/local/domoticz/var/scripts/dzVents/generated_scripts/VPN Status.lua':
2021-03-24 22:22:00.908 ...icz/var/scripts/dzVents/generated_scripts/VPN Status.lua:68: unexpected symbol near '" -p 2211"'
- waaren
Added port and VPNStatus switch in below versionChris12 wrote: ↑Wednesday 24 March 2021 22:26 I think this is because ssh is running on port 2211 on my ASUS router.
return
on =
timer =
logging =
marker = scriptVar,
local remoteHost = '192.168.192.1' -- change to router IP
local message = 'OpenVPN not connected. Check it out'
local port = 2211
local VPNStatus = dz.devices(1155)
local commands =
status = ' /usr/local/ashscripts/nvram get vpn_client1_state ',
local sshBOL = "sudo ssh -p " .. port .. ' ' .. remoteHost .. " \'"
return cmd
-- Main
if tonumber(result) ~= 2 then
dz.log('Result: ' .. result .. ': ' .. message, dz.LOG_ERROR)
VPNStatus.switchOff().checkFirst()
dz.log('openVPN connected', dz.LOG_DEBUG)
VPNStatus.switchOn().checkFirst()
