How to switch a Selector Switch from Python
jjnh
Domoticz version: 2023.1
Post by jjnh »
I am pretty new to Python programming.
Right now I am trying to find out how to gracefully switch a selector switch from Python.
I can turn switches on and off using:
import domoticz
import DomoticzEvents as DE
DE.Command("{name of the device", "on")
But switching a selector switch does not work.
In the meantime I solved it with a CURL command, but there must surely be a better way.
Odroid N2+ 4GB, with an RfxTrx433E, Zigbee with Slaesh's CC2652RB, Z-Wave, BroadLink IR using RM mini 3 and P1 connected.
Domoticz version: 2024.7
Re: How to switch a Selector Switch from Python
If you are not planning to create a Python plugin but just a script to automate some devices you better start with dzVents as it is way better documented and has a better integration with Domoticz and better support https://www.domoticz.com/wiki/DzVents:_ ... _scripting
Just my 2 cents...
jjnh
Post by jjnh »
Thanks for the response. I indeed see that there is very little clear documentation on interfacing with Domoticz from Python.
Having several Dzvents script up and running I indeed agree this is much better, however I am building a script which automates interaction with a Yahboom cooling hat for my Raspberry Pi. This cooling hat uses I2C interfaces to steer a fan, Oled display and some RGB lighting. Therefore I need to import Python libraries.
